how hard is it to change alternator on 07 patriot? - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 04-15-2012, 10:44 AM
pajpat07 pajpat07 is offline
Junior Member
pajpat07 is on a distinguished road
I've got a 2007 2.4L 5 speed patriot I bought in January. Its got just over 70k on it and the alternator is dying. I'm a student and am wandering how hard it is to change it out myself. I've never really worked on it but am pretty good w/ things like this. Don't want to break the bank if i don't have too but don't want to get in over my head either. Any feedback or help would be great.
how long should this take and how difficult is it?
Thanks
Sponsored Links
Advertisement
  #2
Old 04-15-2012, 10:54 AM
Terasec's Avatar
Terasec Terasec is offline
Senior Member
Location: from NYC and have places in upstate NY and in PA
Ride: 2007 Patriot, Light Khaki, 4x4, CVTII FdriveII,
Terasec is just really nice
Send a message via AIM to Terasec Send a message via Yahoo to Terasec
Alt is still a do it yourself replacement part,
Not as easy as past cars that can be done in minutes on the side of the road. But still doable,
Procedures are here somewhere.
Involves removing front passenger tire, and water pump and accessing it through there.
  #3
Old 04-15-2012, 11:11 AM
Junior Member
yeah came across the procedure somewhere. Just reading it always sounds easier than doing and that's what I'm afraid of. Do you happen to know where I could find a diagram of it or the engine?
  #4
Old 04-15-2012, 01:34 PM
todde702's Avatar
todde702 todde702 is offline
Senior Member
Actually, I don't think you have to remove the water pump but you do have to unbolt the AC compressor so that you can get the AC lines to move and flex a little as you wiggle and turn the alternator down and out.
Here's the text of the procedure from the 2008 FSM:
Step #12 is the tricky part where you have to rotate the alt. assembly a certain way to get the heavy battery post between the ac line and the engine block before you tip the front pulley side down towards the ground.
Quote:
REMOVAL
1. Disconnect and isolate negative battery cable at battery.
2. Remove the right front wheel.
3. Remove the underbody air dam.
4. Remove the accessory drive splash shield.
5. Remove the accessory drive idler pulley.
6. Loosen the lower mounting bolt.
7. Loosen the A/C compressor and relocate, pull down and to outboard side of vehicle to make room to remove generator.
8. Unplug field circuit from generator.
9. Remove the B+ terminal nut and wire.
10. Remove the upper mounting bolt.
11. Remove the generator lower mounting bolt.
12. Relocate the battery terminal (1) to the other side of the A/C line (2) for removal of the generator.
13. Rotate generator pulley down.
14. Slide generator down and out of vehicle.
__________________
-Todd
Quote:
- William Shakespeare
- Anonymous
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
