Engine Code P2004/P2017 Intake Manifold Question - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 07-06-2010, 04:49 PM
Dubl-A Dubl-A is offline
Junior Member
Dubl-A is on a distinguished road
Hello All,
I have a specific question on my 07 Pat and need clarification on this if possible...
I have the P2004/P2017 Engine codes showing up then going away. Intake Manifold Rudder Stuck Open, Sensor On HIGH.
Being this code comes and goes I'm assuming that its dirty/build-up/etc. I have taken the flow valve off and have tried to physically turn the rudder shaft. I can barely turn it either way.
How much should this turn? Being the engine is off is there something preventing it from opening and closing by hand?
I am planning on taking it off and inspecting the actual manifold but am waiting on a replacement gasket so I'm trying to arm myself with as much info as I can (Thanks to yall!)
btw, my Pat has 156k serviced miles on it worry free and this is her FIRST code
Any help is greatly appreciated!!!
Sponsored Links
Advertisement
  #2
Old 07-06-2010, 06:20 PM
todde702's Avatar
todde702 todde702 is offline
Senior Member
156k miles! Jumpin Jehose-a-fat. I think you've got the crown for highest miles on the board! And I gotta ask if you have a CVT or Manual trans?
I would say the shaft should move freely if you've removed the shaft sensor/motor from the one end (top left most section of the picture). Better stuck open then closed though. And it should be a reusable O-Ring gasket on the intake, though at 156k miles worth of heating and cooling, it could tear when coming apart.
__________________
-Todd
Quote:
- William Shakespeare
- Anonymous
  #3
Old 07-06-2010, 06:27 PM
robi454's Avatar
robi454 robi454 is offline
Annoying Member
Ride: 1959 CJ-5 Willy, 2006 Wrangler, 2009 Patriot Sport
robi454 will become famous soon enough
Send a message via Yahoo to robi454
I have to say it sounds like gunk build up, I would run some gumout or fuel injector cleaner thru your system. Get your engine nice and hot when you are doing this. Seems to work well on these engines. At high RPMs the engine breaks up the gunk faster. If you are still getting these codes after that then try manually cleaning the manifold.
This is a great site, not only for Patriot information, but our members offer a variety of other information as well. If you are interested in becomming a "Site Supporter" click the following link it doesn't cost very much only $15 or $20 and helps keep the site going. http://www.jeeppatriot.com/forum/showthread.php?t=2872
Our Site Admin guys are working on updating the site with new software and every little bit helps.
__________________
Sometimes, war is the peaceful solution.
Everyone should believe in something…I believe, I’ll have another beer.
  #4
Old 07-06-2010, 07:13 PM
Junior Member
Thanks for that title
I'm a service technician (Copiers/etc) myself so I understand the importance of keeping up with maintenance and it has paid off.
I have a 2.4 w/CVT.
I did remove that actuator/Flow valve and I couldnt get shaft to move freely.
I noticed you said "sensor" is this physically touching the rudder??
I may try to remove the sensors.
btw, Im currently using the 2008 Patriot Service manual which has limited detail just steps of removing the Manifold itself no sensors/actuator/etc removal.
Thanks again!
  #5
Old 07-06-2010, 07:17 PM
Junior Member
Every Oil change I use Lucas fuel system cleaner.... so Im leaning towards some heavy build-up
I just got the new gasket so I'm just going to take it apart and inspect.
I definitely appreciate the info!!!
  #6
Old 07-06-2010, 07:26 PM
robi454's Avatar
Annoying Member
good luck, I hope you can get this problem resolved. Since you have been using an engine treatment regualry, it could be possible that instead of gunk, gum or grime or as the commercial's call it Engine Sludge, you may have a worn or broken part casuing the malfunction. Talk to the service techs at your jeep dealership, you can call them on the phone most of them have become very helpful since they got taken over by Fiat. They may be able to offer more specific advice.
__________________
  #7
Old 07-07-2010, 09:18 AM
todde702's Avatar
Senior Member
Once you get the manifold off, you'll probably be able to spray clean the flutter valves and slowly work them loose again. Probably just some dirt build up on the shaft. Although, with it all being plastic, it is possible something has warped causing the binding as well. If that is the case, I see that moparonlineparts.com has a new intake manifold for $134. Take some pics along the way to share your experience.
I think were talking about the same thing. I knew it was an actuator, I also figured it would be a sensor inside as well to report the actual position (open/closed) so if there was a problem it could report it.
__________________
-Todd
- Anonymous
  #8
Old 07-07-2010, 12:12 PM
Junior Member
Thanks Guys, I will definitely share the pics
  #9
Old 06-06-2012, 01:14 PM
Nubian Nubian is offline
Junior Member
Nubian is on a distinguished road
Also in need of HELP!!!
How did you make out? my daughter's '07 patriot 2.4L 5 spd has the P2004 code after I floored it. Need to get it fixed ASAP, can't get it inspected till then.
  #10
Old 08-17-2012, 06:10 PM
Stonent Stonent is offline
Senior Member
Ride: 2009 "Jeep Green" Patriot 2.4L CVT
Stonent is on a distinguished road
I just got the p2017 twice in the last month. You're probably only going to get this under hard acceleration because the little flapper things don't really open unless the engine is under a really good load or high RPM. The way I have read was that they restrict air flow to increase the air velocity going into the intake ports to get a better mix with the fuel. Under heavy load, more air is needed so they open up more. I think this happens around the time that Dual VVT kicks in and the valves are open longer and wider.
  #11
Old 10-06-2012, 12:50 PM
Senior Member
Now mine's on all the time and has added a p2004.
  #12
Old 10-07-2012, 06:36 PM
Senior Member
FYI I made some videos of mine and turning the valve.
http://www.jeeppatriot.com/forum/sho...d.php?t=107415
  #13
Old 03-14-2014, 12:00 PM
preston629 preston629 is offline
Member
preston629 is on a distinguished road
old thread but ive got code 2017, anyone found a fix?
__________________
08 patriot all stock
  #14
Old 08-07-2014, 12:48 PM
alexman2525's Avatar
alexman2525 alexman2525 is offline
GP LIFE
Ride: '08 Jeep Patriot 2.4L 5-speed
alexman2525 is on a distinguished road
p2017 code
Quote:
Preston629, I have the same code in my '08 Jeep Patriot popping up. After reading every post about this issue (thanks to todde702 and Stonent for the bulk of the information) I believe that you can fix this by replacing the Intake Manifold Runner Control Valve (Dorman 911-902, search the part number on Amazon for a good price if your a Prime member). I watched the videos by Stonent and the flaps on my intake manifold seem to open and close with ease, no resistance what-so-ever.
So last night I changed out the Intake Manifold Runner Control Valve and after throwing everything back together, I am now getting the code p2004 (intake valve stuck open) so it seems to me that the new control valve is holding the runners open, but not getting the signal to close the them.
I tried to clear the code with my cheapy code reader (Autel MaxiScan MS300 CAN Diagnostic Scan Tool for OBDII Vehicles) but the p2004 keeps pop up.
I was about to take my Jeep to the dealership to see if I need a re-flash or if the dealer's code reader is needed in order to clear that code but then a co-worker asked the simple question: "Did you disconnect the battery and let it reset?" ....I did not, so I'm going to do that today and see if that clears the code. If not, it's off to the dealership to waste my time and probably get hassled to replace the whole intake manifold
Preston629 if your still on the forums and still have this issue, I can send you all the information I have gathered.
  #15
Old 08-07-2014, 02:27 PM
dixiedawg's Avatar
Senior Member
Ride: 2014, silver, FDII
I thought all 08's had the lifetime powertrain warranty?
I never needed the intake manifold, but they did replace my exhaust manifold under warranty.
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
