Help Needed: Lights, Turn Signals, Wipers are in-op - Jeep Patriot Forums
post #1 of 2 (permalink) Old 05-14-2019, 11:44 AM Thread Starter
I’m having issues with my 2009 Patriot. I had the left directional on, turned left, then a quick turn right, while I moved the directional to a right turn. After I performed these actions, I lost turn signals, lights, windshield wiper controls, hazards etc.
• All fuses good
• Replaced left multi-functional turn signal switch, work temporarily then all in-op
• Replaced left multi-functional turn signal switch second time, along with new Clock spring did not fix, same issues
• With the second new multi-functional turn signal switch and Clock Spring, I’m still getting intermittent and inconsistent function. Such as windshield wipers turn on once in a while but when switch off, still on, or delayed to turn off, hazards and turn signals intermittent, head lights same issues.
What else should I be looking at?
Regards,
Chris
nileek is offline
post #2 of 2 (permalink) Old 05-15-2019, 09:07 AM
After replacing the switch, some have had to disconnect the battery for 10 mins or so to reset the PCM.
https://www.jeeppatriot.com/forum/17...signals-2.html
No wipers or lights or turn signals Oktazcat Electrical and Audio 36 04-09-2019 03:53 PM
Turn signals, headlights wipers, emergency flashers stopped working again. 2009 patri Crowder79 Jeep Patriot General Discussion 1 05-22-2018 06:00 AM
2011 Jeep Patriot: OP Overland Garrett Build Threads 0 08-19-2016 01:09 PM
coin-op washer is f'd up... JamesNewJeep The Sway Bar 0 03-26-2011 09:37 PM
lost signals, wipers and headlight controls...AGAIN.. mono1029 Electrical and Audio 3 08-02-2010 03:09 PM
