Cannot Shift Out Of Park - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 01-27-2008, 08:53 PM
Sudbury Jeep Sudbury Jeep is offline
Junior Member
Sudbury Jeep is on a distinguished road
Hello!
This is actually my first post here on the forum, but the community here helped in my buying decision. I'm happy to say I'm the owner of a red '07 North Edition Patriot 4x4.
As to my issue, the problem I've encountered is with shifting out of "Park". It doesn't happen all the time and I can't figure out any circumstance that would cause it to happen repeatedly. To solve the problem, I discovered that by lifting the emergency brake and releasing it right away, I can shift without any problems. At first I thought this was a safety feature, so I tried parking with the emergency brake on. This didn't solve the issue. I would put the emergency brake down and the shifter would still seem to be locked (periodically) in "Park". So I would pull the emergency brake up again and release it. Again, this solved the issue.
I'll be going to the dealer to report this problem, but has anyone else experienced this? Any ideas on why the emergency brake would seem to unlock the shifter on those times when it appears to be stuck?
Philip
Sponsored Links
Advertisement
  #2
Old 01-27-2008, 09:05 PM
Gramps Gramps is offline
Senior Member
Gramps will become famous soon enough
Shifting out of Park requires depressing on the brake pedal. There is an interlock switch that's engaged and it may be out of adjustment.
  #3
Old 01-27-2008, 09:08 PM
silvermike's Avatar
silvermike silvermike is offline
Senior Member
Ride: 07 & 14 Patriot, 72 Ford ragtop, 08 Mustang GT
silvermike has a spectacular aura about
Plus of course the ignition needs to be out of "lock".
__________________
2007 - Steel Blue 4x4 Limited 5spd, sunroof, EVIC, tow prep, Draw-Tite hitch.
2014 - Deep Cherry Red Crystal Pearl Sport Altitude, 4X2, 2.0L, CVT2.
  #4
Old 01-27-2008, 09:12 PM
Keeping Fingers Crossed's Avatar
Keeping Fingers Crossed Keeping Fingers Crossed is offline
Senior Member
Ride: Curator of my old Pat, now my Dad's
Keeping Fingers Crossed is on a distinguished road
I have found, that if you start er up, and in a real fast mode, try putting it in gear...Im talking about in like <5 seonds, it won't go. (Tho I don't force it).
After approx 10 seconds it will go..Safety feature perhaps?
  #5
Old 01-28-2008, 06:25 PM
quasimodem51's Avatar
quasimodem51 quasimodem51 is offline
Fossilized Member
Ride: 07 Patriot Limited FDII, CVT2L, NAV, 9 BA
quasimodem51 will become famous soon enough
KFC: I find the same thing if I do not have my foot on the brake. If I put my foot on the brake while in Park, I can then move the shifter out of Park.
__________________
Save the Earth. It is the only one with chocolate.
  #6
Old 01-28-2008, 08:02 PM
Junior Member
Typically, I start the engine and then let it run for a minute or so while I put my seat belt on, etc. So even if I'm not in a rush, the shifter will sometimes lock no matter how hard I press on the brake pedal. I can move it all the way to the right, but not down. Unlike when you're not pressing the brake pedal and the shifter won't move at all. Why enabling and disabling the emergency brake solves this issue, I don't know. But I'll be calling the service dept at the dealership tomorrow to take care of it.
  #7
Old 02-09-2008, 07:38 PM
armybell armybell is offline
Junior Member
Ride: 2007 Patriot Limited 4X4, Inferno Red
armybell is on a distinguished road
Shifting problem
I had the same problem except nothing helped. The first couple times it happened I eventually got it to shift. Then one night I got home, parked in the garage and came out the next morning and had no luck getting out of park. I called jeep and sent out a wrecker to tow me to the dealer. The driver didnt want to drag my patriot out of the garage so he found the manual overide lever. (pop the plug in the passenger side of the shift consol and flip up the white lever) It went to the shop and I dont know what they did but they it wasnt good. They had to replace the entire wiring harness on the passenger side of the vehicle because the plug was broken. How the 'plug' got broken, I dont know but between waiting for the part and them to replace it I waited 8 days. 8 days with no vehicle.
Its funny...when my turn signal on my Grand Cherokee went haywire, the dealer had to replace the entire wiring harness under the vehicle.
  #8
Old 02-10-2008, 01:54 PM
Senior Member
Shift Interlock Cable
The Shifter’s serpentine pattern does not require the shifter to have a button on the knob to release it from “Park”. There is a blocking lever within the Shifter that prevents undesired shifting out of “Park”.
The shifter has a solenoid which is actuated by depressing the brake pedal. This prevents shifting out of “Park” without the brake pedal being depressed. To operate the solenoid, the ignition must be in the “On” or “Run” position and the brake pedal must be depressed. The Brake Switch sends a signal to the Cabin Compartment Node (CCN) and the CCN, in turn, energizes the solenoid that moves the Park Lock Lever to allow the driver to shift out of 'Park”. On the right side of the Console Pod is a plug that allows access to the Park Lock Lever for manual operation.
Symptom: Key is trapped and cannot be removed from the ignition when the Shift Lever is in the “Park” position.
Possible Cause: The Interlock Cable adjustment is not set correctly (spring collapsed too far).
Corrective Action: Check the Interlock Cable Adjustment .
Possible Cause: The Interlock Cable is not secured properly at the shifter housing.
Corrective Action: Be sure the Interlock Cable is properly secured at the shifter housing.
Possible Cause: Shifter housing tab is broken .
Corrective Action: Replace shifter mechanism.
Possible Cause: Interlock Cable routing through the instrument panel area is causing increased friction within the Interlock Cable Housing (bind/kink in Interlock Cable).
Corrective Action: Check the Interlock Cable Housing routing. The Interlock Cable has a clip that locates it to the Instrument Panel structure. The Interlock Cable must be free to move through this clip. The clip is located behind the panel.
Symptom: Key can be removed no matter what position the Shift Lever is in.
Possible Cause: The Interlock Cable adjustment is not set correctly.
Corrective Action: Check the Interlock Cable adjustment .
Corrective Action: Be sure the Interlock Cable is properly secured to the shifter housing.
Possible Cause: Shifter housing tab broken.
Corrective Action: Check the Interlock Cable Housing routing. The Interlock Cable has a clip that locates the Interlock Cable to the Instrument Panel structure. The Interlock Cable must be free to move through this clip. The clip is located behind the panel.
Possible Cause: Interlock cable not secured in Ignition Cylinder.
Corrective Action: Secure Interlock cable in Ignition Cylinder.
Symptom: Shift Lever will not move to the right so that it can be moved out of the “Park” position.
Possible Cause: Brake lamp switch may be mis-adjusted.
Corrective Action: Turn the ignition to the “On” or “Run” position. Brake lamps must be on for the shifter solenoid to receive a signal. If the brake lamps switch is mis-adjusted, the solenoid will not be energized. Replace Brake Lamp Switch.
Possible Cause: No Voltage to Brake lamp switch from 10 amp fuse #3 in TIPM
Corrective Action: Repair circuit or fuse #3.
Possible Cause: Solenoid bushing to Park Lock Lever is out of position or has fallen out.
Corrective Action: If the shifter build date is before 2/1/2006 (located on the label on the rear of the shifter housing) and the solenoid bushing can be located, reinstall the bushing on the solenoid shaft and use a soldering iron, melt the end of the solenoid shaft so that the bushing will not come off of the shaft. Verify the operation of the Park Lock Lever.
If the solenoid bushing cannot be located or the shifter build date is after 2/1/2006, replace the shifter assembly.
Possible Cause: Solenoid is sluggish or hesitant. Low voltage to solenoid. The voltage with key on, engine off, should be at least 10.1 volts. There may be up to a 3 second delay before full voltage is received at the solenoid after the engine is started.
Corrective Action a: Correct the low voltage condition. If the voltage is above 10.1 volts, replace the shifter assembly.
Corrective Action b: Sticky residue around solenoid plunger
Possible Cause: Park Lock Lever on the right side of the sifter is not moving when the brake pedal is depressed.
Corrective Action: Check Park Lock Solenoid operation.
Possible Cause: Park Lock Lever is sluggish and scrapping against the inside of the Shifter Housing.
Corrective Action: Replace the shifter assembly.
Symptom: Shift Lever will move to the right but will not move down toward the “Reverse” position .
Possible Cause: Key Interlock Lever within the shifter is not releasing when the key is turned to the “On” or “Run” positions.
Corrective Action: Check Interlock Cable operation and cable adjustment.
Possible Cause: Interlock Cable is not routed properly.
Corrective Action:Check Interlock Cable routing.
Symptom: Shift Lever can be moved without turning the key on. Possible Cause: Interlock Cable Cartridge not properly installed into the Lock Housing.
Corrective Action: Remove the steering column shroud and check for correct installation of the Interlock Cable Cartridge into the Lock Housing.
Symptom: Shift Lever difficult to pull out of any gear. Possible Cause: Shift Cable not fully seated into the Transmission Bracket.
Corrective Action: Check the Shift Cable installation at the transmission. Be sure both of the Shift Cable Housing locking tabs are fully engaged into the bracket.
Possible Cause: Shift Cable to Transmission Lever nut is loose.
Corrective Action: Tighten the nut to 20 N•m (175 in. lbs.).
Adjustments:
Pry up on cable adjuster lock to release and allow cable to “self-adjust”. Lock cable adjustment by pressing down on the adjuster lock until bottomed at the cable housing
ID:	1531   Click image for larger version
Name:	Shift Interlock.jpg
  #9
Old 02-10-2008, 02:23 PM
jepstr67's Avatar
jepstr67 jepstr67 is offline
POTM November 2008
Ride: 2008, 4x4, FD1, 5 speed. 25D long live vinyl seats
jepstr67 is a jewel in the rough
I'm curious if they have some kind of "safety" (idiot proof) device for manual transmissions as well. I suppose it interfaces with the clutch on the manual. Won't crank if the clutch isn't pressed down.
Just more crap to be mis-aligned and cause problems.
  #10
Old 02-10-2008, 03:28 PM
Senior Member
The Clutch Pedal Safety Switch has been around since the '70's.
  #11
Old 02-11-2008, 02:05 PM
jeepjeepjeep jeepjeepjeep is offline
Junior Member
Ride: 2007 Patriot Sport 4x4 FD1, Black
jeepjeepjeep is on a distinguished road
There is a small circular "tab" on the passenger side near the shifter. If you remove this tab there will be a white lever that you can see. If you press this lever up while the brake is depressed you will be able to shift out of park. This happened to me and it corrected the problem. Let me know if you need any more advice.
  #12
Old 02-12-2008, 04:37 PM
jepstr67's Avatar
POTM November 2008
Quote:
Jeeps manufactured in the (at least the early) 1980's do not have such a device. So even if it has been "around" Jeep did not use it.
  #13
Old 02-12-2008, 05:52 PM
Senior Member
Dodge and Plymouth did in 1970 on the B and E bodies. GM had it in most by the mid '70's. It's nothing new, maybe just new to Jeep. It is the 21st Century. Maybe we should go back to points, plugs, condenser and carburetors, at least for off-road? That suits me fine!
  #14
Old 06-05-2008, 08:20 PM
nacojeep nacojeep is offline
Junior Member
nacojeep is on a distinguished road
Special thanks to Gramps and jeepjeepjeep for their posts on this topic. Couldn't get the shifter out of park today on my wife's Patriot. While waiting for the tow truck, I decided to look online for forum suggestions. Used the "pull tab, move lever" solution to get it rolling without the tow truck, after checking the #3 fuse (brake lights didn't work).
Dealer was impressed that I knew about the "emergency park release switch". They replaced the brake lamp switch; everything ok now.
  #15
Old 06-05-2008, 08:43 PM
Jeepasaurus Tex Jeepasaurus Tex is offline
Senior Member
Ride: '01 Cherokee Sport 4X4 Hell Beast, '08 Patriot 4X2
Jeepasaurus Tex is on a distinguished road
Quote:
The clutch thing has been on every manual I've ever had, but I've never had an old Jeep. I never minded it, and it's never broken on anything I drove.
I was thinking as I was reading this thread though, what a great selling point for a manual tranny!
__________________
"Blow up your TV, throw away your papers, move to the country, and build you a home"- John Prine
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
