Changing / Replacing Spark Plugs - Jeep Patriot Forums
Notices
Maintenance General maintenance articles for the Patriot.
Click for instructions on how to post an article in the Knowledge Base
Reply
Thread Tools Display Modes
  #1
Old 03-03-2010, 02:23 PM
clear_star82 clear_star82 is offline
Junior Member
Ride: 2007 Jeep Patriot Limited and 1984 Jeep CJ7
clear_star82 is on a distinguished road
Spark plugs used, as annotated on underside of hood:
Engine Cover must be taken off by applying pressure to the underside of the cover in the four corners, to disengage the male/female connectors:
Female on underside of engine cover:
Male off of engine block:
I used a 3/8" drive, T30 socket to unscrew the bolt that is at the left top corner of each spark plug hole:
Shown here:
Bolt easily removes, x4
Unfasten wiring harness by grasping top and bottom sides to release latch:
Remove individual ignition modules x 4:
Spark plug can be seen at the bottom:
Use a spark plug specific socket that's 5/8" hex. The spark plug specific socket has a rubber grommet on the inside that holds the spark plug to the socket so you can take it out of tight corners (without having to use a magnetic grabber) and also helps for insertion by holding it in place thereby helping you not to cross-thread:
I also had to use a 6" extension:
Even after only 30K miles and 1.5 years, mine shown quite a bit of wear:
If you use spark plugs with metal gaskets, turn to tighten 1/4 to 1/2 turn past contact. I would hand-turn on until contact then use the socket driver after that point. That way you are ensuring no cross-thread AND can tell easily when the gasket makes contact.
Enjoy! I this helps
Sponsored Links
Advertisement
  #2
Old 05-20-2010, 11:46 AM
mav0016's Avatar
mav0016 mav0016 is offline
Senior Member
mav0016 will become famous soon enough
I just did mine last night, it took 20 minutes, easier than an oil change!
__________________
08 Patriot inferno red, North Edition 4x4 Lifted RR
Ottawa, Canada
  #3
Old 08-10-2010, 01:30 PM
Harbor's Avatar
Harbor Harbor is offline
Senior Member
Ride: '15 Grand Cherokee, '14 Challenger & '07 Crossfire
Harbor will become famous soon enough
clear star82 - Thanks for posting this pictorial. Your instructions were spot on, and I was able to change the plugs on my daughter's Pat yesterday in approx 20 minutes.
Car idles a lot smoother, and we'll be checking the MPGs over the next few weeks.
At 22K, the old plugs looked beat, and interestingly, the gap in the plugs from cylinders #3 & 4 was above .055". Either factory variance when installed or something with the engine. It does see a lot of highway use.
Thanks again and cheers.
__________________
'14 Black Limited
  #4
Old 08-10-2010, 06:29 PM
Ignatz's Avatar
Ignatz Ignatz is offline
Senior Member
Ride: 2008 Patriot 4x2 2.4 CVT
Ignatz is a glorious beacon of light
I checked the gap on mine when I took them out and they weren't that far off, but they were a couple thousands either way.
  #5
Old 11-10-2010, 12:55 PM
Souldeep Souldeep is offline
Junior Member
Ride: Patriot 08 Sport 2.4
Souldeep is on a distinguished road
Very nice and useful post, this provoke save time and money!!
  #6
Old 11-11-2010, 02:13 AM
JeepHankins JeepHankins is offline
Senior Member
Ride: 2008 North Edition 2.0L
JeepHankins is on a distinguished road
I just changed my plugs. It was the easiest tuneup ever!
__________________
  #7
Old 03-13-2011, 09:09 PM
duramax08 duramax08 is offline
Junior Member
duramax08 is on a distinguished road
Whats the gap on a 08' 2.0? The same?
  #8
Old 03-13-2011, 09:45 PM
festerw festerw is offline
Senior Member
festerw will become famous soon enough
Only changes I can suggest would be to use anti-seize on the plug threads, dielectric grease in the boot connection and torque the plugs.
__________________
2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
2011 Dodge Durango Crew
  #9
Old 03-17-2011, 11:40 PM
Junior Member
Quote:
I would imagine very similar, but I would check on the underside of the hood, there should be a sticker towards the latch.
  #10
Old 03-31-2011, 04:31 AM
ozie2012 ozie2012 is offline
Member
ozie2012 is on a distinguished road
Quote:
I thought changing spark plugs would took me hours to do it, but it was so easy following your steps. That was a job well done!
  #11
Old 12-16-2011, 08:09 PM
rjenn4404 rjenn4404 is offline
Junior Member
rjenn4404 is on a distinguished road
no sticker under hood. what size plugs?
  #12
Old 12-17-2011, 12:19 PM
Junior Member
Crap, sorry guys, the pictures are now gone. They were uploaded to a website folder that I no longer maintain. Sorry for the short life, I'll attempt to take more pictures soon, when I get back from deployment, and can upload them
  #13
Old 12-17-2011, 12:24 PM
Junior Member
Quote:
One of the pictures, that used to be posted, clearly showed the size of the plugs. Sorry buddy. The auto parts store where you buy your plugs should be able to direct you appropriately
  #14
Old 12-17-2011, 08:50 PM
BarryB's Avatar
BarryB BarryB is offline
Senior Member
Ride: 2008 Jeep Patriot, Limited 4x4, 5spd
BarryB will become famous soon enough
It should be listed in the back section of your owner's manual. For the 2008, it is ZFR5F-11 (Gap 0.043).
  #15
Old 12-17-2011, 08:55 PM
miketmx's Avatar
miketmx miketmx is offline
Senior Member
Ride: 2015 Patriot North 4X4 FD1 6 Speed Auto
miketmx is on a distinguished road
All the pictures are shown on this Knowledge Base thread:
http://www.jeeppatriot.com/forum/showthread.php?t=36996
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
