Biggest tires? - Jeep Patriot Forums
Notices
Sponsored by Discount Tire
Reply
Thread Tools Display Modes
  #1
Old 03-09-2010, 03:49 AM
riotman riotman is offline
Junior Member
riotman is on a distinguished road
Biggest tires?
with a 2 and a half or 3 inch lift whats the biggest tires you can get on the patriot i doubt 33's but i was wondering i want to start to mod mine, and would gearing be needed for my riot tank?
thanks
Sponsored Links
Advertisement
  #2
Old 03-09-2010, 04:43 AM
Tony1911's Avatar
Tony1911 Tony1911 is offline
Senior Member
Ride: '07 Jeep Patriot, '88 Ford F-150
Tony1911 will become famous soon enough
You seem to have posted the same question, although with different phrasing, in two separate forums. Not only that but you are asking about a topic that has been discussed over and over again. I am not trying to be deliberately rude here, but seriously - if you really want to know something, using the search feature really is a good idea.
__________________
Ground clearance is not just a single number! There is more to it than distance to lowest point of vehicle.
Want to know something? Do use the search function. No, it doesn't always help, but you miss out on a lot of stuff if you don't try.
  #3
Old 03-09-2010, 09:06 AM
jettore jettore is offline
Senior Member
Ride: 08 FDII
jettore is on a distinguished road
Where are you going to get that lift? Build it yourself? That's where you need to start. You can't just thow out ideas without some research. Figure out the lift issue first, then figure out how large of a tire can fit.
  #4
Old 03-09-2010, 01:24 PM
heckler's Avatar
heckler heckler is offline
Senior Member
Ride: 07 Lifted FDII North; 81 Westy
heckler is a jewel in the rough
i bet you could fit 34's if you had a 4" lift.
__________________
Project Abyss - 07 FDII North, RRO lift, 16X8 Soft 8 with 235/70-16 Grabber AT's, Roof Basket, Procomp 55 roof lights, dash tweeters, 2" hitch, North Shore Rack, K&N drop-in, Hi-lift, Procomp 55 driving lights
  #5
Old 03-09-2010, 02:52 PM
prank213's Avatar
prank213 prank213 is offline
Senior Member
Ride: jeep patriot
prank213 is on a distinguished road
Send a message via AIM to prank213 Send a message via MSN to prank213 Send a message via Yahoo to prank213
simple question simple answer.......... you could go with 245-75-r16 or you could go with 30x9.50xR15..
i'm planning on going for 30x9.5xr15 because the tire is less expensive then any 16 inch tire
  #6
Old 03-09-2010, 04:26 PM
Junior Member
cool thanks for the reply's i see the forum links, sry for being a noob to the forums, but i get excited about my patriot! lol : D
  #7
Old 03-09-2010, 04:34 PM
heckler's Avatar
Senior Member
reality check - it's not a tank, and never will be.
but it'll get you way further than any other cute-ute out there.
__________________
  #8
Old 03-10-2010, 12:11 AM
AertepT's Avatar
AertepT AertepT is offline
Junior Member
Ride: 2008 Patriot FD1
AertepT is on a distinguished road
I just put 245/70-16's under mine. They have a 29 1/2" dia. I have a slight rub on the pinch-welds on the front. They only rub when you lock it over. Other than that though, it's pretty good. A friend of mine is going to hammer down the pinch welds for me and heat up the fender liner to hammer it flat. Should be good to go after that.
  #9
Old 03-12-2010, 06:28 AM
cooluks cooluks is offline
Banned
cooluks is on a distinguished road
Quote:
Definitely. You must match the size of your tires to the lift of your car. Because if it is not match there will probably some error will occur and it is not nice to look at.
  #10
Old 03-20-2010, 08:38 PM
patroit07 patroit07 is offline
Senior Member
Ride: Jeep Patriot 2009
patroit07 is on a distinguished road
Stop complaining about the search feature tony 1911 it is old news and you are beating a very dead horse just leave it alone otherwise complain to Joe Becker about it like you always do. ENOUGH
  #11
Old 05-19-2015, 02:22 PM
WhytPatriot's Avatar
WhytPatriot WhytPatriot is offline
Junior Member
WhytPatriot is on a distinguished road
Is that with the RRO lift???
  #12
Old 05-19-2015, 03:35 PM
rcguymike's Avatar
rcguymike rcguymike is offline
Senior Member
Ride: 13 MK Sport 4x4 FDI | 96 5.2L ZJ<-parts? | 99 XJ
rcguymike is a jewel in the rough
Quote:
Stu's would most likely be a similar story but you would probably rub at full compression. Those are really the largest tires that fit the wheel well under any sort of compression. I tried a friends 31x10.5's and I couldn't even steer without rubbing and that was with it still on jack stands.
__________________
Grand Build Thead | JP Build Thread
  #13
Old 05-19-2015, 04:44 PM
Sandstone's Avatar
Sandstone Sandstone is offline
Senior Member
Ride: 2010.5 Latitude Sport FDII Sun/Sound, No leaks
Sandstone is a jewel in the rough
I had 30x9.5x15 on mine before installing StuCoils. They rubbed slightly on the passenger side wheel well at full right lock, but not on the pinch welds. A different rim with a little less offset would have probably taken care of it.
__________________
15" Ravine Rims, 235/75/15 Duratracs, CRDSTU coils, JKS Quicker Disconnects, Airbox Baffle Mod., Midland 822 CB w/ 2' Firestik II, Weathertec floor liners.
  #14
Old 05-19-2015, 10:34 PM
pnshr7's Avatar
pnshr7 pnshr7 is offline
Senior Member
Ride: '12 Patriot 4x4 white lifted and blacked out
pnshr7 will become famous soon enough
I've got 245/65/17 with no rub wish I had test fitted 70s
__________________
'12 44 2" lift 17" rubicon rims blacked out wrapped in 245/65s grabbers blacked out tail lights flasher grill and hood baja lights 2" hitch and curt roof basket
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
