Brake change - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 05-10-2010, 10:59 PM
brroland's Avatar
brroland brroland is offline
Junior Member
brroland is on a distinguished road
Send a message via AIM to brroland
Brake change
At what mileage did you have replace your brake pads?? were you able to just put on new pads or did you put on new rotors also?
Sponsored Links
Advertisement
  #2
Old 05-10-2010, 11:34 PM
harold's Avatar
harold harold is offline
Senior Member
Ride: Black 2.0 CRD Sport 2008
harold has a spectacular aura about
if you are asking if pads and discs have a set change time, then they don't
pads and discs are changed as and when needed
a car that does 100,000 k's per year on freeways will have considerably less wear that one that does 20,000 in stop start traffic
is that what you are asking?
the only rule i have, is that if i change the discs (rotors) then i always put on new pads
a lot of brake places will try and get you to machine the discs when it's not necessary
again, my 2c worth
__________________
No More Jeep....
  #3
Old 05-11-2010, 09:21 AM
todde702's Avatar
todde702 todde702 is offline
Senior Member
If the rotors are badly scored or you have a pulsation in the brake pedal (rotor warpage), then you're going to need them either machined or replaced. But when they need to be replaced depends on driving style, brake design, etc. I'm at 37k miles now on mine and I think I'll need new front pads around 40-45k miles. My wifes 2004 GMC Sonoma went 61k miles on the original pads, but GMC put huge pads on them with double piston calipers. My jeeps brakes look like motorcycle parts compared to her truck.
Also, when I did her fronts, I bought all good quality parts. The Bendix OEM pads, and top grade Wagner rotors. They dusted like crazy (I'd have to wash the front rims once a week as they became almost all black), constantly squealed no matter how many times I took them apart and applied anti-squeal and within 30k miles, the rotors and pads were done. This last time I put on the cheapest Advance Auto Parts (Organic Pads and cheap rotors) and they are quiet, stops great and I haven't had to wash the front rims from dusting yet. In fact it's been about 2 months now and the rims still look great.
__________________
-Todd
Quote:
- William Shakespeare
- Anonymous
  #4
Old 05-11-2010, 09:39 AM
tiptronic's Avatar
tiptronic tiptronic is offline
POTM Winner AUG. 09.
Ride: Jaguar X-type 2.5 4x4
tiptronic has a spectacular aura about
Send a message via Skype™ to tiptronic
I've known brake pads to last anywhere between 6,000 & 80,000 miles depends on how you drive & the quality of the components!!!
__________________
Just swapped red Classic X , for, Green Auto SE " Spirit " 2.5 Petrol Limited edition X still 4x4,
Ex 07 Patriot CRD Sport , UK ( with lots of chrome goodies )
  #5
Old 05-11-2010, 01:11 PM
Akula's Avatar
Akula Akula is offline
Senior Member
Ride: 2008 Patriot Limited 4x4
Akula is on a distinguished road
Quote:
Generally, the brake parts designed for superior stopping will wear quickly, dust up more, and may even be noisier. But they'll stop you.
I'm at 47,000 miles, mostly in town but a good chunk highway, and I haven't had to swap out pads yet, but I think I'm getting close. I'll check at my next oil change, and I expect to see them getting close to the squeal tabs.
It's generally a good idea to machine the rotors when you swap out pads- pads and rotors wear together, and if you don't machine the rotors, the new pads will wear a bit faster as they mate to the wear pattern on the rotors.
  #6
Old 05-12-2010, 09:34 AM
todde702's Avatar
Senior Member
Quote:
True, except the box for the Bendix pad stated longer service life, less rotor wear and low dust
Oh well, at least the cheaper ones are working great!
__________________
-Todd
- Anonymous
  #7
Old 05-12-2010, 11:55 AM
kb01 kb01 is offline
Senior Member
kb01 will become famous soon enough
I'm getting close to 70,000 miles on my original brakes. It's mostly highway driving but I've never gotten anywhere close to this kind wear out of brakes in the past. I've normally replaced pads around every 35 or 40k.
  #8
Old 05-12-2010, 09:00 PM
JeepHankins JeepHankins is offline
Senior Member
Ride: 2008 North Edition 2.0L
JeepHankins is on a distinguished road
any one know the wear limit for the drum brake shoes. I have drums on the rear of my pat and the service manual doesn't give a spec it. I'm guessing some where around 1/16"
__________________
  #9
Old 05-12-2010, 11:54 PM
todde702's Avatar
Senior Member
Quote:
Typically 1/32" above the rivet, if they are a riveted pad, or 2/32" (1/16") above the brake pad backing plate for bonded.
__________________
-Todd
- Anonymous
  #10
Old 05-19-2010, 03:46 PM
Senior Member
yeah thats kinda what i figured, thanks todd
__________________
  #11
Old 05-19-2010, 04:52 PM
dixiedawg's Avatar
Senior Member
Ride: 2014, silver, FDII
45,000 miles on mine brakes still good.
My Tracker would go 75,000 miles on the fronts, and believe it or not the rears on that are still original at 175,000 miles.
I do a lot of highway driving.
I had a Buick that would eat front brakes at 12,000-15,000 miles.
__________________
  #12
Old 11-08-2014, 10:16 PM
PatriotRox2008 PatriotRox2008 is offline
Junior Member
Ride: 2008 Jeep Patriot
PatriotRox2008 is on a distinguished road
My Patriot's original brakes lasted 3 years and over 100,000 miles. Highway, backroad, hills, town, etc.
  #13
Old 11-09-2014, 10:28 AM
RossoRacer's Avatar
RossoRacer RossoRacer is offline
Unsponsored Baja racer
Ride: 2010 Jeep Patriot Sport 4x4 "General Lee Jr"
RossoRacer is a jewel in the rough
Lol, way to resurrect an old thread. Mine initially lasted I think maybe 30k on the back, and I replaced the fronts at maybe 35k to be safe. That was just pads, and having the rotors turned. A couple months ago, I replaced pads and rotors in all four corners at about 63k miles, but most of the pads appeared to have nearly half their life left. Just a couple days ago, I learned that rotors come with some coating these days to keep them from rusting while in the packaging, that's supposed to be washed off when they're applied. I didn't know about that, but for some reason they rusted within two weeks of installation. Got some fluid film ordered, gonna clean 'em and spray 'em soon.
__________________
Trekkie, trucker, Jeeper, potential racer. Don't touch my trumpets.
"For God so loved the world that He sent His only begotten Son, that all who believe in him might not perish but have eternal life" -John 3:16
http://www.youtube.com/watch?v=KOb8IEyCO1o
  #14
Old 03-20-2015, 03:24 AM
480KREEPIN's Avatar
480KREEPIN 480KREEPIN is offline
Equal Opportunity Mod
Ride: 2011 dark charcoal pat ,71 k/5 blazer,2006 banshee
480KREEPIN is a jewel in the rough
I know this thread is an old one, but I would like to get more feed back. When did you first have to change your pads? did you need to turn the rotors?
__________________
LONESTAR MK'S/STREET JEEPS
Viper alarm,Kenwood in dash dvd,Pioneer 800 watt amp,Pioneer 12" subwoofer,3m tinted windows,euro shorty antenna,18x8.0"Kmc Rockstar rims,H&r springs,Hankook optimo h727 tires 225/55,Mopar cargo mat,compass shift knob,(jeep) steering wheel cover,vht tail lights & turn signals,avs vent visors,k&n air filter,60 series flowmaster,3.5" flo_pro tip,black pipes,3"nerf bars,cross bars,green led interior,Rugged ridge matts,jeeppatriot stickerlasti-dipped badges & grill
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
