Bumper repair question - Jeep Patriot Forums
Notices
Exterior Exterior questions and modifications.
Guards, rails, armor, racks, mounts, etc
Reply
Thread Tools Display Modes
  #1
Old 11-08-2010, 11:14 PM
Rzeszowx Rzeszowx is offline
Junior Member
Rzeszowx is on a distinguished road
Basically not even two weeks into having my Patriot, I discovered one morning that someone hit my vehicle overnight and disappeared. The dent is in the left corner of the rear bumper, no paint was removed, it is just concaved inward about the size of a basketball. A few weeks ago I went to the dealership to see how much it would cost to fix and they said the entire bumper had to be replaced, then quoted me at around $700.
I sincerely doubt the bumper needs to be replaced, can anyone confirm this and or provide a guess of how much it would cost someone to just bang the dent out of the plastic?
Sponsored Links
Advertisement
  #2
Old 11-08-2010, 11:18 PM
Arz12793's Avatar
Arz12793 Arz12793 is offline
Member
Ride: '07 Jeep Patriot Sport '86 Dodge D150
Arz12793 is on a distinguished road
I have a very simular dent in my drivers corner of my rear bumper. I went on a trip and came home to find a suprise. I havent got it fixed even a year after it happened. It wasnt worth the cost of replacing the whole bumper.
  #3
Old 11-09-2010, 12:14 AM
harold's Avatar
harold harold is online now
Senior Member
Ride: Black 2.0 CRD Sport 2008
harold has a spectacular aura about
couple of options
remove the bumper, put it on a soft sofa (or similar) and try and force the bumper back into shape from the inside using a large rounded thing - depends on what exactly you are trying to achieve, then use a hairdryer (again from the inside first) to heat the damaged section (should be able to get it almost back into proper shape) and hairdry from the outside if you are comfortable doing it
or buy a new bumper
pictures of the damage would help
__________________
No More Jeep....
  #4
Old 11-09-2010, 01:59 AM
the_jeep_now's Avatar
the_jeep_now the_jeep_now is offline
2012 POTY
Ride: 2013 VW Jetta TDI
the_jeep_now is a glorious beacon of light
Here is another solution. If there is no crack in plastic, remove the bumper, fill up a tub with slightly hot water and put the damaged end into the water, try to force the damaged section back out. It worked perfectly for me once on Dodge Caravan. After it was done, you couldn't even tell that there was once a dent. So do what you're comfortable enough doing. Whatever you choose, I think, buying a new bumper should be your last option.
__________________
"Jeep isn't just another vehicle, it's the lifestyle."
TJN's Build Thread
TJN's Tour
  #5
Old 11-09-2010, 12:57 PM
sab's Avatar
sab sab is offline
Junior Member
Ride: 2007 Jeep Patriot 2X4-Black
sab is on a distinguished road
My front bumper had a push in and I ended up buying a new $900 front bumper but just like you, I feel that it probably could of have been popped out. Doesn't hurt to try then if u fail get your new bumper
  #6
Old 11-09-2010, 02:29 PM
Arz12793's Avatar
Member
I dont think on my bumper ill be albe to just pop it out and it will look good as new becuase there is wrikle in the paint at the point of contact which happens to be the point of the corner. I would be happy with making the lines match up. I can deal with a few wrinkcles.
You can barley see the problem. Its the drivers rear corner at the top.
  #7
Old 11-09-2010, 04:49 PM
harold's Avatar
Senior Member
give it a go yourself - can't really make it any worse?
__________________
No More Jeep....
  #8
Old 11-09-2010, 06:18 PM
Arz12793's Avatar
Member
I got quotes todayfor bothe the front and rear bumpers. Mainly for the front, but they were riduculous, so im gonna work on them this weekend instead.
  #9
Old 11-09-2010, 07:27 PM
johnnyboy123's Avatar
johnnyboy123 johnnyboy123 is offline
Senior Member
Ride: 2012 Dodge Charger SXT V6
johnnyboy123 will become famous soon enough
After being rear ended in my Pat they just repaired the bumper cover (and bent back the metal bumper). There was a slight crack in it but it looks good as new now.
IMO you don't need a new bumper. I remember reading a thread on here about someone parking in the sun and the heat popped the dent out on its own. I would try that or the hair dryer idea if removing it yourself is not an option.
__________________
2010 Jeep Patriot Sport 4x4 Latitude
Black Muffler - Curt Class III Hitch
MyGig RER - Rockford Fosgate Prime 1693 6x9's
20% Tint Front, Factory Tint Rear
Cooper Discoverer AT3 235/65R17
  #10
Old 11-09-2010, 08:24 PM
Keeping Fingers Crossed's Avatar
Keeping Fingers Crossed Keeping Fingers Crossed is offline
Senior Member
Ride: Curator of my old Pat, now my Dad's
Keeping Fingers Crossed is on a distinguished road
Take the bumper off, and carefully from the inside, heat the area with a heat gun, or hair dryer, and see if it pops out easier.
When push comes to shove, you have to try something before 1st before deciding if you need to buy a new bumper, so its worth a shot
  #11
Old 03-04-2011, 11:24 PM
armandjones82 armandjones82 is offline
Member
armandjones82 is on a distinguished road
Why won't you try to have some good repair tips or steps on your bumper, like what I found out here. I'm sure that this would help you out in all the things that you can do for your bumper.
  #12
Old 03-08-2011, 12:12 AM
Junior Member
I never updated anything here but I had a guy who runs a body shop who is a friend of the family check it out, for $150 he pulled the entire thing out and it looks perfectly new. Much better than the $800ish whatever bullcrap the dealership wanted to replace the whole bumper.
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
