Another "Check Engine Light" thread... - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 10-08-2009, 12:55 PM
AZCycle's Avatar
AZCycle AZCycle is offline
Senior Member
Ride: 07 Inferno Red FWD CVT, 1965 Ford Mustang, 289V8
AZCycle is on a distinguished road
Haven't been around in quite a while... life's changes have kept me from enjoying my favorite website as much as I used to. Good to see the site is going strong and growing!
Anyway... I've had an ongoing "check engine" light issue for well over a year now. I've checked gas caps, and taken it to the dealer every time. They have always been genuinely concerned and tried their best, but after a few days to a month, the telltale "ding!" and light shows up again. I'm getting increasingly frustrated.
I know they have cleaned the throttle body, and checked numerous things... the most recent service was replacing some major computer module. That was two weeks ago, and within two days of the new module installed the light was on again (and it hasn't turned off since). I am out of warranty by a few thousand miles (bought my 07 before Jeep implemented the full warranty) but thankfully the Service Manager has been aware of my issue and because it was happening long before I was out of warranty, they've been working on it for free as if it were still under warranty. I didn't pay a cent for that expensive computer module... nice of them, of course... but I want my Jeep fixed!
I will try turning the ignition key trick today to see if it will pull a code...
I was curious to know if ANYONE actually had a solution to their check engine light. I've read through all the other threads but most of them never posted a solution.
So far I've seen:
- Bad 02 sensor
- gas cap
- emissions tube broken/loose
- exhaust crossover pipe (??) leaking
- dirty throttle body
I'm taking it back to the shop next week and will continue to update this thread with my findings and results.
__________________
Sponsored Links
Advertisement
  #2
Old 10-08-2009, 02:19 PM
Teeker1's Avatar
Teeker1 Teeker1 is offline
Member
Ride: 2009 Jeep Patriot Sport 2.4 CVT
Teeker1 is on a distinguished road
So when the check engine light comes on you should get a code. You never told us what the code was or if it has changed each time. You can buy a code reader really cheap- 50 or 60 bucks.
  #3
Old 10-08-2009, 02:24 PM
MickeyG MickeyG is offline
Senior Member
Ride: 2008 FD1 4X4
MickeyG is on a distinguished road
Send a message via AIM to MickeyG
Or buy the scan guage which offers code reading as well as other goodies
the code is the key and the vendor codes even more useful. See if any of your friends has the code reader that reads ABS as well as vendor specific codes. I suspect you are seeing the standard code supplemented by a vendor code which the inexpensive readers will not pick up.
__________________
17" tires, RRO lift kit, Mopar skid Plates front and rear, Massive Speed System front strut tower brace (for Caliber same part number as Patriot), Reese trailer hitch, full size spare, scan guage II; MBRP stainless cat back muffler; K&N filter; all installed by Wilmington NC http://www.per4manceinnovations.com/
Who is John Galt?
  #4
Old 10-08-2009, 02:48 PM
Kahbrohn's Avatar
Kahbrohn Kahbrohn is offline
Senior Member
Location: Guaynabo, Puerto Rico - just south of San Juan.
Ride: '14 Sport, Bright White, 4x2, Katzkin, 130S/RES
Kahbrohn will become famous soon enough
Send a message via AIM to Kahbrohn Send a message via MSN to Kahbrohn
Well, have you/dealer checked up on these TSB's?
There are several relating to MIL (Malfunction Indicator Light) and they give the codes involved. Once you find out the code, you may hit on the problem. Hope this reference helps you out. I was going to suggest having the PCM software updated but if it was completely exchanged, it should have been taken care of. Unless of course, the new PCM has the same outdated software. Might be worth a check.
__________________
2009 - Jeep Patriot, Sport (Light Sandstone)
2014 - Jeep Patriot, Sport (White)
  #5
Old 10-08-2009, 02:50 PM
Hitzy's Avatar
Hitzy Hitzy is offline
Senior Member
Ride: '08 Patriot Sport 4x4
Hitzy is on a distinguished road
Mine came on along with the ESP/BAS light. The culprit was a warn wiring harness under the drivers side kick plate, aparrantly it rubbed right through the sheathing and shorted out the wires.
  #6
Old 10-08-2009, 04:22 PM
Schoat333 Schoat333 is offline
Senior Member
Ride: Accord
Schoat333 will become famous soon enough
Quote:
Thats scary
AZCycle, Do you notice any difference in the way the engine is running? Does it missfire or hesitate at all? If not, you may have a problem like Hitzy had.
  #7
Old 10-08-2009, 07:10 PM
chateaupierre chateaupierre is offline
Senior Member
Ride: 08 2wd Patriot 5 spd 25D
chateaupierre is on a distinguished road
MIL & Diagnostic code P4055
Each June and October, I get the old chime with the MIL engine check lite or a GasCap lite. Each time, my Scangauge shows a Diagnostic Test Code (DTC) as P0455. This is an annoyance that I have learned to deal with and fix on each occurance.
In fact, I am experiencing the MIL Kabuki dance now. The P0455 code is the gas tank emission sensors bitching. In my case it is caused by large change in outside temperature (in June & October). The remedy is annoying but simple... see link...
http://www.jeeppatriot.com/forum/sho...125031#post125
Of course, you need to get the diagnostic code first.
  #8
Old 10-08-2009, 08:45 PM
AZCycle's Avatar
Senior Member
Thanks guys... I've never pulled the codes as I don't have a reader. Each time, I've just taken it to the dealer. I'll try the key code thing today and see if it gives me anything. No strange symptoms or engine running badly. Just that annoying light on most of the time.
__________________
  #9
Old 10-08-2009, 11:16 PM
Senior Member
Allo AZCycle, I share your frustration on the MIL chime. The MIL chime happened to my Riot within 2 weeks of new delivery in June 08. It freaked me out. Looking back, my Jeep showed no abnormal symptoms or performance problem while the chime MIL comes on. All told, the MIL (sometimes GasCap lite) came on a total of half dozen days.
Next time you are at your friendly dealer, ask them for the code.
My P0455 code problem was caused by some over-sensitive emission sensor during days of large swings in outside temperature/humidity. I normally use a lockable MotoRad gas cap. It works 97% of the time without chime problem. When the MIL comes on, I just replace it with the OEM cap: The MIL disappears after a day or so. Then put the MotoRad gas cap back on with no silly MIL for months until the next set of weather swings.
In my case, there may be a slight fitment problem with my MotoRad cap. Other members using MotoRad caps reports no problem. I may have bought a quirky cap; or my gas tank fill-nozzle don't like my particular MotoRad cap under certain atmospheric conditions. Who knows?! I don't care any more.
In fact, another member PatriotPierre from Quebec reported similar MIL problem in the depth of winter. Quebec gets first dibb on Arctic blasts; Maine get only second hand chill after Quebec
I wonder if your OEM gascap have occasional fitment problem. Cost you a few dollars for an after-market cap to find out. You mind as well spurge $20 for a lockable cap. May foil gas-thieves when high gasoline prices returns.
Finally, when does your MIL comes on, for how long? When does it disappear?
  #10
Old 10-19-2009, 08:46 PM
AZCycle's Avatar
Senior Member
Sorry for the late response... been crazy busy! Well I attempted the ignition key-turn and it didn't work for me... no codes displayed. But I did go out and release the stock gas cap, and cranked it down again. Sure enough, 30-minutes later the check engine light went off. That got me thinking. We DID have a weird change in temperature here that coincided with the check engine light and we went on a trip to northern arizona with much cooler temps.
About a week later, the gas tank was low, and the low-fuel light came on. Soon after (within a few hours) the check engine light came on. I filled up the tank, making sure to tighten the gas cap well, and the engine light went off. It's been off for about a week now.
So I'm really starting to think it might be the gas cap and/or change in pressure/temperature, etc. Next time I take the Jeep in for it's oil change, I'll have them pull the codes and tell me what they are. In the meantime, I'm just going to keep experimenting with the gas cap. I want to get a lockable cap anyway...
__________________
  #11
Old 10-20-2009, 03:37 PM
creo's Avatar
creo creo is offline
Member
creo is on a distinguished road
I say wait another year to figure it out.
  #12
Old 11-02-2009, 05:11 PM
TTM TTM is offline
Junior Member
TTM is on a distinguished road
engine light malfunction?
Hi, I am new to the forum so not sure if I'm posting correctly or in the right place!
Found this site b/c I was wondering if anyone has been having the same problem and if anyone has any idea of how to rectify and/or if there is any recourse to this.
Pending my next phone call, I will be taking my 2007 Jeep Patriot into the dealer for the FOURTH time for the same problem...the engine light keeps coming on (not flashing, thank goodness). The first time they told me it was a computer reload/update issue and it would be solved. A couple weeks later, it came back...I took it back in, and this time they told me I hadn't turned the gas cap tightly enough. This is hard for me to believe, because I am a religious five-time cap turner (and I am now a TEN-time cap turner). This time they also said there was a fuel vapor leak. A couple weeks later, the light came back again...took it in and they told me it was the gas cap again. I still can't believe that is possible, unless the cap is loosening itself?? Ironically, a couple weeks later a light came on that said "gas cap"-- a lot more appropriate, however- still hard to believe as I've screwed it on ten times. I took off the cap, rescrewed it, restarted, and the light went away. And now, another couple weeks later/just yesterday, the engine light came on again.
I am beyond frustrated as the dealer is 40 minutes away from me; they do not give loaners, so I need to get a ride to and from every time; and I cannot keep taking time off of work to get this done! Even though it's under warranty (for another few months)--- it is a complete nuissance...and worse, what happens one day when I think it's the gas cap, but it's really something more serious pertaining to the engine?
After reading through other posts, perhaps I should mention that I also have the problem with water leeking through the back door after it rains, and also my ignition hesitates to start. I took it in the for ignition problem once before (this was mid-summer so it was not cold or anything)...theytold me they reset the computer and it should be fine. It still hesitates.
Also a tad disturbed to hear that Jeep is no longer making the Patriot.
Can anyone offer me some advice? Thanks!
  #13
Old 11-03-2009, 09:37 AM
todde702's Avatar
todde702 todde702 is offline
Senior Member
TTM, and AZCycle: I'd try replacing the gas cap or at the very least, wipe down the O-ring seal and the top of the filler neck (though there is a one-way vent valve built into the cap to allow fresh air into the tank as the fuel level drops and this could be leaking as well). Perhaps some dirt is preventing a tight seal?
TTM: As for the ignition problems, how many miles do you have on it and if close too, or over 30k miles, have you replaced the spark plugs? The patriots didn't come with platinum plugs and need to be replaced every 30k miles. Also, check your air filter while you're there and replace that as needed.
__________________
-Todd
Quote:
- William Shakespeare
- Anonymous
  #14
Old 11-03-2009, 02:58 PM
TTM TTM is offline
Junior Member
Todd, thanks so much for your feedback. I am at 23,000 miles. I don't believe the spark plugs have been replaced. I did recently have the air filter replaced but I will have them check that as well.
AZ Cycle mentioned a lockable gas cap...is there such a thing?
  #15
Old 11-13-2009, 12:22 PM
AZCycle's Avatar
Senior Member
Well another update: Seems replacing the computer didn't do anything. The light has come on a few times since the replacement. Each time, we've had a drop in outside temperature or it came on along with the low-fuel light. Opening the gas cap and re-tightening seems to be working.
However. While my fiance was driving yesterday, the check engine light came on and the Jeep immediately stalled. It restarted fine and acted normal. She did the gas cap trick and the light went off right away.
But the stalling concerns me, so we took it into the shop this morning and explained everything. I asked what code the computer has been showing and teh service manager said it was a "camshaft position sensor" code since day one. So I don't know what to think. The error codes don't show that it is a fuel/vapor/gas cap issue but the light responds to tinkering with the light.
The camshaft position sensor went out on my 94 Ford Ranger years ago, and it cost me $1000 to fix... they had to tear apart half the engine to get to it.
On a related topic, we're selling the Patriot. I can't afford the payments anymore with a new mortgage and a wedding to pay for next year. Refinancing really doesn't help unless we extend the term and I'm not going to do that. We're going to sell it and buy a less expensive used vehicle. I'd like to get this check engine light issue resolved so the new owner doesn't inherit it.
So... anyone have a "camshaft position sensor" story?
__________________
Sponsored Links
Advertisement
Reply
Tags
2007 jeep patriot, check engine light
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
