Evic install - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 08-26-2009, 04:11 AM
Rskitall's Avatar
Rskitall Rskitall is offline
Senior Member
Rskitall is on a distinguished road
Evic install
Would it be possible to install a EVIC on a non EVIC patriot. I sat in a Patriot that had one and i like it.Not sure if it would be like a plug and play thing or what.Or would it be easier to get the whole thing (tach EVIC Speedometer etc..)
__________________
13 Patriot FD1 4X4 Latitude
770VX2 Viper 2 way Alarm w/factory remote start
Engine oil cooler to double my towing
Hidden Hitch Class 3 2" receiver
Thule cross bars
3,000lb winch on the receiver
Sponsored Links
Advertisement
  #2
Old 08-26-2009, 07:29 AM
Kahbrohn's Avatar
Kahbrohn Kahbrohn is offline
Senior Member
Location: Guaynabo, Puerto Rico - just south of San Juan.
Ride: '14 Sport, Bright White, 4x2, Katzkin, 130S/RES
Kahbrohn will become famous soon enough
Send a message via AIM to Kahbrohn Send a message via MSN to Kahbrohn
Not sure if it is a PnP setup. Depending on what you want it for, a Scangauge may be an alternative and a bit easier to install. If you want to simply monitor MPG's, engine functions, and such, Scangauge (based on what I have read) should do the trick. If you want the TPMS and other functions, then that's a different ball park.
Either way, it would probably be best to have it done by the dealer. Components that affect the odometer "may" have to be changed and that is against the law in itself unless properly done and registered.
__________________
2009 - Jeep Patriot, Sport (Light Sandstone)
2014 - Jeep Patriot, Sport (White)
  #3
Old 08-26-2009, 01:27 PM
quasimodem51's Avatar
quasimodem51 quasimodem51 is offline
Fossilized Member
Ride: 07 Patriot Limited FDII, CVT2L, NAV, 9 BA
quasimodem51 will become famous soon enough
I would first investigate whether there are multiple physical configurations of the instrument cluster. If there is only one configuration (the EVIC stuff is there just not lit up ever), then you may be halfway home. If you let some sunlight bounce off the matt portion of the speedometer and you can see an outline of the LED arrays forming the EVIC, then you may have a cluster that will work.
Next up would be applying the same diagnostic approach to the wiring harness. If they make only one wiring harness and the little plugs just aren't plugged in, most of the rest of the task may be easy to accomplish.
If not, I would imagine it would be price prohibitive to have EVIC installed.
I suspect you are out of luck because the bean counters would have figured that there is a lot of wire to be saved by making more than one configuration.
Good luck. I would be interested in knowing how you made out.
__________________
Save the Earth. It is the only one with chocolate.
  #4
Old 08-27-2009, 02:17 PM
Rskitall's Avatar
Senior Member
I know it's not the same but I installed a map light and I am gald I got the wiring harness but it pretty much just plugged in with the harness.I don't think the Evic is there but I will check on my break.I notice the Evic on the other Patrioit had a button like the speedometer and that is not there.I was thinking of just getting the EVIC from the Junkyard but I guess I will have to investigate a little more which means taking sh** apart
__________________
Thule cross bars
  #5
Old 08-27-2009, 03:35 PM
Kahbrohn's Avatar
Senior Member
I am actually surprised you don't have the EVIC. I have a 26E packaged '09 Patriot and I have the EVIC. Must have been included after the 2007 model I guess. The more I sort of think about it, the more I think it could be installed (assuming your actual instrument cluster allows for it) and just have the computer reflashed to recognize/control it.
__________________
  #6
Old 08-27-2009, 04:17 PM
dadunkindude's Avatar
dadunkindude dadunkindude is offline
All-around Good Guy
Ride: '09 Patriot Sport, '07 Wrangler Sahara
dadunkindude is a jewel in the rough
Send a message via AIM to dadunkindude
I'm not sure you'll be able to do it easily. Look at all the different instrument cluster options for the Patriot. This comes out the 08 Parts Manual.
__________________
Don't forget to reward helpful posters! To do so, click the "justice scale" next to the post number to provide "reputation" to those who help you out. Voila!
Every time you call a JEEP a "car," God kills a kitten. Please, think of the kittens.
Go out fast. When it hurts, go faster!
  #7
Old 09-05-2009, 05:48 PM
Rskitall's Avatar
Senior Member
well it's not there so I will have to find one at the junk yard. can anyone take a pic of the connectors to see if they are even any in there
__________________
Thule cross bars
  #8
Old 09-05-2009, 06:09 PM
tiptronic's Avatar
tiptronic tiptronic is offline
POTM Winner AUG. 09.
Ride: Jaguar X-type 2.5 4x4
tiptronic has a spectacular aura about
Send a message via Skype™ to tiptronic
THis is often a subject on Caliber & SRT4 ForumZ--I just checked it out---I think that the general opinon is that for the extra info you get from EVIC it just is't worth the expense & hassle. It isnt plug & play & your non EVIC Pat will not have the required sensors fitted to make it work anyway.i.e. Compass, TPMS, head light delay, auto door lock 0n/off , miles till empty , average mpg etc etc. The general concensus of opinion was it would be cheaper to trade in & get a Patriot/Caliber with it allready fitted.
__________________
Just swapped red Classic X , for, Green Auto SE " Spirit " 2.5 Petrol Limited edition X still 4x4,
Ex 07 Patriot CRD Sport , UK ( with lots of chrome goodies )
  #9
Old 09-05-2009, 06:13 PM
rocal's Avatar
rocal rocal is offline
Senior Member
Ride: Jeep Patriot
rocal has a spectacular aura about
I've really just got my come-uppance. I always thought I was pretty knowledgeable in things to do with motoring...but....
What in all the seven hundred halls of hell is this thread about...?
  #10
Old 09-05-2009, 06:24 PM
JoeBecker's Avatar
JoeBecker JoeBecker is offline
just an average Joe
Ride: 2008 Steel Blue Patriot Sport 2WD
JoeBecker will become famous soon enough
Quote:
It is board based. I don't believe that the wiring (number of harnesses or wires in it) will be any different between the two.
You would have to get a whole new instrument panel, and that brings up issues with the odometer. I believe that data is stored in the instrument cluster.
What data do you want to see? The scangauge II is good for most anything the EVIC will tell you. The majority of the personal settings can be set with just the keys. If it is a setting that can only be changed via EVIC see if your dealer can change it by hooking it up to their scan tool.
__________________
2008 Steel Blue Patriot Sport, 2WD, CVT, Package E, Tire/Wheel Group My Modifications
If the women don't find you handsome, they should at least find you handy - Red Green
  #11
Old 09-05-2009, 11:44 PM
Rskitall's Avatar
Senior Member
for some reason no commands through my keyless entry will work(turn off chirp on lock,auto lock off etc etc.dealer says because I have a aftermarket alarm they won't change my settings with a scan tool.I can drill a little hole if needed in my own plastic cover for the button that is not a big deal but it would be nice to change the settings when I want.
__________________
Thule cross bars
  #12
Old 09-06-2009, 06:39 AM
yellowhat's Avatar
yellowhat yellowhat is offline
Senior Member
Ride: 07 2.0 CRD Limited
yellowhat is on a distinguished road
There's a small screen the left hand dial on your dash binnacle. Depending on your model, this small screen displays information about your vehicle. For example, compass heading, mpg, radio info etc. I, quite by accident, have managed to purchase the LTD Pat which includes this cool feature along with alloys sunroof, load cover and many other sought after bits that aren't "standard" How lucky am I?
__________________
Gloss Black 2007 Limited MK Sunroof Boston Sound
Pioneer F-700BT Sat-nav Bluetooth with IPOD controller from the steering wheel!
Mopar deflectors, front and sides. Rear Parking sensors with camera connected to head unit.
  #13
Old 09-06-2009, 09:11 AM
JoeBecker's Avatar
just an average Joe
If they are not willing to scan it for the personal settings, I would assume that they aren't going to help when it needs to be reflashed/reprogrammed with the new instrument cluster.
What was their reasoning? Are they afraid they are going to mess up the alarm? Do they want to charge you to do it? Who put in the alarm? Did you ever try the settings before the alarm was installed? Can the alarm be "disabled" easily to see if the fob settings will work?
I can see why an alarm might mess with the key fob settings that involve locking the Jeep as part of the process. Do the functions that do not require pushing lock on the key fob work? Like auto unlock (where you cycle the key in the ignition and push the unlock button of the Jeep)?
__________________
  #14
Old 09-06-2009, 10:49 AM
tiptronic's Avatar
Uk Sport & Ltd Patriots are fitted with EVIC as standard!!
__________________
  #15
Old 09-06-2009, 12:35 PM
rocal's Avatar
Senior Member
Ride: Jeep Patriot
Right, so it's that thing that says South-West, North by North-West, Dora Jarre (Jean-Michel's sister) eh?
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
