Includes all bulletins released through: November 5, 2010
Part 1: Jeep Patriot Technical Service Bulletins
Date ...... Model Yr … TSB # …............................ Description......................
09/25/10 … 0710 … #23-016-10a .. Water Leaks At The Front And/Or Rear Roof Area
09/22/10 … 0710 … #08-024-10 …. Fuel Gauge Fluctuation
06/29/10 … 0910 … #08-014-10 …. REN and REZ Radio Lock Up. Flash Radio with DVD Update Disc
05/20/10 … 2010 … #02-001-10 …. Clicking, Ticking, Grinding, Rubbing Sound and/or Vibration From Front Brakes
03/02/10 … 0810 … #08-004-10 …. Radio Video Disable Update
02/27/10 … 0710 … #18-005-10 …. Flash: Change In RPM When Cruise Control Set Or Resume Button Is Pressed At Or Above 100 KPH
09/24/09 … 0710 … #26-001-09 …. Fluid Flushing Requirements
09/15/09 … 0910 … #05-002-09b .. Pre Delivery - Front Brake Rotor Corrosion Inspection & Procedure
08/12/09 … 0809 … #05-003-09 …. Flash: Full ESP Off Function (supersedes 05-004-08)
08/08/09 … 0709 … #02-001-09 …. Poor Handling and/or Strut Leaking and/or Rides Rough
06/23/09 … 2009 … #18-018-09 …. Flash: MIL Illumination For Diagnostic Trouble Code P0139 Or P0571 Is Set
03/14/09 … 0709 … #08-005-09 …. Flash: Alarm Sensitivity (export models)
03/06/09 … 0708 … #18-005-09a .. Flash: MIL Illumination For P2610 - PCM Internal Engine Off Timer Performance
02/28/09 … 0709 … #05-001-09 …. Brake Vibration or Noise (european models)
02/13/09 … 2009 … #08-003-09 …. MyGig REN or REZ Radio Inoperative After Battery Disconnect
11/27/08 … 2009 … #08-036-08 …. Flash: Audio System Mutes On Start-Up, Amp Settings After Exiting Hands Free Mode, Nav Vol. Corrections
10/30/08 … 2008 … #05-004-08 …. Flash: Full ESP Off Function
10/23/08 … 2007 … #08-033-08 …. Flash: Incorrect Compass Display For "East and West" On EVIC Display In Dutch Language Setting
09/19/08 … 0708 … #23-028-08 …. Squeak or Groan Sound When Raising or Lowering Door Glass
09/11/08 … 0708 … #18-019-08a .. Flash: MIL Illumination with DTC P2173
09/11/08 … 0708 … #18-018-08a .. Flash: DTC P2110 / ETC Lamp Flashes at Speeds Greater Than 95 Miles Per Hour
09/11/08 … 0708 … #18-017-08a .. Flash: Idle Vibration From a Stop With Closed Throttle
09/11/08 … 0708 … #18-016-08a .. Flash: MIL Illumination with DTC P0171
07/23/08 … 0708 … #18-011-08c .. Flash: MIL Illumination with DTC P0139 or P2270
07/22/08 … 2008 … #18-030-08 …. Flash: DTC P2002 - Diesel Particulate Filter Efficiency Below Threshold Or Limp-in Mode
07/22/08 … 0708 … #18-029-08 …. Flash: Diagnostic Trouble Code P0299 - Turbocharger Underboost
07/04/08 … 0708 … #08-007-08a .. No Engine Crank Or No Engine Start Due To Electronic Lockup Of The WCM / SKREEM
06/18/08 … 0708 … #18-011-08b .. Flash: MIL Illumination with DTC P0139 or P2270
05/09/08 … 2008 … #21-014-08 …. Flash: Incorrect Reporting of DTC P0730 for DTC P0717
03/20/08 … 0708 … #18-011-08a .. Flash: MIL Illumination with DTC P0139 or P2270
03/07/08 … 2008 … #21-011-08 …. Gear Clash / Difficult to Shift
03/04/08 … 0708 … #08-007-08 …. No Engine Crank Or No Engine Start Due To Electronic Lockup Of The WCM / SKREEM
02/15/08 … 0708 … #23-008-08 …. Seat Track Creak/Squeak Sound
12/19/07 … 2008 … #05-005-07 …. Flash: ESP Chime Function - Multiple Chime Between Shifts
10/31/07 … 0708 … #06-005-07 …. Clutch Pedal Squeak
10/30/07 … 0708 … #23-046-07 …. Paint Repair - Etching
10/05/07 … 2007 … #21-013-06a .. Continuously Variable Transmission (CVT) Automatic Shifter Diagnostics
10/04/07 … 2007 … #22-004-06 …. Tire Pressure Monitor - System Information
09/18/07 … 2008 … #26-004-07 …. Owner Manual Addendum - Important Notice - Export Models Only
08/22/07 … 0708 … #23-036-07 …. Low Gloss Interior Trim
08/14/07 … 2007 … #24-006-07 …. A/C Compressor Noise or Housing Damage
08/08/07 … 0708 … #23-035-07 …. Exterior Lamp - Lens Fogging
06/23/07 … 2007 … #08-018-07 …. Mopar Remote Start System - RKE - Intermittent Operation Or Alarm May Sound
06/23/07 … 2007 … #23-024-07 …. Metallic Rattle Sound From Liftgate While Driving Over Bumps
06/22/07 … 2007 … #06-003-07 …. Clicking / Scraping Sound From Clutch Pedal Area When Turning Steering Wheel
06/12/07 … 2007 … #23-023-07 …. "A" Pillar Glass Molding Lifting At Upper Edge
06/11/07 … 0708 … #23-027-07 …. License Plate Rattle
05/31/07 … 2007 … #14-003-07 …. Under Flush Fuel Filler Door Splash Shield
05/30/07 … 2007 … #18-018-07 …. Flash: MIL Illumination with DTC's P0016, P0017, P000A, or P000B
05/17/07 … 2007 … #08-010-07 …. Flash: DTC's C121A / C2205 - Steering Angle Sensor - Not Initialized / Internal
05/16/07 … 2007 … #08-001-07b .. Passenger Air Bag Deactivation
05/16/07 … 2007 … #18-032-07 …. Flash: MIL Illumination with DTC P2004
04/28/07 … 2007 … #18-031-07 …. Flash: Launch Performance / Driveability Enhancements
04/26/07 … 2007 … #08-017-06 …. StarSCAN® Vehicle Scan Report Availability
03/30/07 … 2007 … #26-003-07 …. Fluid Flushing Requirements
03/20/07 … 2007 … #23-009-07 …. Radio Speaker Misdiagnosis - Rattle/Buzz Sounds in Door Modules
02/19/07 … 2007 … #18-006-07a .. Generic PCM (GPEC) or TCM (CVT Controller) Replacement Requirements
02/16/07 … 0708 … #26-002-08 …. Add Parking Brake Adjustment To The 30 Month, 30K Miles Or 50K Km Service Interval
08/25/06 … 2007 … #08-030-06a .. Powertrain Control Module Initialization
03/08/06 … 2007 … #23-014-06 …. Windshield Wiper Blade/Element Maintenance
Part 2. Jeep Patriot Recalls
Date ...... Model Yr …… # .......................... Description......................
06/18/2010 … 2007 … RC-K11 …. Accelerator Pedal
11/00/2008 … 2009 … RC-H33 …. Powertrain Control Module
01/00/2008 … 0708 … RC-G42 …. TIPM Re-Configure, Anti-Theft System
01/00/2008 … 0708 … RC-G43 …. AIRBAG LABEL
12/00/2007 … 0708 … RC-G31 …. TIPM Re-Configure, Headlamp Leveling
10/00/2007 … 2007 … RC-G36 …. Manufacturers Weight Label
07/00/2007 … 2007 … RC-F50 …. Reprogram ABS Control Module
05/00/2007 … 2007 … RC-G15 …. Rear Wheel Hub Mounting Bolts
05/00/2007 … 2007 … RC-G19 …. Reconfigure TIPM – Daytime Running Lamps (without Trail Rated option)
05/00/2007 … 2007 … RC-G18 …. Reconfigure TIPM – Daytime Running Lamps (w/Trail Rated option)
11/00/2006 … 2007 … RC-F03 …. Owner’s Manual Rollover Addendum
10/00/2006 … 2007 … RC-F38 …. Engine Camshaft Cap Bolts
Part 3. Jeep Patriot Rapid Response Transmittals
09/09/09 … 2009 … RRT-09057 …. Rear Stabilizer Bar End Link Nut Torque
08/07/09 … 2009 … RRT-09044 …. Sunroof Water Leak
09/29/08 … 0809 … RRT-08070a .. Lower Control Arm (LCA) to Crossmember Mounting Bolts (supersedes RRT-08070)
Chart notes:
Model Year:
"0708" = 2007 and 2008 models
"2007" = 2007 models
"2008" = 2008 models
"2009" = 2009 models
Important:
Some bulletins may apply only to specific production dates, models and/or equipment. Not all affected vehicles will exhibit described problems, failure rates may vary widely. Not all bulletins involve repair issues, some are issued for informational purposes only.
TSB's are not Recalls. "Preventive" service repairs will normally not be performed under warranty if a vehicle is not exhibiting the particular symptom or problem.
For vehicles that are out of warranty, any TSB related work that is performed is usually charged at the normal dealer service rate.
--Compiled and maintained by Milous (c)2008-2009
Chart notes:
Model Year:
Important:
