push pin fasteners - Jeep Patriot Forums
Notices
Exterior Exterior questions and modifications.
Guards, rails, armor, racks, mounts, etc
Reply
Thread Tools Display Modes
  #1
Old 01-16-2011, 09:03 AM
error-prone error-prone is offline
Junior Member
Ride: 2008 2-liter 5-sp
error-prone is on a distinguished road
push pin fasteners
Pretty basic question --
How do I remove a push pin fastener?
(Preferably, without breaking it.)
Sponsored Links
Advertisement
  #2
Old 01-16-2011, 09:30 AM
jepstr67's Avatar
jepstr67 jepstr67 is offline
POTM November 2008
Ride: 2008, 4x4, FD1, 5 speed. 25D long live vinyl seats
jepstr67 is a jewel in the rough
There are 2 kinds. The one with 2 parts where a pin pushes into the center to expand the larger pin. The other just has round fins around the shaft. The second kind, I go around the cap several times with a screw driver until I can get under the head and then pry the whole thing out. the other kind I use a small screw drider the get the center pin out and remove the main part with a pliers. I have been able to reuse both kinds, but you have to be very careful taking them out.
__________________
NO INCUMBENTS!
____,_____
//_l_l_,\____\,__
l_/--\_l__l/--\0lllllll0
_(o)) _) _(o))---))_______________________________
  #3
Old 01-16-2011, 09:39 AM
Junior Member
Thanks!
I'll give it a try.
(Probably I should wait until the parts store is open.)
  #4
Old 01-01-2013, 09:29 PM
ski2fast ski2fast is offline
Junior Member
ski2fast is on a distinguished road
Smile Use WD40 or liquid wrench works great!
Thank you to the poster who said try WD40, I never would have thought of that. After almost ruining one push pin I went to the dealer, but they were closed. So after reading the WD40 post I pried up one end of the 'nail' and sprayed WD40 into it. After that it was easy to pry up the 'nail' with a flat head screw driver. I also used two flat head screw drivers at the same time on the next 'nail' which made it easier too. After the WD40 treatment they just pop right out. Also, the amber light will not work, it has tabs that prevent it from going in so you must use the clear light #3157.
  #5
Old 01-01-2013, 10:03 PM
PPiekarski PPiekarski is offline
Senior Member
Ride: '12 Latitude 4x4 in Copperhead Orange Pearl
PPiekarski has a spectacular aura about
Send a message via AIM to PPiekarski
I usually just use some small dikes to prop up the push pin, works like a charm!
__________________
- Engine/Transmission/Fuel tank skidplates - Front tow hooks - 2" tow hitch w/ hook attachment -Deluxe mud guards - Rockford Fosgate R1693 front and rear door speakers w/crutchfield wire adapters - Weathertech digital fit mats/Husky cargo Liner - AVS window visors and bug deflector with Jeep emblem - 2" stubby antenna - UltraGauge - Exhaust tip - RRO Lift - Romik running boards - 1.25" spacers - Jeep plate frames - Mopar door sills - K&N Air Filter -
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
