Oops I did it again... - Page 8 - Jeep Patriot Forums
The Sway Bar Your Off-Topic Playland.
Non-Jeep related topics.
The Abyss   Where bad threads go to die  (restricted access)
 21Likes
post #106 of 117 (permalink) Old 03-22-2019, 10:20 AM
ColoradoMan's Avatar
Originally Posted by RossoRacer View Post
And in response to the bit about solid axles being horrible off-road....they're still good in many crawling cases, and more durable. Independent suspension just means you can straddle more stuff, and take high-speed desert courses better if you have the spring travel. A "Wrangler" with independent suspension on either end would no longer be a Wrangler, just as having four doors ruins the novelty effect, and just like slapping the Cherokee badge on an independent axle Fiat doesn't make it a Jeep.
Yeah they say the only downside of the independent suspension is that its more expensive to fix, which is true. I do think that solid axels get in the way more off road and if they are in the way probably more likely to get damaged.
If the wrangler would have independent suspension, they would never have the death wobble.
ColoradoMan is offline
post #107 of 117 (permalink) Old 03-23-2019, 01:39 AM Thread Starter
Having wheeled something with full independent suspension, front and rear solid axles, and something with independent front/solid rear, here are my observations:
1) Independent suspension means a MUCH more comfortable off road ride, especially if you're able to disconnect the sway bars. you can run trails a bit faster, and they are less jarring to your spine. BUT you find yourself on 3, or even 2 wheels quite often, meaning a locker or other traction device is almost required, since you'll often have 1 tire on at least one axle able to spin freely, thus getting all the torque, forward progression especially up hill was often an issue I struggled with.
2) front and rear solid axles. I'll admit my XJ had the Cadillac of suspensions, with dual rate springs in the front, OME shocks, and OME leafs in the rear, and it rode way better on and off road that most solid axle jeeps I had ever been in. That being said, Trails were MUCH rougher, and had to be taken slower. BUT due to articulation of the axles, I almost never had even a single tire off the ground, and so with no additional traction devices, (open diffs), places I struggled with my patriot, I had no issues in the XJ. The solid axles tend to be more robust, and can handle more than independent suspension setups on stock to lightly modified vehicles (the axles themselves are thicker/stronger, and have fewer fail points, like CV joints.)
3) independent front, and solid rear: the best and worst of both worlds. Maybe because I went from SUVs to a truck, but the ride is not as good as the patriot, and the articulation is worse than the jeep. If I had the $$, I would Solid axle swap the front end on my truck, no questions. It would have been done yesterday.
It comes down to really what you need/want. If I was doing mostly overland, light duty trails, independent suspension no questions, as long as it had a traction device (locker). if you do more difficult/technical trails, there is no contest that a solid axle setup is stronger, more reliable, and gives better traction in all situations.
as far as death wobble. 99.999% of the time, that is due to a loose track bar, and that is easily resolved by making sure the track bar is not getting loose. Whether the bolt has backed out, the hole it goes through is wallowed out, or the bushings on the track bar have started to fail, resolving the issue fixes the death wobble. and proper maintenance prevents it. (and it's super easy to check, just look at your front axle and have somebody turn the steering wheel left and right, if there is any play at all, it's super noticeable right away.)
1989 Cherokee Pioneer - Sold
2003.5 Mazdaspeed Protege
1998 Mazda B4000 4x4
aroundincircles is online now
post #108 of 117 (permalink) Old 03-24-2019, 12:01 AM
Unsponsored Baja racer
RossoRacer's Avatar
Doesn't the track bar/death wobble situation usually happen from hack job lift kits?
Trekkie, trucker, Jeeper, potential racer. Don't touch my trumpets.
"For God so loved the world that He sent His only begotten Son, that all who believe in him might not perish but have eternal life" -John 3:16
http://www.youtube.com/watch?v=KOb8IEyCO1o
RossoRacer is offline
post #109 of 117 (permalink) Old 03-24-2019, 12:29 AM Thread Starter
no.
post #110 of 117 (permalink) Old 03-25-2019, 12:20 AM
RossoRacer's Avatar
Hrm. Thought I had heard it was from those things being installed improperly, but it's possible that's only one possible source, or that I misheard, or that it's mainly local thing. Phoenix probably has ALOT more good low-cost offroad shops than northern Michigan. We've got barely anything here.
post #111 of 117 (permalink) Old 03-25-2019, 12:53 AM Thread Starter
99.9% of the time, Track bar is loose at the axle.
post #112 of 117 (permalink) Old 03-25-2019, 09:57 AM
What did you off road that was independent suspension that wasn't a patriot?
post #113 of 117 (permalink) Old 03-25-2019, 10:03 AM
Man now you are making me rethink an xterra. I would think the ride would be much improved.
Mods: 225/65/17 Geolandar A/T, K&N Cold air intake
post #114 of 117 (permalink) Old 03-25-2019, 10:51 AM Thread Starter
an original army surplus humvee. Not mine, but a good friend of mine had one back in the early 2000's. Bought it off surplus for a song, and sold it for $50k a few years later. We were able to blast through the desert at 100mph +, and didn't feel a single bump. crawl up the sides of cliffs, but even with its incredible travel, 3 wheeling was quite frequent, and sudden drops on either of the front wheels would cause the back to pop up a bit. I've also been in (but not driven) Rang rovers, which, apart from all the electrical issues, were amazing machines off road, but they all had some sort of traction device to lock the axles.
post #115 of 117 (permalink) Old 03-25-2019, 10:54 AM Thread Starter
Go take one for a drive. They are for sale all over the place. Don't take my opinion as gospel, I've known two guys with them, ridden in them, and as far as I'm aware, they were unmodified. I found them to be a lot harsher than I was expecting them to be. But I also haven't ridden in Liberty either, which has a similar setup, and probably beat you up off road as well.
RossoRacer likes this.
post #116 of 117 (permalink) Old 04-03-2019, 02:26 PM Thread Starter
You Tube
"> You Tube
" type="application/x-shockwave-flash" width="425" height="350">
post #117 of 117 (permalink) Old 04-16-2019, 12:23 AM Thread Starter
Hit 2 million views on my youtube channel!
https://www.youtube.com/c/aicvideo
DangerAaron likes this.
