Cruise control - Jeep Patriot Forums
 2Likes
  • 1 Post By geddisleroy
  • 1 Post By Ignatz
post #1 of 11 (permalink) Old 06-08-2011, 06:05 PM Thread Starter
Cruise control
My cruise control went out the other week. I called a local repair shop and he said it might be a fuse that went out. I looked in the book found where the fuse box is but not sure what fuse it is. He also said it might be connected with my cigarette outlet but that works fine.
Please help.
bmeloo is offline
post #2 of 11 (permalink) Old 06-09-2011, 09:00 AM
The cigar lighter has its own separate circuit. Many other items are lumped together, so your best bet is to pull each fuse and test it. Normally, you can see if the fuse is blown without, but every once in a while, you can get fooled!
Jack Allwardt, Bonney Lake (Tehaleh area), WA; "recovering Californian"; (REPEAT Patriot Owner...'08 Limited and a '16 High Altitude), Retired engineer, US Army veteran, Amateur radio General Class Licensee: K6SNS, Member: American Legion, Veterans of Foreign Wars, Central Valley Vietnam Veterans, Enumclaw (WA) Lions Club. Former vintage military jeep owner, instrument rated commercial pilot, ag pilot, vintage aircraft restorer and test pilot.
post #3 of 11 (permalink) Old 06-09-2011, 10:32 AM
Unlike older cars that use a servo of some sort to open the throttle, our cruise control is just an electric switch/control to the ECM/PCM. The ECM/PCM then opens the throttle electronically. The fuse is a good place to start, but it could also be a problem with the cruise stalk or the clock spring in the steering wheel. Do you at least get the Cruise message show up on the dash when you turn it on or off?
post #4 of 11 (permalink) Old 06-09-2011, 06:59 PM Thread Starter
The cruise light does not show up when I start my vehicle or when I turn the cruise on.
bmeloo is offline
post #5 of 11 (permalink) Old 03-29-2019, 11:17 PM
theGarinator's Avatar
Having the same issue with my 2008 Patriot North.
The cruise does light up on the dash when I press the cruise control button.
It was working intermittently for a while then once, while on the highway, it just spontaneously disengaged. Now it doesn't engage at all, but the light still comes on on the dash.
I"ll check the fuse box ?
Thanks for any insight. Gary
theGarinator is offline
post #6 of 11 (permalink) Old 03-29-2019, 11:54 PM
geddisleroy's Avatar
besides the fuse check the brake light switch, it has two built in switches one for brake light and one for cruise control.
theGarinator likes this.
MODS=Remote start.Chrome grill inserts & door handles, Chrome mirror covers,headlight & tail light trim. 2 din radio with DVD, navigation and back up cam. Curt Trailer hitch, Oil cooler & trailer light wire harness. Parking sensors. Automatic headlights.Dash cam. Rear 12v power outlets. 120 AC 800w power inverter.
My vehicles
2014 Jeep Patriot
2002 Chevrolet Silverado p/u.
1930 modal A Ford 4dr town sedan
1946 Ercoupe 415C Airplane
geddisleroy is online now
post #7 of 11 (permalink) Old 03-30-2019, 06:27 AM
Lightbulb Cruise Control Engaging Issue
I'll poke around for the brake light switch then @geddisleroy,
Thanks for the quick response!
Gary
post #8 of 11 (permalink) Old 03-30-2019, 10:34 AM
I too am having an engagement issue with the CC, so I will look into it. The lights are on and whatnot, but no CC engagement.
Jeeper81 is offline
post #9 of 11 (permalink) Old 04-11-2019, 03:03 PM
Today I pulled out and put back in/returned all the fuses. Made sure they were sitting tight. None were burnt.
Result:
My cruise control started working again.
Go figure. See if that lasts.🤔
post #10 of 11 (permalink) Old 04-11-2019, 08:41 PM
We've had intermittent problems with our 2014 5-spd. Its been good for a couple months now, but its gone out a few times over the years. I didn't do a thing, I'd just check it every so often and shazam! its back.
post #11 of 11 (permalink) Old 04-12-2019, 07:44 AM
I had an intermittent cruise control failure where restarting the car would fix the problem. It became more frequent so I took it to the dealer who noted that no codes were thrown. They replaced the switch assembly under warranty and the problem hasn't recurred.
2016 Patriot Sport, 5 speed manual, 4x4.
pahiker is offline
