How to Reset Chage Oil (w/o EVOC) - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 10-22-2007, 02:57 PM
mike mike is offline
Junior Member
Ride: Jeep Patriot
mike is on a distinguished road
Hello I have a ‘08 Jeep Pat, and had the first oil change done at the dealership and they did not reset the change oil indictor on the dash. I have an owner’s manual but it is in the safety deposit box and did not want to have to go get it or wait 3 hours at the dealership to reset my computer. Can anyone tell me how to reset the change oil?
Sponsored Links
Advertisement
  #2
Old 10-22-2007, 04:13 PM
nearly.normal.jimmy's Avatar
nearly.normal.jimmy nearly.normal.jimmy is offline
Senior Member
Ride: Discovery One
nearly.normal.jimmy will become famous soon enough
You keep your owner's manual in a safety deposit box?
And I did not even know their was a change oil light....
__________________
Home Grown Patriot Info Site<--clicky
Before: 4x2, 2.4L, 26F, CVTII, Sirius, Single CD
After: Nav Radio, Sunroof, Front Plate Holder, Rear Reading Light, Front Tint, Splash Guards,
Front Air Deflector, iPod integration, Pioneer 6982 6"x9",Infinity 10.7t tweeters, ScanGaugeII,
Billet Antenna, K&N Air Filter, Side Air Deflectors (removed)
  #3
Old 10-22-2007, 05:11 PM
Brett Brett is offline
Senior Member
Ride: 01 Honda S2000, 99 Honda Civic, 07 Jeep Patriot
Brett is on a distinguished road
I wasn't aware of the feature on the 2008 models, either. I was hoping it wasn't your oil pressure light!!!
From the manual (available from www.jeep.com under "for owners"):
Engine Oil Change Indicator System
Oil Change Required
Your vehicle is equipped with an engine oil change indicator system. The “Oil Change Required” message will flash in the EVIC display for approximately 10 seconds after a single chime has sounded to indicate the next scheduled oil change interval. The engine oil change indicator system is duty cycle based, which means the engine oil change interval may fluctuate dependent upon your personal driving style.
Unless reset, this message will continue to display each time you turn the ignition switch to the ON/RUN position. To turn off the message temporarily, press and release the Trip Odometer button on the instrument cluster. To reset the oil change indicator system (after performing the scheduled maintenance) refer to the following procedure.
1. Turn the ignition switch to the ON position (Do not start the engine).
2. Fully depress the accelerator pedal slowly three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you start the vehicle, the oil change indicator system did not reset. If necessary repeat this procedure.
  #4
Old 10-22-2007, 05:53 PM
Junior Member
Ride: Jeep Patriot
thank you
I did not mean to put in there, but when I put all the paper work toghter just put in with it and forgot to take it out. so now that is were it sets. Thank you for the info.
  #5
Old 10-22-2007, 06:43 PM
AZCycle's Avatar
AZCycle AZCycle is offline
Senior Member
Ride: 07 Inferno Red FWD CVT, 1965 Ford Mustang, 289V8
AZCycle is on a distinguished road
I'm confused. Is this a new option for 08's with the EVIC or do 07s have it as well?
__________________
  #6
Old 03-31-2008, 04:22 PM
FLUFFY BEAR FLUFFY BEAR is offline
Junior Member
Ride: 08 Pat, CVT, 2.4, fwd - Orange
FLUFFY BEAR is on a distinguished road
Mine came on this morning for the first time
I don't have the digital display with the mpg device
It shows up where on the odometer
2,500 miles on the Patriot so far
Light seems early to me
  #7
Old 04-01-2008, 04:07 AM
blitzbuggy's Avatar
blitzbuggy blitzbuggy is offline
Senior Member
Ride: 2008 jeep patriot 4x4 5 speed/Yamaha BWS
blitzbuggy is on a distinguished road
mine was like that to, the manual states 10000 KMS( in canada) between oilchanges, and it also takes in to consideration the temperatures , driving style, and city/highway stuff to. as so i am told from my service advisor.
  #8
Old 04-22-2008, 02:49 PM
Schoat333 Schoat333 is offline
Senior Member
Ride: Accord
Schoat333 will become famous soon enough
I just turned over 2500 miles and the very next time i turned the car on guess what. Ding Ding Ding oil change required. Seems like chrysler programmed them to come on at 2500 miles automatically. Wonder why they advertise 6000 miles in the owners manual then?
  #9
Old 04-22-2008, 04:04 PM
ben ben is offline
Senior Member
Ride: 2007 Patriot Sport 4X2, 2.4L w/ CVT
ben is on a distinguished road
Is this light just an 08 option?
__________________
  #10
Old 04-22-2008, 04:13 PM
Senior Member
Ride: Accord
Quote:
i believe it is. anyone know for sure?
  #11
Old 04-22-2008, 04:44 PM
MrSensible MrSensible is offline
Senior Member
Ride: 08 Sport 4x4, 5spd
MrSensible is on a distinguished road
Fromwhat I heard it's not just programmed for miles. There is a quality monitoring system associated with it as well. I believe and my dealer confirmed it is set to 6000 miles since last reset OR oil quality limits are reached.
Mine first came on at 6000 and every 6000 since resets. I have not seen it come on when it wasn't near intervals of 6000.
  #12
Old 04-22-2008, 05:01 PM
Senior Member
Ride: Accord
Interesting. I wonder how the oil quality is determined? Do you drive mostly city, or highway?
  #13
Old 09-21-2008, 05:34 PM
flattop's Avatar
flattop flattop is offline
Member
flattop is on a distinguished road
Mine came on at 5,600 miles. Thanks for the turn off info. It was getting annoying.
__________________
'08 Patriot 4x4, 2.4L, 5 speed, jeep green, e pkg w/ yes fabric, towing pkg, side air bags, K&N air filter, E3 plugs.
  #14
Old 09-21-2008, 11:52 PM
Weatherman's Avatar
Weatherman Weatherman is offline
Patriot Crash Test Dummy
Ride: 2011 Brilliant Black Riot & 1994 Z28(Green Mamba)
Weatherman will become famous soon enough
Send a message via Yahoo to Weatherman
Its a standard feature for all 08's. Mine is bone stock "D" package with no options and it has an oil change light that I have to reset myself everytime because the waterheads at the dealer never do it when they change the oil.
__________________
"Reno's alot like Mayberry on TV, except everyone's on crystal meth and prostitutions legal."
-Deputy Travis Junior-
My 2008 Patriot saved my life! R.I.P. "Das Jeepin' Wagon" You will be missed.
  #15
Old 10-27-2008, 03:45 PM
firemothjoe's Avatar
firemothjoe firemothjoe is offline
A True Straight Shooter
Ride: 08 Patriot Sport Black-Crystal 2.4L CVT2 4x4
firemothjoe will become famous soon enough
That did the trick! Thanks Brett!
The "master mechanic" at my dealer once told me that the Patriot detects whether the oil is too dirty and then the light comes on automatically, what a load!
__________________
-Joe
Find me on facebook.com/firemothjoe
Give your JP.com screen name so I can recognize you.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
