Replace themostat - Jeep Patriot Forums
Notices
Newbie Check-In First Post? Make your big introduction here.
Reply
Thread Tools Display Modes
  #1
Old 12-07-2011, 07:28 PM
patmac patmac is offline
Junior Member
patmac is on a distinguished road
Replace themostat
Does anyone know where the thermostat is located and how difficult it is to change? I have a 2007 patriot 2.4
Sponsored Links
Advertisement
  #2
Old 12-07-2011, 07:47 PM
todde702's Avatar
todde702 todde702 is offline
Senior Member
Here's some info from the 2008 factory service manual:
Testing:
Thermostat diagnostics is included in Totally Integrated Power Module's (TIPM) programming for on-board diagnosis. The malfunction indicator light (MIL) will illuminate and a diagnostic trouble code (DTC) will be set when an open too soon condition occurs. Do not change a thermostat for lack of heater performance or temperature gauge position, unless a DTC is present. For other probable causes, (Refer to 7 - COOLING - DIAGNOSIS AND TESTING).. Thermostat failing shut is the normal long term mode of failure, and normally, only on high mileage vehicles. The temperature gauge will indicate this.
Removal:
GAS - PRIMARY THERMOSTAT
1. Partially drain cooling system (Refer to 7 - COOLING - STANDARD PROCEDURE).
2. Remove air filter housing.
3. Disconnect coolant hose (1) from inlet housing (2).
4. Remove inlet housing bolts (3).
5. Remove thermostat assembly, and clean sealing surfaces.
GAS - SECONDARY THERMOSTAT
1. Partially drain cooling system. (Refer to 7 - COOLING - STANDARD PROCEDURE).
2. Remove air filter housing .
3. Disconnect coolant hoses (1) from rear of coolant adapter (2).
4. Remove radiator hose (3).
5. Remove radiator hose (4) from front of coolant adapter (2).
6. Remove coolant adapter mounting bolts.
7. Carefully slide coolant adapter off water pump inlet tube and remove coolant adapter (2) and secondary thermostat.
__________________
-Todd
Quote:
- William Shakespeare
- Anonymous
  #3
Old 12-07-2011, 08:03 PM
Junior Member
Thanks Todd that is exactly what I was looking for. I am from the old school/classic type car owner and this patriot is my daily driver . I can work on the classic's but these new models task my ability to do my own repairs.
  #4
Old 12-07-2011, 09:07 PM
todde702's Avatar
Senior Member
Also, the primary stat is 180 deg. F and the secondary is 203 deg. F.
__________________
-Todd
- Anonymous
  #5
Old 12-07-2011, 09:47 PM
Junior Member
once again thanks. you have been a great help. been searching for repalcement parts. that is when i figured out that they have 2 of them. about the same time you replyed. need to do some more home work and i think i will be able to replace them with a little help from my eldest son this weekend. between the two of us we have five classic hot rods. we do almost all of our own work on them. this looks like it is going to be eaiser than i first thought.
  #6
Old 12-13-2011, 05:46 PM
KillaCam's Avatar
KillaCam KillaCam is offline
Senior Member
Ride: 2009 Jeep Patriot Limited
KillaCam is on a distinguished road
patmac I couldn't agree with you more - there's not much I enjoy more than working on my own car but these new systems make it more difficult than it used to be...
Thankfully this forum is full of superstars like Todd - an abundance of helpful information is within the threads!
__________________
-2009 Limited Patriot, FWD CVT II, 30% tint front windows, 15% all other windows, blacked out muffler, blacked out tail lights, Curt Class III Hitch, auxiliary reverse lights, custom mesh grill, Husky All-Weather Floor Mats, Black PATRIOT bumper inserts
-1942 Willys MB 4x4...rebuilt and running strong!
  #7
Old 06-02-2013, 12:46 AM
cn90 cn90 is offline
Junior Member
Ride: 2009 Patriot
cn90 is on a distinguished road
Quote:
Thanks,
From looking at Jeep parts websites:
http://www.trademotion.com/parts/200...iagram=WD07045
They list the tstats as 170F and 203F.
I'd love the replace the 170F with 180F, do you know the PN for the 180F tstat?
  #8
Old 06-02-2013, 09:59 AM
Terasec's Avatar
Terasec Terasec is offline
Senior Member
Location: from NYC and have places in upstate NY and in PA
Ride: 2007 Patriot, Light Khaki, 4x4, CVTII FdriveII,
Terasec is just really nice
Send a message via AIM to Terasec Send a message via Yahoo to Terasec
Quote:
You are not alone,
Find most new cars have turned routine tasks into major ordeals.
  #9
Old 06-02-2013, 10:29 AM
todde702's Avatar
Senior Member
Quote:
Originally Posted by cn90 View Post
Thanks,
I couldn't say cn90. According to the 2008 FSM, this is how the T-Stats operate.
Quote:
OPERATION
When the Engine is cold and both the primary and secondary thermostats are closed. The coolant will circulate through the engine, heater system, and the bypass. The cooling system has no flow through the radiator
As the engine warms up, the primary thermostat will start to open at 82 C ( 179 F). Coolant will start to flow through the radiator oil cooler and transmission cooler. Coolant will flow through the transmission oil cooler only when the primary thermostat is fully open. The primary thermostat will fully open at 95 C (203 F).
The secondary thermostat will start to open at 95 C (203 F). This will increase the coolant flow through the cylinder block and cylinder head and the radiator. The secondary thermostat will fully open at 110 C (230 F).
If the thermostat is stuck open or allows coolant leakage through it, the engine will not operate at the proper temperature for obtaining engine fuel efficiency, performance and emissions levels. If this condition occurs, a diagnostic trouble code will be set and a MIL light will be turned on. Refer to the Powertrain Diagnostic Procedures manual for further information and diagnostics provided.
__________________
-Todd
- Anonymous
  #10
Old 10-24-2013, 11:20 PM
Junior Member
Ride: 2009 Patriot
There is some discrepancy here...
I just replaced the thermostats. The primary tstat clearly has Chrysler logo and "170" engraved in it.
The tstat I bought from autohausaz.com also says 170.
The FSM says 179 for primary tstat!!!
What is going on here?
  #11
Old 10-25-2013, 08:27 AM
todde702's Avatar
Senior Member
Being a mechanical part, it's likely that the T-Stat starts to open at 170 deg. and is fully open by 180 deg. The same may be true of the secondary, which I think someone else mentioned was labeled 190. Those may be the opening temps not the fully open/max flowing temps.
__________________
-Todd
- Anonymous
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
