CVT Transmission Fluid And Filter Change - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 03-16-2009, 04:29 PM
jimmi56 jimmi56 is offline
Junior Member
jimmi56 is on a distinguished road
I have done a search but I havent seen any posts regarding the CVT fluid and filter change. Is it just a straightforward remove pan, fluid and filter and put the new filter and gasket in and fill her up?
Sponsored Links
Advertisement
  #2
Old 03-16-2009, 06:40 PM
zbee's Avatar
zbee zbee is offline
Aussie Patriot Legend
Ride: Patriot Sports Lifted & Limited CRD + 2 @ work
zbee has a spectacular aura about
Send a message via MSN to zbee Send a message via Skype™ to zbee
to retain the lifetime warranty get a dealer to do it, the fluid is expensive and you need special tools aswell, this is one job that is a dealership must do
__________________
mine has really really big wheels now245/70/r17
  #3
Old 03-17-2009, 12:18 AM
Junior Member
I had thought the fluid and filter needed to be changed at 36000 miles but I looked again and it says 60k. Should I really wait that long?
  #4
Old 03-17-2009, 12:29 AM
jpjeepguy's Avatar
jpjeepguy jpjeepguy is offline
Senior Member
Ride: 2007 Compass Sport 4x4 CVT, "E" Pkg, Moon Roof
jpjeepguy is on a distinguished road
60k is the sever service interval, the "regular service" interval is 120k miles. The fluid costs in excess of $20 a quart and it will take 8-9 quarts.
From looking at the service manual the actual process is just like any other automatic. Drop the pan, change the filter, install new pan gasket and refill. It is the refilling that is the rub- there is not a dipstick for the transmission- instead a special tool (essentially a graduated wire cable with a handle) is used, the temperature of the fluid is measured and then a table in the service manual is consulted that tells at what mark on the tool the fluid should be at.
Me, I plan to have a dealership take care of this service when the time comes.
  #5
Old 03-17-2009, 12:43 AM
zbee's Avatar
i agree, i had mine done but i do extreme traveling, best left to dealers as not worth the possible grief doing it youre self
__________________
  #6
Old 03-17-2009, 09:14 AM
todde702's Avatar
todde702 todde702 is offline
Senior Member
You can use the oil dipstick. When I first brought my Pat home, I noticed no trans dipstick. So I pulled the oil dip stick, wiped it clean then inserted it fully into the CVT fill/check tube. The oil level read at the one quart low mark on the oil dip stick. Doesn't tell me if it's full or low or anything, but at least I know it's at the same level as it was delivered to me.
__________________
-Todd
Quote:
- William Shakespeare
- Anonymous
  #7
Old 03-18-2009, 06:23 AM
hvac59's Avatar
hvac59 hvac59 is offline
Senior Member
hvac59 is on a distinguished road
Now that man deserves a whole hearted job well done and a golf clap. Daaaaaaamn, why didn't I think of that! Good work Todd.
hvac59
__________________
White 01 WJ(stock 4.7 limited QD1)
White 08 MK(2.4 CVT limited FD1)
  #8
Old 03-19-2009, 08:45 AM
Silverone's Avatar
Silverone Silverone is offline
Senior Member
Ride: 07 4WD
Silverone is on a distinguished road
My HHR has no dipstick. Not even a place to stick the oil dipstick. The manual says the only way fluid can escape is thru a leak. Nothing on the ground? You ain't got a leak. Don't worry about it. But the dealer couldn't tell me how he knew the fluid was OK on delivery. Good test for a quick oil change place's honesty. Ask how the trans fluid level was.
  #9
Old 03-19-2009, 11:03 AM
tiptronic's Avatar
tiptronic tiptronic is offline
POTM Winner AUG. 09.
Ride: Jaguar X-type 2.5 4x4
tiptronic has a spectacular aura about
Send a message via Skype™ to tiptronic
The CVT Trans is not a User Servicable part!! It is basically a sealed for life Unit. The fluid level is checkable , using special Depth/Temp euipment , by the dealer. The special fluid, whitch contains rubber granuels for belt adhesion, has its fist Check & change at 60.000 miles.As this system works under amazingly high pressure to actuate the belt/pully system. Its not a system I would attempt to do myself!!
__________________
Just swapped red Classic X , for, Green Auto SE " Spirit " 2.5 Petrol Limited edition X still 4x4,
Ex 07 Patriot CRD Sport , UK ( with lots of chrome goodies )
  #10
Old 03-19-2009, 11:12 AM
orangejeepzj orangejeepzj is offline
Junior Member
Ride: 91 jeep cherokee, 99 jeep cherokee, 08 patriot
orangejeepzj is on a distinguished road
So has anyone hit the 60k mark yet, i wanna know how much the fluid change is gonna cost. And has anybody changed the fluid in your diffs yet. How involved is that if so. I have looked a t them and afraid it may be a dealer service as well
  #11
Old 04-27-2011, 07:31 PM
blackkimber blackkimber is offline
Junior Member
blackkimber is on a distinguished road
CVT fluid change
I was told $250 for trans fluid change. The same dealer said they would sell me the mopar trans fluid at a discounted price of $18 per quart since they had lost their Jeep dealership because of the bankruptcy and reorganization of Chrysler.
  #12
Old 04-27-2011, 09:26 PM
JeepHankins JeepHankins is offline
Senior Member
Ride: 2008 North Edition 2.0L
JeepHankins is on a distinguished road
Check out miller tools 9336A thats what i have. I'm going to do my cvt service at 100000 kms.
__________________
  #13
Old 05-07-2011, 12:46 PM
Stonent Stonent is offline
Senior Member
Ride: 2009 "Jeep Green" Patriot 2.4L CVT
Stonent is on a distinguished road
I've heard you can get Nissan CVT fluid for the Rogue for $15 a quart at the Nissan dealer. That might save a little money over the Chrysler stuff considering Nissan owns the company that made the transmission.
  #14
Old 05-13-2011, 10:48 AM
kb01 kb01 is offline
Senior Member
kb01 will become famous soon enough
Quote:
Changing the differential fluid is easy (it takes standard gear oil) and most independent garages can do it quickly and cheaply. I can't remember what my mechanic charged but it was pretty nominal.
I have about 80,000 miles and am waiting until somewhere between 100,000 - 120,000 miles to change the CVT fluid. I called several dealers and they want between $250 - $300 to change it (it goes for $18/quart).
I have the Lifetime Warranty and am operating under the normal maintenance schedule. If anything happens, I'm hoping that my local dealer will have my back in terms of warranty claims -- I've bought several cars from them and given them several thousand of dollars in maintenance.
  #15
Old 11-16-2015, 12:36 AM
PheasantPete PheasantPete is offline
Member
Ride: 09 Patriot;84 3/4T 4X4 GMC BURB, 383 PERF,Lifted
PheasantPete is on a distinguished road
Red face
Update, as a aircraft mechanic and former ASE certified mechanic I will tell you everything above is typical internet garbage from those who post nonsense about things they do not understand. Napa has the dipstick 605-1677 @ under $25. It comes with a chart as the fluid level is temp dependent. They also have the filter and gasket NAPA Part #1-5510. It is straight forward transmission filter change, be sure to wipe out pan and clean the 2 magnets thoroughly. Valvoline makes a Full synthetic CVT fluid that is CVTF4 chrysler compatible. Part #804751. I recommend changing before 100K miles as it already dirty (very black) by then and then every 50K miles as much fluid remains in trans during drain. The owners manual recommends 60K for severe duty and 120K miles normal service. This applies to 2007-2011 Patriot with CVT transmission. The fluid required will depend on how hot trans was when drained and how long it drained. Most require under 7qts but I would have a 8th around just in case. Add 5qts and then check, add, check until in middle of zone. Any dipstick that touches the bottom will also do as it is measured in millimeters and one could scribe the back of the oil dipstick so you always have it with you. Measured from bottom of stick 32mm works from 50F to 170 F. It would be the high mark @ 50F and the low @ 170F. 28mm to 36mm works from 70F to 125F trans fluid temp with low for 70F and high for 125F. I posted more details here: http://www.jeeppatriot.com/forum/showthread.php?t=97981
Last edited by PheasantPete; 11-16-2015 at 03:26 AM. Reason: added internal link to a post with more detail
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
