Rear wiper problem - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 03-30-2009, 05:29 AM
Rskitall's Avatar
Rskitall Rskitall is offline
Senior Member
Rskitall is on a distinguished road
Rear wiper problem
My rear wiper stops at different spots while wiping the rear window it is weird Has anyone else had this happen.I guess I am going back to the dealer.Tried turning car off and retrying it and tried the old hit it and see if it works nut no luck
__________________
13 Patriot FD1 4X4 Latitude
770VX2 Viper 2 way Alarm w/factory remote start
Engine oil cooler to double my towing
Hidden Hitch Class 3 2" receiver
Thule cross bars
3,000lb winch on the receiver
Sponsored Links
Advertisement
  #2
Old 03-30-2009, 06:53 AM
bensez's Avatar
bensez bensez is offline
Member
Ride: Patriot 2,4 CVT ECO+ (european edition with LPG)
bensez is on a distinguished road
Have had the same problem when i got my car. It happens the first time i used the rear wiper, it stops as well at different spots. Went to the dealer he told me that connot be. We tried again and suddenly it works fine. Never had the same since then.
  #3
Old 03-30-2009, 07:58 AM
Ash's Avatar
Ash Ash is offline
Senior Member
Ride: Bright Silver Metallic 2.0 CRD limited with BA
Ash is on a distinguished road
Do you mean it sort of skips across the glass? That's what mine does and it's rubbish, I think it is down to the wiper blade.
__________________
Bright Silver 2.0 CRD Limited (UK Spec)
  #4
Old 03-30-2009, 09:46 AM
phatdilf's Avatar
phatdilf phatdilf is offline
Senior Member
Ride: 4x4 08 pat rro lift 235/70/16 bfg a/t
phatdilf is on a distinguished road
yeah mine leaves streaks all through the arc
i think it's just terrible wiper blade, i went to buy one but kinda hard to find cause it's so small it's not very common
__________________
http://www.cardomain.com/ride/3153711
ONLY THROUGH STRUGGLE I FIND REST WITH A PIECE OF ME TAKEN AWAY
  #5
Old 03-30-2009, 12:25 PM
festerw festerw is offline
Senior Member
festerw will become famous soon enough
More than likely the motor has a bad spot in it.
__________________
2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
2011 Dodge Durango Crew
  #6
Old 03-30-2009, 01:03 PM
cadavev's Avatar
cadavev cadavev is offline
Senior Member
Ride: 14 patriot fwd latitude
cadavev is on a distinguished road
on my pat the rear glass was replaced and when they put the wiper back on they did not tighten it up enough and it did not work properly. i just tightne the nut a bit more and it works fine now. Hope you get it fixed....
__________________
David Vianu
Rancho Cucamonga, Ca.
14 Patriot Latitude Fwd 2GB package
Traded in 07 patriot sport cvt fwd 208, 314 miles owned since new.
  #7
Old 03-30-2009, 09:05 PM
oldskidog oldskidog is offline
Senior Member
Ride: Sally
oldskidog is on a distinguished road
Mine (07) just started doing the random places stop thing - if anyone figures it out please post! First annoyance out of the riot in 2 years...
  #8
Old 04-03-2009, 12:53 AM
Rskitall's Avatar
Senior Member
I figured it out myself It is # 16 fuse inside your fuse box it is weird because it says it is only for accessory power but it does effect the wiper??? I just decided to go to the back to the basics and check my fuses and I saw it blown and then I tried the wiper and it worked!!
__________________
Thule cross bars
  #9
Old 04-03-2009, 01:45 AM
BigLen59 BigLen59 is offline
Junior Member
BigLen59 is on a distinguished road
Send a message via AIM to BigLen59
I actually had my rear wiper motor replaced by dealer because it was doing the jumping thing.
  #10
Old 04-03-2009, 02:07 PM
Rskitall's Avatar
Senior Member
they probably just changed the fuse lol.No problems since changing the fuse. I thought I would post this in case anyone else had this weird problem.The other weird part was that my 12volt accessory worked for a while before it went out completely (I was wondering why the green light for my GPS was not bright green like it usually is)
__________________
Thule cross bars
  #11
Old 04-03-2009, 02:55 PM
JeepJim JeepJim is offline
Senior Member
JeepJim is on a distinguished road
Quote:
I have been having this issue since last July! I'll be damned if it wasn't Fuse 16 just like you said too. I thought for sure I had checked them all... But anyway rep points coming your way! Thanks!
  #12
Old 04-06-2009, 02:11 PM
Rskitall's Avatar
Senior Member
Thanks for the rep points!!
__________________
Thule cross bars
  #13
Old 04-06-2009, 02:24 PM
Rends's Avatar
Rends Rends is offline
POTM June 2009
Ride: 08 CRD Limited 4X4 Turbo Diesel Injection
Rends will become famous soon enough
If this is realy a fuse only problem then the thread should be moved to the knowledge base!
  #14
Old 04-24-2009, 04:46 PM
Senior Member
After replacing the fuse it worked that day...
I went to use it again this last week and guess what? Yup the fuse was already blown and I do not use the cigarette lighter, or the accessory outlet. I wonder whats causing the damn thing to blow?
  #15
Old 04-30-2009, 01:47 AM
Rskitall's Avatar
Senior Member
I replaced mine with a 20 amp fuse instead of 15 amp and have never had a problem again.I think it has to do with whatever your plugging in to your cigar lighter I don't think it was all supposed to be all in one (accessory and rear wiper) but who knows
__________________
Thule cross bars
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
