Rear Break squeak - Jeep Patriot Forums
Notices
Sponsored by Discount Tire
Reply
Thread Tools Display Modes
  #1
Old 01-13-2010, 11:19 PM
blackscpatriot's Avatar
blackscpatriot blackscpatriot is offline
Member
Ride: 2009 Jeep patriot Sport 4x2 5spd
blackscpatriot is on a distinguished road
Rear Break squeak
Everytime I let off of the brake pedal I hear a very annoying squeaking noise coming from the rear brakes. Has anyone else had this problem? I have asked 2 different dealerships and both say its "normal" and its the design of the brakes. Any ideas?
__________________
Correct me if im wrong, but I thought the water is supposed to stay outside the jeep?
Sponsored Links
Advertisement
  #2
Old 01-14-2010, 02:05 AM
homac's Avatar
homac homac is offline
Senior Member
Ride: 2008 Jeep Patriot North
homac will become famous soon enough
Squeeky brakes are sometimes just because of the metallic pads or oxidation on the discs themelves.
Anything significantly loud, pulling to one side or shuttering should be checked straight away. In some cases a visual check can be made as you can see the discs yourself.
Some shops will check them for free if you do some investigating (i.e. in the hopes if you do need servicing they will get your business)
__________________
POTM July 2008 & December 2009
  #3
Old 01-14-2010, 02:17 AM
Weatherman's Avatar
Weatherman Weatherman is offline
Patriot Crash Test Dummy
Ride: 2011 Brilliant Black Riot & 1994 Z28(Green Mamba)
Weatherman will become famous soon enough
Send a message via Yahoo to Weatherman
From what Ive witnessed so far, it works like this.
If your vehicle is under 36,000 miles:
Any and all noises, broken or missing parts, small fires, leaks, or mythological creatures inhabiting your vehicle are perfectly normal and are just part of the "design."
If your vehicle is over 36,000 miles:
Any of the above are serious issues which require immediate service action to avoid endangering and possibly killing you and your entire family and will cost no less than $1,000 per occurence. Unless said issue is related to drivetrain, in which case it is perfectly normal and just a part of the "design."
-Information taken directly from the "How to handle a customer's complaints regarding service" flowchart which can be found behind the desk at Hall Chrysler Dodge Jeep, Virginia Beach VA.
__________________
"Reno's alot like Mayberry on TV, except everyone's on crystal meth and prostitutions legal."
-Deputy Travis Junior-
My 2008 Patriot saved my life! R.I.P. "Das Jeepin' Wagon" You will be missed.
  #4
Old 01-14-2010, 09:57 AM
neamih's Avatar
neamih neamih is offline
Member
Ride: 2007 Jeep Patriot 2.0 CRD
neamih is on a distinguished road
tell us more about
is this sound appear and disappear when you are riding slow and brake? is it a continuous noise or intermitent one? pushing or not the brake pedal?
i had a broken disc on the left rear wheel
at the beginig verry small noise and in time became big, and i had to change the disc (brake rotor)
  #5
Old 01-14-2010, 10:25 AM
bigbadgreygoose's Avatar
bigbadgreygoose bigbadgreygoose is offline
Senior Member
Ride: 2009 Patriot North 4x4 FD1
bigbadgreygoose is on a distinguished road
first question first....
Rear discs or drums???
__________________
2009 Patriot North 4x4, 26E-FD1, North Plus, Tire & Wheel, Trailer Hitch
  #6
Old 01-14-2010, 10:29 AM
Ignatz's Avatar
Ignatz Ignatz is offline
Senior Member
Ride: 2008 Patriot 4x2 2.4 CVT
Ignatz is a glorious beacon of light
When I brake hard (rarely) my rears squeak, but I think its because the rears don't get used much and rust & dust accumulate in there . . . then when they're really firmly contacted, Squeeek! That's an appropriate noise for a vehicle named Ignatz, isn't it?
  #7
Old 01-14-2010, 01:22 PM
psaulesl's Avatar
psaulesl psaulesl is offline
Senior Member
Ride: '07 Patriot 4x4 North;FD1 CVT;Lots of Mods and Mud
psaulesl is on a distinguished road
My handbrake (drum in hat, rear main brakes are the disc portion) squeaks a bit if I drag it at low speed.
I had a warrany problem with a recurring stuck parking brake cable last year (there was water freezing in a cable). I cooked my parking brake shoes as a result of it being partially stuck. I recall having a squeaking problem at the time. Ultimately I ended up having most of it replaced under warranty.
__________________
2007 Jeep Patriot 4x4 North FD1 CVT, Inferno Red, Trailer Hitch, Skid Plates, Front Tow Hooks, Engine Oil Cooler, Cargo Nets, Cabin Air Filter, Black Muffler Mod, Removed dealer decals
Coming soon: Centre console false bottom ; more mud.
  #8
Old 01-14-2010, 01:41 PM
klingoff's Avatar
klingoff klingoff is offline
Senior Member
Ride: 2013 Dodge Journey SE Plus
klingoff is on a distinguished road
My rear brakes have squeaked from day one just before coming to a stop.
I am not worried about it unless I feel the brakes arn't working or the noice changes to a vibration.
  #9
Old 01-14-2010, 03:07 PM
Member
answers
I have drum brakes and it only happens when I let off the brakes from a dead stop and its not the pedal itself. I had someone press the brake and it is coming from the rear drums for sure.
__________________
  #10
Old 01-14-2010, 03:43 PM
Senior Member
rear drum brakes huh? well then...
1- Remove drum and clean drum interior & shoes
2- Sand the shoes slightly using sandpaper, 150 steel grain
3- Sand the interior of the drum lining in circular motion to remove any linear scuffs caused by dirt and normal wear and tear. This is a common problem with drum brakes that cause squealing and knocking.
4- The shoes are mounted on steel plates. And these steel plates are set tight against the steel backing plate. And when you have steel rubbing on steel, you get squealing. You need to put a dab of lubricant where the steel touches.
It always makes me laugh when mecanics say they cant do a thing about squealing brakes
__________________
  #11
Old 01-14-2010, 06:42 PM
Member
thanks a lot
Thank you very much bigbadgreygoose. I will certainly try that this weekend and post results. Any other ideas would be much appreciated.
__________________
  #12
Old 01-14-2010, 07:29 PM
UA_who's Avatar
UA_who UA_who is offline
Sept 2009 POTM
Ride: '14 Cherokee TH
UA_who is a jewel in the rough
Quote:
What they mean is that they won't guarantee that the brakes won't squeak again after they fix them.
__________________
'14 White Cherokee TH------------Mods: Nuttin' yet
  #13
Old 01-20-2010, 01:26 AM
aaronfaryna aaronfaryna is offline
Junior Member
aaronfaryna is on a distinguished road
chamfer your brake pads?
  #14
Old 01-20-2010, 10:32 AM
Member
Thumbs up Inspection scheduled
I will be inspecting the rear brakes this weekend and will post pics if I find anything out of the ordinary. Thank you all for your help. Hopefully it just needs a little cleaning or greasing.
__________________
  #15
Old 01-20-2010, 12:19 PM
Senior Member
for "greasing" between the steel parts, take a look at some anti-seize compound...its a thick grey paste that holds up nice to friction.
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
