battery size - Jeep Patriot Forums
post #1 of 9 (permalink) Old 02-09-2019, 12:10 PM Thread Starter
battery size
how big will fit?
that scooter battery does not impress me
should I get a AGM ?
2jeepfam is offline
post #2 of 9 (permalink) Old 02-09-2019, 12:21 PM
5speed's Avatar
Look at NAPA and Rockauto. I usually replace the original equipment battery after 4 years but my Pats are garage kept so earlier replacement may be necessary in other conditions.
2017 Patriot Latitude, FWD, 2.4, 5spd. 2016 Patriot Sport, FWD, 2.0, 5spd.
5speed is offline
post #3 of 9 (permalink) Old 02-09-2019, 01:22 PM
TrailBlazerZ71's Avatar
I run an Interstate group 7576 agm and it fits the same as the oe battery
Mike
"Though I drive through the valley of the shadow of diesel, I will fear no turbo, for your horsepower art with me. Your bore and stroke, they comfort me"
'98 Chevrolet K1500 - 5.7L/4L60E - Eternal Project
'02 Chevrolet 2500HD - 8.1L/Allison 1000 - Tow Rig
'16 Jeep Patriot FDII - 2.4L/CVT2L - Daily/Offroad Rig
TrailBlazerZ71 is offline
post #4 of 9 (permalink) Old 02-09-2019, 01:29 PM
I had a Costco battery go bad while on a trip, and the out of state Costco didn't have the exact replacement, muttering something about a "Californian thing...", so the battery they did give me, was a little too big--I couldn't secure it or place the cover back on, but when home again, I used the old Dremel tool and cut a wider space at the bottom edge of the box, and it fit just fine! That battery was larger capacity than stock, and lasted over 5 years when I traded my '08 for a '16.
Take a look at the battery box the next time you have the battery out, and see what slight modifications you could make to fit a larger footprint battery in there.
And, good luck!
Jack Allwardt, Bonney Lake (Tehaleh area), WA; "recovering Californian"; (REPEAT Patriot Owner...'08 Limited and a '16 High Altitude), Retired engineer, US Army veteran, Amateur radio General Class Licensee: K6SNS, Member: American Legion, Veterans of Foreign Wars, Central Valley Vietnam Veterans, Enumclaw (WA) Lions Club. Former vintage military jeep owner, instrument rated commercial pilot, ag pilot, vintage aircraft restorer and test pilot.
post #5 of 9 (permalink) Old 02-09-2019, 05:06 PM Thread Starter
yes it looks like there is some room to work with
when it isnt 0F some day ill have a closer look
2jeepfam is offline
post #6 of 9 (permalink) Old 02-10-2019, 02:05 AM
Flamewave's Avatar
I fit a Group 34 Northstar AGM in mine with a little tray cutting. https://www.amazon.com/gp/product/B01GS3VK9C/
This is all I had to cut to get it to fit. Excuse the dirt.
Flamewave is offline
post #7 of 9 (permalink) Old 03-15-2019, 11:52 AM
Lucas's Avatar
I usually use a standard size battery. Of course there are situations when there is a problem with the start of the engine, but I already know that this happens because of low battery level and I know how to solve this issue. Sometimes the problem is in voltage. I've solved my issue with help of battery maintainer. Also I can recommend you to turn on the lights for 2 sec before starting engine if it's too cold in the street.
Lucas is offline
post #8 of 9 (permalink) Old 03-21-2019, 12:46 PM
Lucas's Avatar
I usually use a standard size battery. Of course there are situations when there is a problem with the start of the engine, but I already know that this happens because of low battery level and I know how to solve this issue. Sometimes the problem is in voltage. I've solved my issue with help of battery maintainer, you can choose one from this review list(​https://carinmydna.com/best-battery-maintainer/​​​). Also I can recommend you to turn on the lights for 2 sec before starting engine if it's too cold in the street.
Lucas is offline
post #9 of 9 (permalink) Old 03-21-2019, 01:16 PM
croat's Avatar
I was worried this year about our batteries, both the Benz and Jeep are over 4 years in our ownership and the batteries were just fine. Garage kept and I get the Jeep was a new battery 4 years ago however the Benz is like 6 years old - got it tested and was perfect. I need to remember in fall to check again.
Religion has convinced people that there’s an invisible man…living in the sky, who watches everything you do every minute of every day. And the invisible man has a list of ten specific things he doesn’t want you to do. And if you do any of these things, he will send you to a special place, of burning and fire and smoke and torture and anguish for you to live forever, and suffer and burn and scream until the end of time. But he loves you. He loves you and he needs money.
~George Carlin
croat is offline
Intermittent battery light and battery going dead djscoggins Electrical and Audio 7 09-22-2016 04:27 PM
Battery JeepPatriotGirl00 Engine and Drivetrain 14 03-03-2008 03:08 PM
Battery Terminal Protectors & Anti-Corrosion Goo Donovan Electrical and Audio 3 02-13-2008 09:47 PM
Battery Replacement DJ XS Electrical and Audio 0 12-29-2007 04:49 AM
Electrical Issues - Battery Light Dawson Electrical and Audio 5 06-16-2007 01:36 PM
