LED INTERIOR/EXTERIOR HAS BEGUN - Page 2 - Jeep Patriot Forums
Notices
Interior Interior questions and modifications.
Seats, dash, rollcages, mounts and misc
Reply
Thread Tools Display Modes
  #16
Old 12-14-2011, 09:39 PM
andrewmsmagee's Avatar
andrewmsmagee andrewmsmagee is offline
Member
Ride: 2011 Black Patriot 4x4 Limited loaded
andrewmsmagee is on a distinguished road
PICS :D
As we all know, there is nothing we don't like more then pictures to accommodate all of the talk! so here is some pictures i took of my jeep in the garage, with only 3 of the 4 dome lights swapped over to blue LEDs
ID:	9213   Click image for larger version
ID:	9214   Click image for larger version
__________________
I'm 19 roaming, living like the Romans do....
Sponsored Links
Advertisement
  #17
Old 12-14-2011, 11:18 PM
Earthworm51's Avatar
Earthworm51 Earthworm51 is offline
Senior Member
Earthworm51 will become famous soon enough
Nice and Bright. Do you need to wear Sunglasses when the Dome Lights are on ? Good job.
__________________
  #18
Old 12-14-2011, 11:23 PM
Member
they are significantly brighter then the stock bulbs :P i am pleased with the light output. Although i was told, from a female perspective, that the blue light is not good for applying makeup hahaha, but other then that, i have no complaints
__________________
  #19
Old 12-14-2011, 11:31 PM
Senior Member
I changed my interior to the clear LEDs but after seeing yours, I might just change colors.
__________________
  #20
Old 12-15-2011, 12:40 AM
SAR Medic's Avatar
SAR Medic SAR Medic is offline
Member
Ride: 2011 Jeep Patriot North Edition 4x4. White
SAR Medic is on a distinguished road
Quote:
Originally Posted by andrewmsmagee View Post
AHHAHA WOW! that's pretty good! 20 bulbs for $90! :| do you happen to know which eBay sellers you used? and have you tried adding extra bulbs to your tail light? because there's one reverse and one brake/run/turn light, but the tail light looks like there should be 4 separate bulbs. on the inside there is 4 points for bulbs to be placed, but only two are used, the other two are still flat, non punched out caps. I've heard of people "dremeling" out the correct shape, but that seems like a lot of work with minimal margins for error :/ and then you wire in another socket and pop it in..... FYI, I'm addicted to bright lights.... :P I'm just slowly starting out now :P
I'm planning on adding Lights to my taillights in the blanks as you described. Im planning on using these LED HideAways they are more of an emergency vehicle light (which is why i'm installing them). But they could be wired to add onto your Brake or Reverse Lights but not the Running lights, I've also been told to match the colour of the LED to the colour lense housing. so Red for Red and White for Clear. They just drill a 1" hole in the place where the blank is no "fiddley dremeling".
__________________
SAR Medic
-Chris
Respond Search and Rescue
WWW.RSAR.CA
OR
  #21
Old 12-15-2011, 01:20 AM
JamesNewJeep's Avatar
JamesNewJeep JamesNewJeep is offline
Senior Member
Ride: 2010 Jeep Patriot Sport 4x4
JamesNewJeep has a spectacular aura about
You should open that thing for business as a mobile tanning booth....Then get some willing ladies to take their clothes off and get inside.
__________________
"Lucy"-All-Terrain, all-weather, AWD, 18" of clearance, can jump for more clearance up to 3.5', amphibious, runs on dog food, protects family. More capable than my Patriot?
The new budget-"It's a good deal, but some poor people remain oddly unf*cked"-Jon Stewart
  #22
Old 12-15-2011, 10:29 AM
KillaCam's Avatar
KillaCam KillaCam is offline
Senior Member
Ride: 2009 Jeep Patriot Limited
KillaCam is on a distinguished road
looks good with the blue lights - good touch! Any updates on the turn signals? Good input from Croat on the resistors...keep us posted on that front.
JamesNewJeep, I like where you're heads at, my man :-)
__________________
-2009 Limited Patriot, FWD CVT II, 30% tint front windows, 15% all other windows, blacked out muffler, blacked out tail lights, Curt Class III Hitch, auxiliary reverse lights, custom mesh grill, Husky All-Weather Floor Mats, Black PATRIOT bumper inserts
-1942 Willys MB 4x4...rebuilt and running strong!
  #23
Old 12-15-2011, 10:36 AM
croat's Avatar
croat croat is offline
Senior Member
Ride: Tiburon
croat has a spectacular aura about
Yea you can buy them online for $5-10 each in a fancy aluminum housing (not needed) plus shipping ..... or simply go to the local radio shack to get em for a fraction of the price.
__________________
Those who desire to give up freedom in order to gain security will not have, nor do they deserve, either one.
~Thomas Jefferson
  #24
Old 12-15-2011, 10:42 AM
croat's Avatar
Senior Member
Ride: Tiburon
Also I prefer the white LED's as its a crisp bright light.
The ones I got for the landrover are even brighter.
http://www.ebay.com/itm/320753762036...84.m1497.l2648
__________________
~Thomas Jefferson
  #25
Old 12-15-2011, 06:44 PM
Member
to anyone with fairly good electrical knowledge.... would the 3757 bulb type with 4 wires, as apposed to 3 wires on the 3157 which i was told would fit, is the only difference between the 3757 and the 3757a socket the little side tabs? because 3757 tabs are centered, our 3757a are offset to each other.... so if i dremel off the tabs on the 4wire type bulb, will it work the same?
__________________
  #26
Old 12-15-2011, 10:58 PM
croat's Avatar
Senior Member
Ride: Tiburon
A 3757 and 3157 are interchangeable. Just like all of my landrovers bulbs were the European counterparts of the 1156/1157 and they work just fine.
__________________
~Thomas Jefferson
  #27
Old 12-16-2011, 08:33 AM
Member
Quote:
even though the 3157 is 3 wires/contacts as apposed to 4 wires/contacts on 3757? ill take a picture of the bulbs i have for the signals tonight... if they are interchangeable i could just dremel off the tabs to make it fit
__________________
  #28
Old 12-16-2011, 11:16 AM
croat's Avatar
Senior Member
Ride: Tiburon
Yes - anyone selling bulbs will claim both are interchangeable as well as with 3057, etc. Some care you need to take a tab off the bulb for fitment but on my old dodge which took 3757's I converted them to 3157's without prob's. Here is one of the hundreds of testimonial write ups on it - but do not buy those bulbs
http://coloradofans.com/forums/63-ac...05-2008-a.html
__________________
~Thomas Jefferson
  #29
Old 12-16-2011, 03:29 PM
Member
so i guess the only difference between the stock 3757a bulb and the aftermarket 3157 bulb is the 3757a has 2 negative contacts and the 3157 only has one? also the 3757a lock tabs are positioned differently :P ill take some pictures tonight, if i get the chance, and upload them to show u the difference
__________________
  #30
Old 12-16-2011, 03:45 PM
Member
v-leds does have a 4 wire version of the bulb, im wondering if i should exchange mine for those ones and just dremmel off those tabs....
__________________
Sponsored Links
Advertisement
Reply
Tags
exterior, interior, leds, lights
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
