Pilot Fog Light Kit - Page 3 - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #31
Old 08-12-2011, 03:04 PM
Guitar Dude 33's Avatar
Guitar Dude 33 Guitar Dude 33 is offline
Member
Ride: 2008 Jeep Patriot Sport 4X4, fully loaded
Guitar Dude 33 is on a distinguished road
I know the post is a few months old, but i'm wondering why a Relay wasn't needed? I'm looking at adding the exact same thing (fog lights with external switch) but all the other posts seem to mention including a relay somewhere in the install. Whats the purpose/benefit of one, and is their any damage that could be done without one?
__________________
2008 Patriot Sport, Bright Silver Metallic, 2.4 L, FD1, Fully Loaded.
Sponsored Links
Advertisement
  #32
Old 08-12-2011, 04:50 PM
Afmcronnie's Avatar
Senior Member
Ride: 2012 Wrangler. Owned 2 Patriots.
Without a relay you would need to run a wire to the interior that was of the correct guage to flow ALL the power for BOTH lights. And a switch with similar capabilities. In the described setup you only need a switch/wiring running inside that can handle the comparativly low amperage of the relay. The main power is run through the relay switch. Much safer.
__________________
  #33
Old 08-17-2011, 01:52 PM
Justin Murphy's Avatar
Justin Murphy Justin Murphy is offline
Member
Justin Murphy is on a distinguished road
This what I was looking for!
Just got a base Pat and wanted to install some fogs.
Thanks!
  #34
Old 11-20-2011, 10:59 AM
felonius felonius is offline
Junior Member
felonius is on a distinguished road
anyone know where in Canada you can order this fog light set? Amazon won't ship to me
Thanks!
J.
  #35
Old 11-20-2011, 01:59 PM
the_jeep_now's Avatar
the_jeep_now the_jeep_now is offline
2012 POTY
Ride: 2010 Jeep Patriot FDI Optic Green
the_jeep_now will become famous soon enough
Just have somebody buy it for you in the States and then ship it to you in Canada...just a thought.
__________________
"Jeep isn't just another vehicle, it's the lifestyle."
TJN's Build Thread
  #36
Old 12-28-2011, 12:37 PM
EastBeach's Avatar
EastBeach EastBeach is offline
Senior Member
Ride: 2010 Brilliant Black Patriot FDI 4x4
EastBeach is on a distinguished road
Quote:
Originally Posted by the_jeep_now View Post
My Patriot didn't come with fog lights. I ordered a set of Pilot lights for $32.82 (http://www.amazon.com/Pilot-Automoti...=pd_ys_iyr_img). Here is how I installed them:
- Removed the inner fender splash cover for easier access.
- Removed black plastic cover.
- Drilled the hole from underneath to use the existing L-shaped bracket.
- Used the existing screw through the drilled hole to mount one side of the bracket.
- Attached the fog light to the bracket.
- Routed the wires inside the cabin to the switch. I chose the switch location to the right of the steering wheel column cover. I broke the plastic switch the kit came with so I installed a different one from Kragen.
- And the final product...
Special thanks goes to Murman for helping me out with troubleshooting with the wiring
I just received my fog lite kit, pilot...same as yours, and I was wondering if you removed the front wheels to have more room to work? Also, could you tell me where and how you routed the wired into the cabin? May you be able to post more photos to help me?
__________________
http://www.fuelly.com/driver/eastbeach/patriot
You have to be very careful if you don't know where your going, because you may not get there.
  #37
Old 12-28-2011, 03:29 PM
EastBeach's Avatar
Senior Member
Anyone with this kit or another? Is it possible to install without removing the wheels?
__________________
  #38
Old 12-28-2011, 11:35 PM
2012 POTY
Responded to your email. Hope it helps.
__________________
TJN's Build Thread
  #39
Old 12-29-2011, 12:15 AM
EastBeach's Avatar
Senior Member
Have not started job yet and not sure if I need to remove the wheels? Can it be done without removing the wheels? Also, is there a good hoisting point that will lift whole front end and place jack stands?
Anyone with ideas to ease in this installment?
__________________
  #40
Old 12-29-2011, 12:43 AM
2012 POTY
I'm sure you can do it without removing the wheels but it'll be very tight and hard to maneuver. Sorry, not sure about jack stands as I did mine one at a time.
__________________
TJN's Build Thread
  #41
Old 12-29-2011, 07:13 AM
EastBeach's Avatar
Senior Member
Thank you for the input...very helpful. I hope to tackle this little project shortly. oh, one last thing...where exactly did you route the wires into the cabin? a photo would be excellent, if possible....Thanks again for all the info.
__________________
  #42
Old 12-29-2011, 10:03 AM
2012 POTY
I don't have a photo but here to give you an idea, courtesy of jlobaugh.
http://www.jeeppatriot.com/forum/sho...89&postcount=1
__________________
TJN's Build Thread
  #43
Old 12-29-2011, 10:24 AM
festerw festerw is offline
Senior Member
festerw will become famous soon enough
There aren't any places to lift the whole front end at once, you can use the stock jack points and put stands under the control arms.
__________________
2003 Jeep Wrangler X - 4.0
2005 Jeep Grand Cherokee Laredo - 3.7
  #44
Old 12-30-2011, 08:57 PM
EastBeach's Avatar
Senior Member
Thank you both. Guess I will just lift one wheel off at a time. Btw, TJN tell me the fog lite kit is not as involved as those photos you posted ? I do get the general idea though.
Done and Done...not so bad. They are super brite....and I feel like they are a bit warm to the touch when on...hmm.
Name:	fog lite switch.jpg
ID:	9302   Click image for larger version
Name:	pilot fog lites.jpg
__________________
  #45
Old 02-08-2012, 09:24 PM
Junior Member
Sorry to drag this one up again...
So in this case, a relay was not used. Just the default wiring along with a switch.
But an optimal install would have a relay first, then to a switch?
Cheers,
J.
Sponsored Links
Advertisement
Reply
Tags
aftermarket, fog lights, pilot
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
