Checking cvt fluid level - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 04-16-2012, 02:19 AM
jeep1stone jeep1stone is offline
Member
Ride: @012 Cherry Red Compass with North All Season 4x4
jeep1stone is on a distinguished road
How do you check the cvt trans fluid level as there is no visible dipstick.
Sponsored Links
Advertisement
  #2
Old 04-16-2012, 02:37 AM
dgcarp dgcarp is offline
Junior Member
dgcarp is on a distinguished road
You can't check it yourself. Dealer has a special probe to check fluid.
  #3
Old 04-16-2012, 02:41 AM
Metaxa's Avatar
Metaxa Metaxa is offline
Senior Member
Ride: 2011 Patriot
Metaxa is a splendid one to beholdMetaxa is a splendid one to behold
Jeep, in its wisdom, has made that a dealer only thing.
They treat the CVT as a sealed unit, not to be serviced other than the dealer fluid and filter indicated in your manual.
Any other thing wrong with it and they toss it and sell you a new one.
This has to do with the contract they have with the company that makes the tranny...or so I read.
Here is the thing, its a Nissan/Mitsubishi owned company, JATCO, so the trans could be fixed (out of warranty) by a Nissan or Mitsubishi dealer.
http://www.allpar.com/mopar/transmissions/CVT.html
The dealer does have a dipstick and, again, I read somewhere, probably here, that you can buy one for $60+.
But why?
  #4
Old 04-16-2012, 02:51 AM
Metaxa's Avatar
Senior Member
Ride: 2011 Patriot
Found some more:
Quote:
Checking the fluid in the CVT
isn’t straightforward. In fact, the procedure
follows along the same lines
as the NAG (722.6) and even the new
62TE. There’s no dipstick; customers
are encouraged to take their vehicle to
a repair facility every 15,000 miles to
have a trained technician check their
fluid. A special tool, Miller part number
9336, is used to check the level, which
depends on fluid temperature. Since the
fluid level can change almost 12mm
from 70F to 190F, the level must be
checked with the 9336 dipstick and
cross-referenced to a chart or table.
From the bottom of the internal stop the
fluid level should be:
Temperature High Low
77F 38mm 25mm
138F 42mm 29mm
191F 46mm 34mm
The fluid is expected to last the life
of the vehicle, but maintenance schedule
B (which pertains to most vehicles)
would require the fluid to be changed
every 60,000 miles. According to
DaimlerChrysler, schedule B includes
vehicles driven under any of these conditions:
• At temperatures below 32F (0C).
• Stop and go.
• Extensive engine idling.
• Dusty conditions.
• Short trips of less than 10
miles (16 km).
• More than 50% at sustained
high speeds during hot weather,
above 90F (32C).
  #5
Old 04-16-2012, 04:05 AM
msilvia01's Avatar
msilvia01 msilvia01 is offline
Senior Member
Ride: 2011 Jeep Patriot Latitude FDI / 1989 YJ Sahara
msilvia01 is on a distinguished road
It's funny cause I was trying to check it today and I turned the plug out and I was like wtf where's the dipstick? It's pretty ridiculous that you have to bring it to the dealership just to check the levels. I feel like this is just another way for them to make money. It's completely unnecessary give me a f***in dipstick and let me check it when I want to, like how cars used to be made. This is a joke.
__________________
2011 Jeep Patriot Latitude 4x4 FDI CVT, black wheels, black emblems, short black antenna, led reverse bulbs, led license plate bulbs, Warn off road yellow fogs, stampede rain guards, curt class III hitch, molded splash guards, Rockford Fosgate Prime R1693 6x9's x4, and of course my jeeppatriot.com stickers on side windows old stickers hard to see, patriot grille sticker on front windshield... more to come.
  #6
Old 04-16-2012, 07:56 AM
dixiedawg's Avatar
Senior Member
Ride: 2014, silver, FDII
I think Todd did a write-up once on how to use the oil dipstick to check the trans fluid levels?
__________________
  #7
Old 04-16-2012, 01:34 PM
todde702's Avatar
todde702 todde702 is offline
Senior Member
Quote:
Yea, you can use the oil dipstick, but it's only going to tell you that it is staying the same. Whether it's low or high, you need Jeep to check it. Here's what I do though:
The CVT fluid is very temperature sensitive, so you want to always check it after a good long drive (like after your drive to work or some similar long commute). You want to also park in a level spot, and in the same spot each time you check it.
Leave the engine running and put the transmission in park. Set the handbrake as well for safety.
Pull the CVT fluid tube plug and pull your oil dipstick. I clean off the dipstick using a paper towel with some windex on it, just to make sure I don't add a little engine oil into the cvt fluid.
Insert the oil dipstick into the trans tube and fully seat the handle into the top of the tube (you can't push it down any further). Now pull it out and read the level. On mine, it came to just below the "low oil" mark on the dipstick. This was a few days after I took delivery of the Jeep, back in 2008. If it's very cold or warm outside, expect it to move slightly up or down on the dipstick, but it should still be visible.
Again, this won't tell you if it's at the correct level, but it will let you watch that it doesn't change drastically. If you notice a drastic change, get to a dealer and have them check the fluid level.
__________________
-Todd
Quote:
- William Shakespeare
- Anonymous
  #8
Old 04-23-2012, 08:58 AM
Dustin's Avatar
Dustin Dustin is offline
Member
Ride: 2008 Trail Rated Patriot- Steel Blue
Dustin is on a distinguished road
Todd, when you check your fluid level is the engine running and transmission in park?
  #9
Old 04-23-2012, 12:14 PM
todde702's Avatar
Senior Member
Quote:
My bad! Yes that is how I check mine. I'll edit my reply above to include that.
__________________
-Todd
- Anonymous
  #10
Old 04-23-2012, 05:09 PM
cali-brate cali-brate is offline
Junior Member
cali-brate is on a distinguished road
If you scratch some measurements onto the backside of your oil dipstick, there is no reason it wouldnt work as well as the factory tool. Its calibrated in millimeters. Compare the level to the chart in the service manual. For an accurate temperature to compare too, let it sit 8 hours during the day and consider it ambient temperature.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
