Adding EVIC - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 06-13-2010, 01:13 PM
brubakes's Avatar
brubakes brubakes is offline
Junior Member
brubakes is on a distinguished road
Adding EVIC
Can you add the EVIC to a Patriot that did't come with one? Parts list? I'm sure its crazy expensive thing to add, but say it was possible....
Sponsored Links
Advertisement
  #2
Old 06-13-2010, 02:43 PM
todde702's Avatar
todde702 todde702 is offline
Senior Member
I'd think you'd need the whole EVIC gauge cluster. I don't think you could add it to a non EVIC one. A PCM flash would also probably be needed to get the functionality. What specific function did you want to get from the EVIC? If it's MPG readings, try a ScanGauge II device. I have one and it has a ton of info available from the PCM (Plus it can pull OBDII codes from just about any vehicle).
__________________
-Todd
Quote:
- William Shakespeare
- Anonymous
  #3
Old 06-13-2010, 03:07 PM
brubakes's Avatar
Junior Member
Quote:
Mostly just wondering out loud. I always like to know what and if options my vehicles could get if they didn't come with it.
Does anyone know if the mileage is stored in the cluster like the Wranglers?
  #4
Old 06-14-2010, 02:24 PM
Tyler-98-W68's Avatar
Tyler-98-W68 Tyler-98-W68 is offline
Compass 2.0
Ride: 2012 Compass Limited, 28F FDII Sun/Sound 430N
Tyler-98-W68 is just really nice
It won't have the same look, but why not get a Scanguage II, it has more features than the Evic, i've got one and love it.
__________________
235/75/15 GY Wrangler Territory | WK2 Projector Headlamp Swap With GTR LED Conversion Kit | 20" 240w LED Lightbar | Magnaflow Muffler | K&N Intake | RRO Lift + RR Winch Bumper Kit + Light Mount | Smittybuilt XRC8 Synthetic Cable Winch | Northstar AGM Deepcycle Battery | Full Interior LED's + Front/Rear Signal & Backup LEDS |Midland Portable CB Radio | Wilson "Little Wil" Antenna |
  #5
Old 06-18-2010, 12:07 PM
brubakes's Avatar
Junior Member
Quote:
I've almost bought the scangauge on several occasions for other Jeeps. Having the EVIC would just be nice for the full factory look.
  #6
Old 06-18-2010, 04:34 PM
Rskitall's Avatar
Rskitall Rskitall is offline
Senior Member
Rskitall is on a distinguished road
I looked into this and you do have to replace the whole instrument panel to get it not worth it unless you get it at a junk yard for cheap.I really wanted the evic also because I can't change my horn on lock or any other setting.It is really annoying for it to honk everytime the doors lock plus I would like to see the gas mileage.
__________________
13 Patriot FD1 4X4 Latitude
770VX2 Viper 2 way Alarm w/factory remote start
Engine oil cooler to double my towing
Hidden Hitch Class 3 2" receiver
Thule cross bars
3,000lb winch on the receiver
  #7
Old 06-18-2010, 04:58 PM
Utopium Utopium is offline
Member
Utopium is on a distinguished road
Quote:
If that is a setting that you don't plan on changing, you could take it to the dealer to have them turn off the horn on lock. They may charge for the programming, but it certainly is cheaper then trying to install an EVIC.
  #8
Old 06-19-2010, 01:41 AM
johnnyboy123's Avatar
johnnyboy123 johnnyboy123 is offline
Senior Member
Ride: 2012 Dodge Charger SXT V6
johnnyboy123 will become famous soon enough
I don't know if this works on the 07's but to change it to not beep/or to beep when you press lock on the key fob.
Press and hold lock button on remote for 4-10 seconds, then press panic button and release both buttons at the same time.
Do the same procedure to turn the beep back on if you want.
__________________
2010 Jeep Patriot Sport 4x4 Latitude
Black Muffler - Curt Class III Hitch
MyGig RER - Rockford Fosgate Prime 1693 6x9's
20% Tint Front, Factory Tint Rear
Cooper Discoverer AT3 235/65R17
  #9
Old 06-20-2010, 11:53 AM
brubakes's Avatar
Junior Member
I looked into this and you do have to replace the whole instrument panel to get it not worth it unless you get it at a junk yard for cheap.I really wanted the evic also because I can't change my horn on lock or any other setting.It is really annoying for it to honk every time the doors lock plus I would like to see the gas mileage.
Other then the cluster itself what is needed? I'm guessing the outdoor temp sensor is already there since I can get that info from the odometer area. I'm figuring the tire pressure sensors would be needed for sure.
If one went ahead with this and got a hold of a new cluster how can you update the mileage so it's correct and accurate? I know in the case of my Wrangler the mileage is stored in the cluster.
  #10
Old 06-04-2012, 12:45 AM
kerkiraios00 kerkiraios00 is offline
Member
Ride: 07 Blk Patriot Limited 4x4 , 08 BMW E90 M3 IB
kerkiraios00 is on a distinguished road
Hi did you ever get it done? Change the cluster?
__________________
2007 Blk Patriot Limited 4x4 - STUcoils - '16 moab wheels wrapped with 235/70 16 Firestone Destinations A/T
  #11
Old 06-04-2012, 02:25 AM
cmoore's Avatar
cmoore cmoore is offline
an odd member
Ride: 2011 Jeep Patriot 4x4 sport
cmoore has a spectacular aura about
I looked into this a while back. I was informed by jeep( after numerous phone calls and much prodding) that in order to do this I would have to replace the entire wiring harness and add more from the front to the cluster. I have settled with the scangauge II and have been more than happy with it. You can even create the custom background color that matches almost exact to the greenish color that comes in the pat.
Sent from my Autoguide iPhone app
__________________
An Angry Mind is a Narrow Mind
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
