Replacing headlight bulbs - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 02-02-2010, 07:06 PM
tinkwantsajeep tinkwantsajeep is offline
Member
tinkwantsajeep is on a distinguished road
I have a burnt out headlight (just the low beam) and I bought the replacement bulbs but after about 10 minutes of trying I still can't manage to get the old one out of there What am I missing? Any tips, tricks, ideas?
Sponsored Links
Advertisement
  #2
Old 02-02-2010, 10:40 PM
blitzbuggy's Avatar
blitzbuggy blitzbuggy is offline
Senior Member
Ride: 2008 jeep patriot 4x4 5 speed/Yamaha BWS
blitzbuggy is on a distinguished road
twist the cap off the bulb, then pull the tab off the back of the bulb
__________________
Suck,Squeeze,Bang,Blow. Repeat
  #3
Old 02-02-2010, 11:44 PM
sandman_qc sandman_qc is offline
Junior Member
sandman_qc is on a distinguished road
I had the same problem as you a couple of months ago... Tried for an hour or so... Had to go to the dealer to see how to do it... Man! I felt dumb...
Anyway, there's some kind of a slider that you have to move AND (that's the part I was missing) a small button you have to push (near the bottom of the socket) when pulling the light off. Easy enough when you know what to do!
  #4
Old 02-03-2010, 03:24 AM
Tony1911's Avatar
Tony1911 Tony1911 is offline
Senior Member
Ride: '07 Jeep Patriot, '88 Ford F-150
Tony1911 will become famous soon enough
There are two different kinds of connectors. One that you are, I think, supposed to just pull off (just a guess - mine has always been way too stiff to do that) and the one sandman talks about. The mechanism that holds the bulb in place might also vary - I have a latch that folds over the back of the bulb, not something with a button.
The way I change my bulbs: first I pull the rubber cap back; then I release the latch that holds the bulb in place and fold it back; pull the bulb out still connected, and remove it from the connector using both hands (told you, that thing is pretty stiff). Place the rubber cap on the new bulb, pull it back and assemble in reverse order. The part that holds the bulb in place can be a little fiddly and annoying at times, especially when it is really cold, but that may just be because I'm left-handed (at least the left bulb is kind of difficult to get out using ones left hand, and my right is kind of clumsy especially when frozen solid).
Not a clue if that's the right way to do it, as the manual claims the mechanism should be something totally different.
__________________
Ground clearance is not just a single number! There is more to it than distance to lowest point of vehicle.
Want to know something? Do use the search function. No, it doesn't always help, but you miss out on a lot of stuff if you don't try.
  #5
Old 02-03-2010, 09:55 PM
BarryB's Avatar
BarryB BarryB is offline
Senior Member
Ride: 2008 Jeep Patriot, Limited 4x4, 5spd
BarryB will become famous soon enough
Mine were like sandman's description - easiest bulbs I have ever replaced. I burn mine all the time so I have replaced several. Upgraded both last month to higher intensity and was surprised how much of a difference it made. Got them on sale so two were not much more than a single standard replacement.
  #6
Old 02-03-2010, 10:28 PM
Dawson's Avatar
Dawson Dawson is offline
Off Road Enthusiast
Ride: '88 Dodge Raider
Dawson is on a distinguished road
Send a message via AIM to Dawson
Quote:
Why are you going through them so often? Both mine lasted about 36k miles. You aren't touching the glass of the lamp when you change them, are you?
The only time I've ever bought expensive lamps was my old Subaru. Won't do that again! I personally find the standard Sylvania's (at $15 each) to be quite sufficient. My Raider's sealed beam lamps are terrible!
__________________
Used to have: '07 Patriot Sport FDII
Trail Rated + Trail Damage = Trail Proven
Cobra 75-WX-ST CB Radio, Garmin Nuvi 205 Nav.
In The Pic:
Robert.Zearing, Dadunkindude, Dawson
  #7
Old 02-03-2010, 11:05 PM
Vultite Vultite is offline
Senior Member
Ride: 07 Jeep Patriot
Vultite is on a distinguished road
anyone know the life of the silverstars? I heard they are brighter but don't last as long as standard lights...
__________________
07 Silver Pat, 2.4L 5-speed manual,leather and power package,17" Yoko Geolander A/T-S, 14" Black Billet stubby antenna, Curt Class III Hitch, black muffler mod, Hella Optilux 2500's,and more to come...
  #8
Old 02-04-2010, 12:50 AM
davecanuck's Avatar
davecanuck davecanuck is offline
Level 3 Supporter
Ride: 09DWBlue 4x4 North
davecanuck will become famous soon enough
1. Disconnect and isolate the battery negative cable.
2. Disconnect the engine compartment wire harness connector from the connector receptacle integral to the headlamp bulb base (3) on the back of the headlamp unit housing (1).
3. Using the tabs on each side of the connector receptacle, firmly grasp the bulb base and rotate it counterclockwise about 30 degrees to unlock it.
4. Pull the bulb and base straight out from the keyed opening in the headlamp reflector (2).
I did not copy the picture from the service manual but you get the idea.
__________________
2009 Deep Water Blue, Patriot "North" (E), 4x4 FDI, Security & Cargo Grp, Jeep window vents/hood deflector, 17" wheels (Firestones), Synthetic oil, homemade cabin a-filter, forum/bumper/3light decal, black muffler mod (life to date 22.9 MPusG - 34000Km)
  #9
Old 02-04-2010, 08:30 PM
BarryB's Avatar
Senior Member
I have over 54K on my Pat. Two have burned out so far.
  #10
Old 02-04-2010, 09:48 PM
Broccoli Iglesias Broccoli Iglesias is offline
Senior Member
Broccoli Iglesias is on a distinguished road
you wouldnt be having this problem if the patriot had a REAL owners manual.
  #11
Old 02-05-2010, 12:48 AM
davecanuck's Avatar
Level 3 Supporter
Broccoli - patience my friend, my previous vehicles (Big 3) never had that type of stuff in an owners manual, i have always had to buy a Chilton's or similar. Even if you don't do the detailed work yourself (not the lightbulb thing) it is nice to understand what is going on.
For example, getting to the fog lamps is a total pain in the ___ on the Pat.
__________________
  #12
Old 02-05-2010, 03:43 AM
Tony1911's Avatar
Senior Member
The owners manual of the Patriot is far, far more informative than what a lot of new vehicles have. It could use major editing by someone who really understands the differences between different models of the vehicle (including export models!), but the amount of information exceeds most owners manuals today.
__________________
  #13
Old 02-05-2010, 08:39 AM
Krakrak Krakrak is offline
Junior Member
Ride: a POS for now
Krakrak is on a distinguished road
I have the PDF version of the owner's manual and there are step by step instructions with pictures from page 398 to 400.
1. Raise the hood and locate the connector behind the headlight
2. Reach into engine compartment and pull red lock out at connector.
3. Remove the green connector from the back of the bulb by pulling straight back.
4. Twist the bulb to the left.
5. Pull bulb outward from assembly.
  #14
Old 02-05-2010, 11:11 AM
davecanuck's Avatar
Level 3 Supporter
Krakrak - good catch, that is why we should always go back to the owners manual to remind ourselves of a few things.
__________________
  #15
Old 02-06-2010, 09:11 PM
1st Jeep 4Me's Avatar
1st Jeep 4Me 1st Jeep 4Me is offline
Senior Member
Ride: Was '08 Silver LTD 4X4, Loaded, CVT II Auto Stick
1st Jeep 4Me is on a distinguished road
Quote:
Let's just say their motto should be "Lots of light, very short life". Go with Philips Extreme Ultras instead.
__________________
Gary
"The sun don't shine on the same dog's butt every day'"
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
