Sunroof / Leak Question, Comment - Jeep Patriot Forums
Notices
Exterior Exterior questions and modifications.
Guards, rails, armor, racks, mounts, etc
Reply
Thread Tools Display Modes
  #1
Old 02-19-2010, 11:08 AM
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxTater1800 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxTater1800 is offline
Guest
Ride: 2010 White Patriot Sport 4X2 W/5spd
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxTater1800 is on a distinguished road
I noticed my sunroof leaking during heavy rain. I was concerned until the design was examined. I have never had a sunroof so an education was needed. It is simple mathmatics from what I see. If the drains keep up with the leak then there should not be a problem. That being said, the gasket must be in good condition. I don't expect a perfect seal as this would make the sunroof difficult to open/close.
The trick seems to be preventative maintenance. When the drains become clogged, and they will, leaking into the interior will become a problem. I plan to clean the drains during routine maintenance. Weed trimmer line should do nicely for snakeing out the drains. If I am missing something, please comment.
Sponsored Links
Advertisement
  #2
Old 02-20-2010, 01:14 AM
whitegt01 whitegt01 is offline
Senior Member
Ride: Acura 03RSX/ 09TSX, 08 Honda Fit.
whitegt01 is on a distinguished road
its not your job to clean the drain or unclog anything....
its a fundamental flaw, and there is no fixing it, and there is no solution. whatever you do will be temp., and then it will leak again... jeep doesn't admit, and they fail to stand behind their product, just like their dealers.
i have owned more than 5 cars over more than 2 decades, never had an issue with any sunroof/moonroof, anything...
i opened my sunroof maybe 3 or 4 times in a year, how does it become clogged??? i have 3 cars with sunroofs now, no issues! they sit outside in the driveway 365 days a year. NO ISSUES. its your jeep, plain and simple.
__________________
:what happens if you buy a patriot:
2008 brilliant black 4x2 sport (26E, sunroof, wheel and tire, all season mats). added-wheel locks, and molded splash guard set, led interior bulbs(all), 5k HIDs bi-xenon...and water leaks in front dome, mid-dome, rear dome, a-pillar, front windshield. (Get rid of it ASAP, peace of mind from not having a river flowing in your car is priceless).
  #3
Old 02-20-2010, 11:46 PM
Afmcronnie's Avatar
Senior Member
Ride: 2013 Wrangler. Owned 2 Patriots.
Quote:
Then whose job is it? If leaves or dirt get in the drain it's the dealers job to clean them out? Your Pat had a problem with the sunroof, mine doesn't. Some do, lots don't. You got rid of it, I'm keeping mine. I'm sorry you had a bad experience, but, frankly, your ceaseless complaining doesn't help anyone to solve their problems. I think this idea about using a line to clean out the drain periodically is a great idea! All the posts I've read on this subject, this is the first to suggest some constructive preventative maintenance.
__________________
  #4
Old 02-21-2010, 11:17 AM
BarryB's Avatar
BarryB BarryB is offline
Senior Member
Ride: 2008 Jeep Patriot, Limited 4x4, 5spd
BarryB will become famous soon enough
Mine leaked slightly after a hard rain when it was brand new - took it to the dealer and the leak specialist fixed it in one try. Dry as a bone ever since and we get a lot of rain (and snow).
  #5
Old 02-21-2010, 12:58 PM
Guest
Quote:
I tried my solution. The front drains bottom out about a foot in. I can't tell what the line hits but that is likely all there is. I suspect the drain goes to the gutter. There are two drains visible from the rear door, near the top. I can put about 4 feet of line into these before they bottom out. I suspect these start at the rear of the sunroof.
  #6
Old 02-21-2010, 11:51 PM
Afmcronnie's Avatar
Senior Member
Following that line of thought, I wonder if using low pressure air would blow it out? In the parts manual, fig. 60-1005, it lists 4 drains, 2 front and 2 rear. It doesnt really show where they terminate. They do seem to be 1 piece hoses. It may be possible to blow them out. They also look to have a valve or fitting of some sort on the downstream end. Did you see any of that?
__________________
  #7
Old 02-22-2010, 08:28 AM
Guest
I had that thought as well. I didn't see any fitting or valve.
  #8
Old 02-26-2010, 08:48 PM
joelbird joelbird is offline
Member
Ride: 09 limited sun burst orange patriot FD II auto
joelbird is on a distinguished road
big problem with cleaning the drain tubes. the hangers for the tubes do not work well on SOME. search and see in the forums. if you jam something down them you can dislodge the tub causing a low point to fill with water. hit the brakes, the water rushes forward over flows gasket and enters cabin. This problem has been state by another member also, she stated that her dogs were in the cargo area and the dealer said a hit to the roof liner can cause the tube to "sag". Mine were sagging from the factory. Had mine fixed, no more leaks during braking.
just be careful what you do to "clean" them. jeep never intended them to be cleaned out by an ower. don't void your warranty by doing something stupid......
  #9
Old 02-26-2010, 09:43 PM
coryconklin coryconklin is offline
Senior Member
Ride: 2009 Jeep Patriot Sport 4x2
coryconklin is on a distinguished road
Mine leaked during the first hard rain after I purchased it. The dealer blew out the drain lines (there are four of them as mentioned earlier) and I have not had any issues since (and there have been many downpours since). Mine also sits outside in my drive way 24/7 and I have put 17,000 miles on it in 7 months which indludes open the sun roof numerous times with no issues.
__________________
2009 Patriot Sport Deep Water Blue Sun & Sound Group, Black Steel Wheel Covers, Chrome Mirror & Handle Covers, Hella Fog Lights, K&N CAI, Valley Roof Basket with Extension!!
  #10
Old 02-27-2010, 10:02 PM
patroit07 patroit07 is offline
Senior Member
Ride: Jeep Patriot 2009
patroit07 is on a distinguished road
I have the answer for sunroof leaking problem Buy a jeep with no sunroof.
  #11
Old 02-28-2010, 05:15 PM
1st Jeep 4Me's Avatar
1st Jeep 4Me 1st Jeep 4Me is offline
Senior Member
Ride: Was '08 Silver LTD 4X4, Loaded, CVT II Auto Stick
1st Jeep 4Me is on a distinguished road
Check this out: http://www.telusplanet.net/~homac/Je...0Detection.pdf
__________________
Gary
"The sun don't shine on the same dog's butt every day'"
  #12
Old 02-28-2010, 10:32 PM
roberttroll roberttroll is offline
Senior Member
roberttroll is on a distinguished road
This is the thread you want to print out and keep -
http://www.jeepforum.com/forum/f98/l...91/index2.html
It shows everything you need to know about sunroof leaks.
  #13
Old 02-28-2010, 11:30 PM
nosirrahg's Avatar
nosirrahg nosirrahg is offline
Senior Member
Ride: '08 khaki Patriot Sport 2WD/'80 El Camino
nosirrahg is on a distinguished road
Quote:
That's what I thought, but I've got an '08 without a sunroof and I still have a leak somewhere...maybe not the roof, but around one of the doors. I've had it fixed once by the dealer, but the problem has returned after a couple years. It's not as bad as what I've seen with the sunroofs, but I do have water collect behind the driver's seat at times after very heavy rains (which we had many of this past year).
  #14
Old 03-02-2010, 10:24 AM
Senior Member
If you notice the leak detection pdf I posted above you'll see the leaks are not limited to sunroof cars.
__________________
Gary
  #15
Old 03-02-2010, 11:51 PM
homac's Avatar
homac homac is offline
Senior Member
Ride: 2008 Jeep Patriot North
homac will become famous soon enough
Good link. I also like how the one person is escalating their issue. If more folks followed the process that is already there to protect them we would have far less issues.
__________________
POTM July 2008 & December 2009
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
