HOW TO: remove center bezel and radio on 09 Patriot (DIY!) - Jeep Patriot Forums
Notices
Interior Articles covering interior modifications (such as seats, dash, roll bars, etc)
Click for instructions on how to post an article in the Knowledge Base
Reply
Thread Tools Display Modes
  #1
Old 08-20-2009, 12:07 AM
PorscheTT's Avatar
PorscheTT PorscheTT is offline
Member
PorscheTT is on a distinguished road
All the instructions I've seen are for the 08s and earlier. The 09 has a different center console.
Tools needed: 1) small flat blade 2) bicycle tire spoons (or something similar) 3) phillips head screwdriver
Step 1) Right tool for the right job.
Step 2)
Make sure you cover the shift knob as not to damage the bezel.
Step 3)
Turn the knobs all the way to the right so the there will be slack in the red and green guide cables.
Step 4)
Use a small flat blade to pry open the bezel just enough so you can slip in the tire spoon. The spoon is wide and made out of a softer material so it won't damage the bezel.
Here are the location of the clip points so you'll know where to pry:
Step 5)
Bezel removed. You'll notice the static cling protection film I have to keep scratches and finger prints from the display screen. Easy cleaning too. The "black" 3M vinyl square on top of the bezel is there for my GPS suction cup to stick to.
Step 6)
You'll see two cables that will need to be unhooked to get the bezel completely out of the way.
Use the small flat screwdriver to push in the tabs to remove both the red and green cable holders.
Step 7)
Simply remove the 4 phillips screw and pull out the radio
I did this exercise to see if my REN MyGIG has plugs for the factory rear camera.
__________________
09 'Riot Sport Rocky Mtn Ed., BlkCrystal, 4x2 CVTII, 26W, RRO 2.125" Lift, 16x8 Moabs w/ 235/70/16, 3M clear shield, MyGIG REN, LockPick + A/V, OEM style rear camera, Class III hitch, Blacked-out Muffler, LED window switches.
Check out my Porsche 930 Engine Rebuild
Sponsored Links
Advertisement
  #2
Old 08-20-2009, 01:05 AM
zettler zettler is offline
Senior Member
Ride: 2009 Jeep Patriot Sport
zettler is on a distinguished road
Excelent work and thank you for sharing!
  #3
Old 08-20-2009, 01:06 AM
heckler's Avatar
heckler heckler is offline
Senior Member
Ride: 07 Lifted FDII North; 81 Westy
heckler is a jewel in the rough
can you repost this into the knowledge base submission forum? That'll keep it at the top where it belongs.
__________________
Project Abyss - 07 FDII North, RRO lift, 16X8 Soft 8 with 235/70-16 Grabber AT's, Roof Basket, Procomp 55 roof lights, dash tweeters, 2" hitch, North Shore Rack, K&N drop-in, Hi-lift, Procomp 55 driving lights
  #4
Old 08-20-2009, 01:10 AM
PorscheTT's Avatar
Member
Quote:
I tried, but I didn't have sufficient privilege? Anyone know how?
__________________
  #5
Old 08-20-2009, 01:20 AM
heckler's Avatar
Senior Member
http://www.jeeppatriot.com/forum/forumdisplay.php?f=19
you have to submit it. You can't put it directly into the knowledge base.
I guess eventually the mods will move the good threads into the knowledge base.
__________________
  #6
Old 08-20-2009, 01:31 AM
PorscheTT's Avatar
Member
Ah...thanks a bunch heckler...submitting it now.
__________________
  #7
Old 08-20-2009, 01:33 AM
Gaze's Avatar
Gaze Gaze is offline
Ride: 2007 Jeep Patriot Limited 4x4
Gaze will become famous soon enough
Send a message via AIM to Gaze
already moved... excellent work!
__________________
2007 Jeep Patriot Limited - Signature Thread
  #8
Old 02-12-2010, 01:08 PM
Shadow-wulf Shadow-wulf is offline
Junior Member
Shadow-wulf is on a distinguished road
So after all that work does the radio support the back up camera? I work at the Brampton Assembly plant and we use Fibre sticks for pulling dashboards apart....nice workaround with the spoke tool!
  #9
Old 03-17-2010, 02:11 PM
GaryK GaryK is offline
Junior Member
Ride: 2009 Patriot Spt, 2008 Compass Spt, 4x2's,2.4L's.
GaryK is on a distinguished road
Center dash
Thanks a lot for the photos, it made the job much easier. I r&r'd the radio, reinstalled the stock one. ( The shop wanted $50 to r&r the radios.) The only thing I would add, is when removing the red and green cables from the arms be aware the little lever has a spring loaded cam that holds the eye of the cable on. This cam must be depressed enough to get the eye over it and then off. (I used needle nosed pliers for that and duckbills to hold the cable end) As with all things plastic, slow and cautious is best. Overall it was easy. I used a tool set I purchased from Summit Racing to pry the dash off. They are made of nylon and includes levers and pry bars (4total). Cost 19.95+shipping. I was back on the air in an hour.
  #10
Old 05-07-2010, 02:00 PM
n4cr2k's Avatar
n4cr2k n4cr2k is offline
Member
Ride: Winter - Patriot 4x4 / Summer - Solstice GXP
n4cr2k is on a distinguished road
Thanks for the write up PorscheTT. Removing the radio housing is a breeze compared to the 07/08 models. Do you also happen to know how to remove the gear selector bezel/housing for the 09/10 models?
Never mind, figured it out.
  #11
Old 08-13-2010, 11:49 AM
lilishmoto's Avatar
lilishmoto lilishmoto is offline
Junior Member
lilishmoto is on a distinguished road
Love the Porsche write up oh and thanks for the how to for the radio. i think it will be my first interior mod the stock radio sucks so bad. i just need to figure out how deep i want to go with the speaker swap
__________________
Hell Yaya it's a JEEP
Current MODS: Yokohama Geolander AT-S 225/65 R17 (Awesome tires BTW); Factory Driving Lights installed
Next MOD: Stu Coil lift
  #12
Old 06-14-2012, 10:50 PM
kvnbrkbl kvnbrkbl is offline
Junior Member
Ride: 2009 Patriot Limited
kvnbrkbl is on a distinguished road
Pictures are gone
  #13
Old 06-14-2012, 11:06 PM
Metaxa's Avatar
Metaxa Metaxa is offline
Senior Member
Ride: 2011 Patriot
Metaxa is a splendid one to beholdMetaxa is a splendid one to behold
Yes, yes they are.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
