CHECK Your Transmission Fluid Level!!! - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 03-01-2012, 06:36 AM
pursuit1980's Avatar
pursuit1980 pursuit1980 is offline
Senior Member
Ride: 2011 Jeep Patriot Sport :: 5-Speed
pursuit1980 will become famous soon enough
__________________
O|||||||O Jeep...Adventure Begins O|||||||O
Sponsored Links
Advertisement
  #2
Old 03-01-2012, 09:28 AM
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxTater1800 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxTater1800 is offline
Guest
Ride: 2010 White Patriot Sport 4X2 W/5spd
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxTater1800 is on a distinguished road
I never check mine. It is almost a easy to replace it every other oil change.
After draining, the drain plug is put back in. Next the 2 rubber plugs are removed. I fill from the top hole until the lower hole overflows. There are several ways to do this but I use a long funnel.
This fluid is supposed to last forever but it does get black with use. I have found that shifing is better with fresh fluid.
  #3
Old 03-01-2012, 12:42 PM
renospatriot renospatriot is offline
Senior Member
renospatriot is on a distinguished road
I just got back from the dealership and my transmission was 1 qt low. New 2012 Patriot 5 spd.
  #4
Old 03-01-2012, 04:16 PM
JamesNewJeep's Avatar
JamesNewJeep JamesNewJeep is offline
Senior Member
Ride: 2010 Jeep Patriot Sport 4x4
JamesNewJeep has a spectacular aura about
Will report back when I check.
__________________
"Lucy"-All-Terrain, all-weather, AWD, 18" of clearance, can jump for more clearance up to 3.5', amphibious, runs on dog food, protects family. More capable than my Patriot?
The new budget-"It's a good deal, but some poor people remain oddly unf*cked"-Jon Stewart
  #5
Old 03-01-2012, 05:24 PM
MrJeepR44's Avatar
MrJeepR44 MrJeepR44 is offline
Senior Member
Ride: 2012 Rav4 Limited 4wd V6, former 2011 Limited FDII
MrJeepR44 is a glorious beacon of light
Quote:
Originally Posted by pursuit1980 View Post
...ENSURE you maintain a CLEAN environment and keep any dirt/grime/dust completely away from the transmission bung holes.
I hope this both warns and helps.
I too try to keep dirt clear of my bung hole.
  #6
Old 03-01-2012, 07:21 PM
ColoradoMan's Avatar
ColoradoMan ColoradoMan is offline
Senior Member
Ride: Patriot 5-sp (sold), 2011 FDII Latitude.
ColoradoMan is a jewel in the rough
Wonder if I should have this checked as well soon.
  #7
Old 03-02-2012, 12:35 AM
jepstr67's Avatar
jepstr67 jepstr67 is offline
POTM November 2008
Ride: 2008, 4x4, FD1, 5 speed. 25D long live vinyl seats
jepstr67 is a jewel in the rough
I was surprised to see how often the maintenance schedule says to change the transmission oil. I don't recall the interval right now, but it is fairly often, like 12,000 miles or so.
__________________
NO INCUMBENTS!
____,_____
//_l_l_,\____\,__
l_/--\_l__l/--\0lllllll0
_(o)) _) _(o))---))_______________________________
  #8
Old 03-02-2012, 01:49 AM
miketmx's Avatar
miketmx miketmx is offline
Senior Member
Ride: 2015 Patriot North 4X4 FD1 6 Speed Auto
miketmx is on a distinguished road
I see the instructions are how to check the level; OK but how do you drain the old fluid ? and I thought the drain & refill mileage was 80,000 km or 50,000 miles ?
  #9
Old 03-02-2012, 04:24 AM
MrJeepR44's Avatar
Senior Member
GOLD!!!
Sorry could pass up the opportunity... LOL
  #10
Old 04-14-2012, 10:19 AM
MKP12's Avatar
MKP12 MKP12 is offline
Senior Member
Ride: 2012 MK limited FDII / 2004 WJ rock crawler
MKP12 is on a distinguished road
I have a new Patriot Sport, 5 Speed, with 1,300kms.
I was due to take my wife and daughter away for the weekend so I decided to check the fluid levels, oil, water, etc....
While checking the manual transmission oil level, I noticed it felt a bit dry, although suprised, being brand new car, I went and purchased some MOPAR ATF+4, and a 1litre oil pump bottle made for filling transmissions/diffs etc... hard to reach places basically.
Being that its a brand new car practically, I only put 200ml into the bottle ready to pump it in, thinking this would be MORE than enough to top it up to the overflow hole.....WRONG!
The transmission needed 700ml!!! before a single droplet started forming on the overflow hole.
700ml!!! Rediculous!!!
Now I bet there is at least 80% of members here who have NEVER checked their transmission fluid level.
Personally, this is a no-brainer, I would now urge EVERYONE to check their transmission fluid level asap!
I'm new to the patriots so forgive me if my question is abit ignorant, but I was wondering why you used Automatic transmission fluid when you have a manual transmission? Isn't that what the "ATF" in ATF+4 means? that it's for automatics? Or is that what is required? I know The transfer case on my WJ uses ATF+4 too, so it's pretty versatile just never heard of it being used on a manual tranny.
__________________
''Every fight is a food fight when you're a cannibal''
Lol... http://m.youtube.com/watch?v=d4znGSK2uEc
  #11
Old 04-14-2012, 10:40 AM
goguadi's Avatar
goguadi goguadi is offline
Senior Member
Location: Breaza , Romania and Nea Trapezounta-Katerini , Greece
Ride: 2.0 CRD LTD Patriot, ,3.0 crd Commander
goguadi has a spectacular aura about
replaced all transmission fliuds at 95000 km.
gearbox (6 speed ) - ATF 4+ (bought from the dealer,as it can't be found in normal shops)
transfer case and diff - 80W-90 transmission oil (Castrol)
the colour of the original oils was still very nice btw.
__________________
[OlllllllO]
Eat,sleep,Jeep
2.0 CRD Limited,Lifted with StuCoils,1.25" wheel spacers,engine-transmission&gas tank skidplates,6000K HID conversion kit,rear parking sensors,tow bar,245/65/17 Lassa Competus A/T on League 208 Nocturne rims (summer tires),235/65/17 Kingstar RW07 on stock rims (winter tires), chrome grille,Patriot door sill guards,Startech Lifestyle leather interior,Husky Liners,Jeep aluminium pedal and dead pedal set.
Nothing like the sweet smell of Diesel
  #12
Old 04-14-2012, 10:43 AM
08MKinKY's Avatar
08MKinKY 08MKinKY is offline
I don't reMember
Ride: 2008 Jeep Patriot Sport 4x4
08MKinKY has a spectacular aura about
Send a message via Skype™ to 08MKinKY
My name is Cornholio!!!
I need TP for my bung hole!!!!!!
__________________
  #13
Old 04-26-2012, 11:31 PM
Pasadenaed Pasadenaed is offline
Junior Member
Ride: 2008 patriot
Pasadenaed is on a distinguished road
Definitely gonna do this over the weekend.
  #14
Old 04-28-2012, 02:20 PM
Billofthenorth's Avatar
Billofthenorth Billofthenorth is offline
Senior Member
Ride: 2012 Jeep Patriot, grey, 2.4L, 5 speed manual 4x4
Billofthenorth is on a distinguished road
Wow, at least Chrysler is consistent. I checked my 5 speed manual today, 2012 got it in Dec ('11) and it was almost a quart low. By the way I stuck my finger in the hole and got enough fluid on it so that I thought it was full, just to make sure I poured a bit of fluid in, then a little more, then some more all in all about 8/10 of a quart before it started coming out the side bung.
I'm jumping on the "check yours" band wagon. I went out to buy wax and microfiber towels and almost blew off getting the ATF4+ but went ahead and got some, figured what the heck I'll check it once I'm home. Sure glad I did.
By the way the screw heads and bolt take 8mm and 10mm sockets AND I found you don't have to open the air filter container, just remove the air intake hose and one bolt on the box and there are 3 plastic pins underneath the box that fit into rubber grommets, you can lift the entire thing out and off to the side to get to the bungs. In fact it's so easy to then access the front screws that I'll say remove the entire box if you want to change the filter.
I wonder what the tolerances are on these transmissions? I know in the old days you had to be right on, a low ATF level could ruin the tranny, I hope these newer ones can handle lower levels and it's just a matter of the cheapskates at the plant filling them to the lowest permissable level.
Glad these forums are here, the Jeep is a much loved vehicle so these issues get some exposure, I can't imagine a Le Car or a Yugo having a forum of it's own.
__________________
Become feral!
  #15
Old 08-20-2012, 01:11 PM
le6920 le6920 is offline
Junior Member
Ride: 2011 Silver Patriot Latitude FWD 2.4L MTX
le6920 is on a distinguished road
I'm new to Patriot's and just bought a used 2011 Latitude FWD 2.4
with a 5 speed trans. How do you go about changing the manual trans fluid? Is there a write up with pics perhaps?
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
