Front Brake Pad Replacement - Jeep Patriot Forums
Notices
Suspension and Wheels Articles covering suspension, lifts, gears, axles
as well as tires and wheels.
Click for instructions on how to post an article in the Knowledge Base
Reply
Thread Tools Display Modes
  #1
Old 01-14-2012, 06:18 PM
Borderspeed's Avatar
Borderspeed Borderspeed is offline
Judge Dredd
Ride: 08 Patriot CRD Limited/Land Rover 90
Borderspeed will become famous soon enough
Thought I'd upload a photo guide to changing the front brake pads.
Only tools required were a jack, axle stands, a 14mm spanner, a caliper wind back tool and a tie-wrap to hold the caliper up.
Jack up vehicle and support with an axle stand, remove road wheel
Using a 14mm spanner or socket remove these two bolts at rear of caliper, remove caliper and support securely so as not to strain brake hose
Remove the old pads and retain the anti-squeal shims
Slider bolts
Once removed you should be left with this view
Use a brake caliper piston wind back tool and push piston fully to the rear,(Note make sure you unscrew the fluid reservoir cap at master cylinder under the bonnet)
Once pushed in it will look like this
Fit new brake pads in a reversal of removal
Refit anti-squeal shims
Refit caliper and slider bolts and torque to specification, repeat process on the other side, tighten fluid reservoir cap, refit wheels and then press brake pedal until a firm pedal is achieved...once satisfied road test and brake gently to bed in new pads and then enjoy improved braking response.
This should take approximately twenty minutes per side to complete.
__________________
NON ARTE SECT MARTE
Royal Air Force Veteran-Gulf War/Bosnia/Kosovo/Sierra Leone
Scottish and Proud!
Sponsored Links
Advertisement
  #2
Old 01-14-2012, 07:04 PM
Judge Dredd
OK now sorted out pictures!
__________________
NON ARTE SECT MARTE
Scottish and Proud!
  #3
Old 01-15-2012, 05:48 PM
Judge Dredd
Description sorted now as well...hope its of use!
__________________
NON ARTE SECT MARTE
Scottish and Proud!
  #4
Old 02-20-2012, 09:20 AM
guydc's Avatar
guydc guydc is offline
Junior Member
Ride: 2009 Patriot 4wd FD1
guydc is on a distinguished road
Thank you for the picture it's really clear
No action with the ABS?
  #5
Old 02-20-2012, 12:04 PM
Metaxa's Avatar
Metaxa Metaxa is offline
Senior Member
Ride: 2011 Patriot
Metaxa is a splendid one to beholdMetaxa is a splendid one to behold
The only thing I might add to this is your slider pins should be cleaned and lubed.
Ask at the auto parts store cause its not grease, per se. Some sort of silicone stuff but its special, not what you have laying around. (Although I stand to be corrected on that statement)
Love a post with pictures, nice and clear.
Last edited by Metaxa; 02-20-2012 at 12:05 PM. Reason: to express my love of pictures.
  #6
Old 02-20-2012, 01:31 PM
dixiedawg's Avatar
Senior Member
Ride: 2014, silver, FDII
Nice post, good photos, good step-by-step. Thanks!
__________________
  #7
Old 02-20-2012, 07:34 PM
Judge Dredd
No this doesn't involve anything to do with the ABS.
__________________
NON ARTE SECT MARTE
Scottish and Proud!
  #8
Old 02-20-2012, 07:38 PM
Judge Dredd
Thanks...I did do the sliders but forgot that bit! Oops!
Quote:
Thank you, I started to do one for Track Rod End replacement but hit an issue with removing the old joint half way through so once that is resolved I will post a guide on that as well!
__________________
NON ARTE SECT MARTE
Scottish and Proud!
  #9
Old 02-20-2012, 08:22 PM
guydc's Avatar
Junior Member
thanks for the reply
Do you have change the rear pad?
  #10
Old 02-20-2012, 10:37 PM
Metaxa's Avatar
Senior Member
Ride: 2011 Patriot
80+ percent of your braking is done via the front wheels so generally speaking you just visually check the rear pads. If there is material on the rear pads you are good to go. Its best to remove the wheel and inspect front and back pad, I've seen a front pad look good while the back pad is worn out. Not supposed to happen that way but it can.
The thing is to get them changed before the pads reduce to metal backing or even before the squealers activate. Saves your rotors, making a brake job easy peasy in your driveway.
I have a Suzuki XL7 with just under 400,000K with original rotors and they still measure within specs.
Those with front discs/rear drums need to do things a bit differently, inspect the rears at least every second tire rotation, both to ensure you can get the drum off the wheel and to have a look. The best ongoing thing for drum equipped Patriots is to 1) use the E brake often, its how your brakes keep in adjustment and 2) once a month or so find a lot or road that is safe and do a bunch of braking while moving in reverse. High speed (for reverse) and low speed, over and over for ten minutes or so.
  #11
Old 02-21-2012, 01:43 PM
Rosco's Avatar
Rosco Rosco is offline
Member
Ride: 2007 Jeep Patriot Limited 4x2 cvt
Rosco will become famous soon enough
I recently replaced my front pads and ordered new ones from rock auto. They came with a small packet of silicone to lube the slider pins with. But I have some anti-seize compound and it says right on the bottle that it can be used on brake sliders.
  #12
Old 02-21-2012, 01:48 PM
croat's Avatar
croat croat is offline
Senior Member
Ride: Tiburon & Patriot
croat is a jewel in the rough
Brake job 101
Yea this is the same for most all cars with the exception of my Hyundai which you need a special tool in order to retract the rear caliper piston back in place (needs to be turned clockwise while pressure is applied).
__________________
Religion has convinced people that there’s an invisible man…living in the sky, who watches everything you do every minute of every day. And the invisible man has a list of ten specific things he doesn’t want you to do. And if you do any of these things, he will send you to a special place, of burning and fire and smoke and torture and anguish for you to live forever, and suffer and burn and scream until the end of time. But he loves you. He loves you and he needs money.
~George Carlin
  #13
Old 02-22-2012, 08:38 PM
FunkRider's Avatar
FunkRider FunkRider is offline
Junior Member
Ride: 98 Cherokee, 09 Patriot
FunkRider is on a distinguished road
I've had a lot of success with opening the bleeder screw on the caliper when pushing the piston back. This removes the fluid subject to the most heat rather than pushing it back up through the lines. Top up the fluid when you are done the brake job, pump the brake pedal and check the fluid level after.
  #14
Old 02-25-2012, 07:57 PM
Judge Dredd
Quote:
Originally Posted by croat View Post
Brake job 101
Yeah the tool used in the sequence above does that as it has a double sided disc with protruding pins which worked fine on my Hyundai Tucson.
Quote:
That's fine if you have the experience and equipment to bleed the brakes afterwards if needs be....however I meant this guide to be a minimal tools/no fuss "how to" for those who are not so confident!
__________________
NON ARTE SECT MARTE
Scottish and Proud!
  #15
Old 02-25-2012, 08:01 PM
Judge Dredd
Rear pads is pretty much the same...it makes it easier if you just undo the bottom caliper slide bolt and then swing the caliper upwards as the brake pipe obstructs access to the top bolt...then just repeat the procedure...pads out...retract piston...refit shims..clips etc and refit new pads..bolt caliper back down.... road test and then have a beer or a cuppa!
__________________
NON ARTE SECT MARTE
Scottish and Proud!
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
