Changing tail lights - Jeep Patriot Forums
Notices
Exterior Exterior questions and modifications.
Guards, rails, armor, racks, mounts, etc
Reply
Thread Tools Display Modes
  #1
Old 04-07-2011, 02:04 PM
waylandcool waylandcool is offline
Member
Ride: 2008 Patriot Sport 4X4, Brilliant Black
waylandcool is on a distinguished road
I need a little help getting the taillight out so I can change a blown bulb. It looks like the tail light is held on by two bolts that have plastic covers over them. I can't seem to pry the covers off the bolts though. Any ideas??
Sponsored Links
Advertisement
  #2
Old 04-07-2011, 05:16 PM
nocoJack nocoJack is offline
Senior Member
Ride: 2011 Jeep Patriot 4x4
nocoJack is on a distinguished road
Check out page 389 in your 2008 Patriot manual.
Open the liftgate, remove the two push pins that are on the right of each light. The whole light unit should pull out. After that, twist and remove the socket light units.
  #3
Old 04-07-2011, 08:59 PM
johnnyboy123's Avatar
johnnyboy123 johnnyboy123 is offline
Senior Member
Ride: 2012 Dodge Charger SXT V6
johnnyboy123 will become famous soon enough
http://www.jeeppatriot.com/forum/sho...d.php?p=303202
__________________
2010 Jeep Patriot Sport 4x4 Latitude
Black Muffler - Curt Class III Hitch
MyGig RER - Rockford Fosgate Prime 1693 6x9's
20% Tint Front, Factory Tint Rear
Cooper Discoverer AT3 235/65R17
  #4
Old 04-11-2011, 01:05 PM
Member
I got it, thanks for the help.
  #5
Old 04-12-2011, 05:10 AM
cooluks cooluks is offline
Banned
cooluks is on a distinguished road
Quote:
How about this steps:
Step One:
Know or evaluate on how to access your blown bulb. A lens cover might need to be removed before you are able to make the change. It is also possible that the change needs to be done via the trunk. Inspect the light to find out which access point you will need to use. If there are no visible screws on the lens cover you will need to change the bulb through the trunk.
Step Two:
For an exterior change, unscrew the lens cover to expose the burnt out bulb. You now need to remove the bulb. Apply light pressure while turning simultaneously to extract the broken bulb. Be careful not to apply too much pressure so you donít break the bulb and cut yourself. It may be quite difficult to remove if the glass is broken. For a trunk change remove the interior panel to make the change.
Step Three:
Once you have expose the bulb you need to determine what replacement you need. Take your used bulb to your local automotive supply store or locate the correct replacement online. Be sure to select the correct bulb for your vehicles particular make and model to ensure a fit.
Step Four:
Once you have obtained the correct replacement bulb you may now install it. First check to see if there is any corrosion in the socket. If so clean with a brush or wipe it clean. With the socket prepared simply screw the bulb back into its socket.
Step Five:
With the bulb in place, replace the lens cover if you did an exterior change. Test the bulbs to make sure you have installed them correctly. Step on the breaks and turn headlights on. Have someone confirm that all bulbs go on.
See the videos on step by step on how to replace tailight --> http://www.monkeysee.com/play/6122-c...il-light-bulbs
  #6
Old 06-12-2014, 07:34 PM
redbud redbud is offline
Junior Member
redbud is on a distinguished road
buy a few plactic exspanding replacement fasteners at jeep shop before removing tail light assembly. then just pull the old ones out (2) and remove tail light. bulb is twist to remove wiring harness and pull out bulb
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
