Electronic Throttle Control (ETC) - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 12-04-2008, 02:32 AM
Jeep Frank's Avatar
Jeep Frank Jeep Frank is offline
Senior Member
Ride: 08 Patriot FD1 06 Ford F150 65 Mustang GT Fastback
Jeep Frank is on a distinguished road
There have been a few posts about this, but my problem sounds a little different so I thought I would share. The other day I was parked on a slight incline (don't know if thatís relevant) and went to start my Patriot after finishing lunch at a restaurant. The Patriot would crank but not start. The electronic throttle control light came on (the lightening bolt with parentheses). Finally after about five attempts the Patriot started and the light went off. I haven't had a problem since. I was getting an oil change any way, so I had the dealer look into it. They said they couldn't find anything wrong and there was no codes stored. It turned out there was a service bulletin out an electronic throttle control issue. My understanding of a service bulletin is itís a recommendation for mechanics of where to start if they encounter a related problem. They did a software update to the PCM. Don't know if it is related to the problem or not. If anyone else has ETC problems the service bulletin might be a good place to start. If I have any other problems I will update this thread.
Sponsored Links
Advertisement
  #2
Old 04-12-2009, 01:53 AM
Jeep Frank's Avatar
Senior Member
Still hasn't happened again....
  #3
Old 04-12-2009, 02:01 AM
cwm cwm is offline
Senior Member
cwm is on a distinguished road
I had the lightening bolt signal happen two times. Once on a long steep downgrade, Loveland Pass, and the other time on I-70, downhill but not a steep section. Next oil change I mentioned what happened.
They said they did the reflash. A few days later on Loveland Pass at the same place it did it again. But it hasn't done it since.
Did the yellow symbol that looks like a engine also come on at the same time? It usually seems to take about three start stop cycles, turning the ignition off and restarting, to get the engine light to go off.
__________________
Colorado
2008 FD-II
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
