Engine Vibrating Noise - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 05-23-2007, 11:43 AM
cjhike cjhike is offline
Member
cjhike is on a distinguished road
Unhappy Engine Vibrating Noise
Notice a noise coming from the front of my Pat on acceleration. You can hear it when the RPM's get above about 3500, and it is quite loud at 6000 RPM. It sounds like a piece of sheet metal vibrating or something - really fast. I was thinking maybe it was the heat shield behind the engine on the fire wall, however can not get it to make any noise when I move it with my hand.
Anybody else have this problem? I have an appointment with the dealership this afternoon for a wheel alignment, maybe they will have time to find the noise as well.
Sponsored Links
Advertisement
  #2
Old 05-23-2007, 04:41 PM
murphdog34 murphdog34 is offline
Member
murphdog34 is on a distinguished road
i THINK i have the exact same problem i didnt test it at those high rpm's but i noticed it did it in 2nd and 3rd gear mostly when i took my foot off the gas and let the gear wind out does this sound liek the problem you are having? please let me know what the dealer says
  #3
Old 05-23-2007, 08:56 PM
Member
I have the CVT and have not noticed it when taking my foot off of the gas, just when accelerating - seems worse under load ie up hill. It starts at about 3500 RPM and stops at 4500 then starts again at 5250 up to red line.After listening closer today seems to originate from the Drivers side below the dead pedal.
The dealer or course had no idea as this is the first Pat they have had into the shop. They are going to check the ones on the lot for "ideas" and give me a call. They assured me that it is nothing mechanically wrong.
  #4
Old 12-22-2009, 07:03 PM
jjs720 jjs720 is offline
Junior Member
Ride: 2007 Patriot Limited 4x4 CVT
jjs720 is on a distinguished road
I have a 2007 Patriot Limited with CVT and I am experiencing the metal to metal vibration around 1800 and 2800 RPM especially under load when traveling up hills/ mountains. I had it at the dealer today and they were unable to pin point the problem. I did a little more investigating when I was home. I believe it may be a welded surround/ shield on the engine side of the rear driveshaft just after the U-joint. It is the only metal that made a similar noise when I would knock on it. I will have to investigate a little further when not so cold out or take it back to the dealer and let them figure it out. I am quickly losing patience with it.
  #5
Old 12-22-2009, 07:28 PM
ti-claude31's Avatar
ti-claude31 ti-claude31 is offline
Senior Member
Ride: 2009 north edition 2,4 l cvt 4wd light grey
ti-claude31 is on a distinguished road
it's only a guess but take a look at the muffler or catalyser? keep us posted
  #6
Old 12-22-2009, 07:40 PM
molsonreddog molsonreddog is offline
Junior Member
molsonreddog is on a distinguished road
Exclamation
I have same vibration @ 3500 rpm. Sounds like some kind of heat shield. Took to dealer 2x they couldn't find anything. The second I pull off the lot it maked the noise, so back I go and get the service manager to go for a ride. Drove with him for a half hour NO NOISE. now I look crazy. The minute he leaves noise is back. I'm at just about 36000 miles and don't want to end up with a problem that I have to pay for.Anyone find the solution?
  #7
Old 05-14-2010, 01:05 AM
Junior Member
I had my vehicle to 2 different dealers a total of 10 times over 2 years before finally resolving the noise at 1800 and 2800 rpm on my '07. It ended up that 2 bolts were missing from the exhaust manifold from manufacture. The dealer installed the 2 missing bolts as well as replaced the catalytic converter and heat shield.
  #8
Old 05-14-2010, 01:26 AM
Vultite Vultite is offline
Senior Member
Ride: 07 Jeep Patriot
Vultite is on a distinguished road
WOW, talk about a lack of QC, the union must have gotten all the workers pissed off that day at the plant or something...
__________________
07 Silver Pat, 2.4L 5-speed manual,leather and power package,17" Yoko Geolander A/T-S, 14" Black Billet stubby antenna, Curt Class III Hitch, black muffler mod, Hella Optilux 2500's,and more to come...
  #9
Old 05-14-2010, 03:00 PM
kb01 kb01 is offline
Senior Member
kb01 will become famous soon enough
I had a similar problem awhile back -- very loud vibration noise at a very specific RPM range.
It turned out to be something very minor. When I installed a new engine air filter, I accidentally didn't clip the second (hard to reach) clip all the way down. The pleats on the NAPA Gold air filter I used were probably a 1/2" longer than the Mopar ones, which made the box very difficult to close. I reinstalled the filter and made sure the box was completely closed and the noise went away.
  #10
Old 05-15-2010, 01:21 PM
Jeephigh_11's Avatar
Jeephigh_11 Jeephigh_11 is offline
Senior Member
Ride: 07' 2.4L 4x4 5 Spd Patriot
Jeephigh_11 is on a distinguished road
At 3500 RPMS the air tumbler within the throttle body opens completely to allow greater smoother air flow for more HP at wide open to close to wide open throttle. The tumbler device is probably stuck in it's normal operating position under 3500 RPMS. The only reason I know this is because I was browsing through the Pats service manual and noticed this information. The only reason I care is because I noticed under heavy up hill acceleration the RPMS just after 3500 jumps or stutters at bit, no big deal for me, and will go unnoticed to everyone else in the Pat.
__________________
Where We're Going We Don't Need Roads.....
  #11
Old 05-15-2010, 04:06 PM
patroit07 patroit07 is offline
Senior Member
Ride: Jeep Patriot 2009
patroit07 is on a distinguished road
I have same kinda noise. I can not hear it no more after I cut off muffler like discojables do. Maybe it was the muffler?
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
