Still need to finish the cover but this is what I got so far.
It hits pretty good!
Thanks for the idea! Thats kinda what I have in mind, except for the hole where the speaker is use some chicken wire and then some speaker felt over the chicken wire just so it has some add protection. Just incase something were to hit it.What I would do for a cover is get a sheet of plastic or wood the depth of the lip. Use paper to make a nice template. Cut it to shape of the hole then check for fit. Measure in a few inches and cut out the center. Or even just cut out a hole in where the speaker is. Get some speaker felt and spray glue and cover the board or plastic. Then attatch it with small screws from the backside. Should look real nice and cost next to nothing. Just my two cents worth.
I'm not sure what you mean by wire it to? If you mean the amp I just wired it up like a basic amp install. You have a wire from the battery, a ground, a remote, the rca's from the head unit, and then the speaker wires to the sub.What did you wire it to? Where did you locate the amp to keep it out of the way and did you incorporate the stock head unit?
