Engine Oil Change Intervals? - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 02-01-2012, 12:31 PM
Doogals's Avatar
Doogals Doogals is offline
Senior Member
Doogals is on a distinguished road
Question Engine Oil Change Intervals?
Owner's manual says to change the engine oil every 13,000 km (8,000 miles) - every other vehicle I've owned was always 5,000 km (3,000 miles).
So why does the Patriot get additional engine oil life out of regular 5W-20 if it's not a synthetic or synthetic blend?
Interested to know, thanks.
Sponsored Links
Advertisement
  #2
Old 02-01-2012, 12:53 PM
jepstr67's Avatar
jepstr67 jepstr67 is offline
POTM November 2008
Ride: 2008, 4x4, FD1, 5 speed. 25D long live vinyl seats
jepstr67 is a jewel in the rough
Many newer vehicles have a 6000 mile change cycle. Engines are held to tighter manufacturing tolerances, produce less heat and wear, and generally last longer without failure. I still change mine every 3000 miles. Although I'm beginning to wonder if that is necessary. If you are not going to keep the car 30 years and drive it 700,000 miles, changing the oil more often is just peace of mind, not necessity.
__________________
NO INCUMBENTS!
____,_____
//_l_l_,\____\,__
l_/--\_l__l/--\0lllllll0
_(o)) _) _(o))---))_______________________________
  #3
Old 02-01-2012, 12:56 PM
ralphfr's Avatar
ralphfr ralphfr is offline
Senior Member
Ride: WHITE 2012 FDII PATRIOT SPORT
ralphfr will become famous soon enough
Question ME TOO???
Hello DOOGALS,
I just picked up my Patriot last weekend and I never asked about service intervals. The book says 8K but I think that is the maximum. From my research this vehicle determines the proper interval all on it's own. Based on many parameters that are run through the ECC like driving style, temp etc... There is another thread here that has lots of good info. You can use the search function to find it. Good Luck with the vehicle.
  #4
Old 02-01-2012, 05:00 PM
todde702's Avatar
todde702 todde702 is offline
Senior Member
As RalphFR stated, there is a oil change indicator. I have the 2008 model which had a 6000 mile/6 month interval or when the change oil indicator lights up, whichever occurs first. I average 5300-5800 miles per change depending on how and where I drive (it's always towards the lower end if the wife drives it a lot). Mine just went off again at 56,000 miles and my last change was 50,400 so I got a good 5600 miles out of the last change.
And just fyi, all 5W-20 oil is either a synthetic blend or full synthetic. There isn't any 5w-20 pure conventional oil (from what I have read on numerous forums and websites).
__________________
-Todd
Quote:
- William Shakespeare
- Anonymous
  #5
Old 02-01-2012, 05:21 PM
MrJeepR44's Avatar
MrJeepR44 MrJeepR44 is offline
Senior Member
Ride: 2012 Rav4 Limited 4wd V6, former 2011 Limited FDII
MrJeepR44 is a glorious beacon of light
My '06 civic has a 10,000 or 15,000 mile oil change interval. I can't remember which one it is, but its high. I use full synthetic in both vehicles
  #6
Old 02-10-2012, 04:07 AM
RHill RHill is offline
Senior Member
Ride: 2008 Sport FDI 5MT, Trailer Prep, Mopar Hitch
RHill is on a distinguished road
I change mine every 5,000 miles. It is easy to remember.
__________________
As of November, 2014, 28.97 MPG for the first 84,280 miles, 70% highway, 29.7% city, and 0.3% off pavement.
Yokohama Geolander AT-S 215/70R16 all terrain tires. Speedometer corrected by telling the computer I have the 215/65R17 optional tires.
  #7
Old 02-10-2012, 09:08 AM
NHPATRIOT's Avatar
NHPATRIOT NHPATRIOT is offline
Senior Member
NHPATRIOT has a spectacular aura about
Quote:
I think "maybe" you are confusing 0W-20 with 5W-20. There is no 0W-20 conventional oil( that I have ever seen anyway ). Initially 0W-20 was only available in full synthetic but there are now a couple blends. 5W-20 is definitely available, and always has been, in conventional oil however. The OEM oil( MOPAR )is conventional oil( used to be Mobil but believe it is now SOPUS ).
All the major brands( Castrol, Pennzoil/Quaker State, Mobil, Kendall, Valvoline, etc... )offer 5W20 conventional oil.
__________________
Royal Purple
SOLD
2011 Jeep Patriot Latitude
2.4L CVT 4WD FDI
  #8
Old 02-10-2012, 09:18 AM
NHPATRIOT's Avatar
Senior Member
1) - 6 months/8000 miles is the MAXIMUM time you can run the oil. It is not the actual recommend oil change interval. Chrysler( Jeep )actually says to go by the Oil Life Monitor and change when it says to. If it does not trip by the 6/8000 however then you must change the oil( warranty compliance ).
2) - the days of the 3 month/3000 miles oil change interval are finally going away( thank goodness ). That interval was fine and dandy in the 60's-70's when oil was of a much lesser quality. Modern oil is capable of going much longer before requiring a change. Auto mfg's are finally catching up.
Modern oils have vastly improved base stocks and additive packages that allow them to have a much longer service life. Changing a modern API certified SL/SM/SN oil before 5000 miles, even conventional oil, in a healthy engine is just a waste of resources( obviously serious hard use or contaminates from off roading etc... can change that ). If you use a quality, name brand, properly rated and certified oil in your vehicle, with a good filter, you should be able to do...
Conventional - 5000
Syn Blend - 7000
Full Synthetic - 10,000+
IMO 8000 is too long on conventional oil despite all my praise of modern oil. 5000-6000 with a premium filter is the max I would personally run any brand or weight.
__________________
Royal Purple
SOLD
2.4L CVT 4WD FDI
  #9
Old 02-10-2012, 10:09 AM
tiptronic's Avatar
tiptronic tiptronic is offline
POTM Winner AUG. 09.
Ride: Jaguar X-type 2.5 4x4
tiptronic has a spectacular aura about
Send a message via Skype™ to tiptronic
My Peugeot 308 is every 2 years or 20.000 miles . This is for the petrol engine , I believe the diesel engine model is every 12 months or 12.000 miles ....
__________________
Just swapped red Classic X , for, Green Auto SE " Spirit " 2.5 Petrol Limited edition X still 4x4,
Ex 07 Patriot CRD Sport , UK ( with lots of chrome goodies )
  #10
Old 02-14-2012, 06:01 PM
CHVYPWR's Avatar
CHVYPWR CHVYPWR is offline
Senior Member
Ride: '08 Patriot 2.4 CVT 4x4
CHVYPWR will become famous soon enough
Quote:
Same here, on both my Patriot and S10.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
