Neutral safety switch??? - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 03-30-2013, 09:45 PM
Brilliant_Black's Avatar
Brilliant_Black Brilliant_Black is offline
Junior Member
Ride: 2008 Jeep Patriot
Brilliant_Black is on a distinguished road
Question Neutral safety switch???
Hi,
I've be having issues with my '08 Pat not starting. Some days it would others it wouldn't. Now it just wont start at all. Battery is fine, Starter works and has been tested. When I turn the key ahead all lights come on, and sometimes I hear a click. But starter wont start. So I tried doing a "hot wire" from the starter right to the battery. Turned the key ahead, and touched the wire on the battery. The starter cranked over but still wouldn't start.
I've been told it could be the Neutral safety switch. I'm not sure exactly where it is. I'm wondering where its located and if there is a way to bypass it all together. Cause I mean lets face it, I will never try to start the thing in Drive. You got to have it in park to take the key out anyways.
I've been a member to this site for years and have never posted a question. Most question I've had have already been answered. I couldn't find anything on this topic.
Thanks all,
__________________
'08 PAT FDII - Brilliant Black
O||||||||O
Sponsored Links
Advertisement
  #2
Old 03-30-2013, 10:26 PM
Metaxa's Avatar
Metaxa Metaxa is offline
Senior Member
Ride: 2011 Patriot
Metaxa is a splendid one to beholdMetaxa is a splendid one to behold
I don't have an answer fro you but wanted to remind that it is Easter weekend so things might be a bit slow.
so, this will explain that and bump the thread back up too.
Someone with a bit of an idea will be along, I'm sure.
  #3
Old 03-30-2013, 11:18 PM
Terasec's Avatar
Terasec Terasec is offline
Senior Member
Location: from NYC and have places in upstate NY and in PA
Ride: 2007 Patriot, Light Khaki, 4x4, CVTII FdriveII,
Terasec is just really nice
Send a message via AIM to Terasec Send a message via Yahoo to Terasec
Neutral sensor is usually located within the shifter.
On other cars I have had its usually a slide sensor that senses shifter position .
Have had it go bad and lose connection on an olkd car. But haven't heard it going bad on the pat or other recent cars.
If park, driving lights and reverse lights work right, probably not the sensor.
When you hard wired it, did you hard wire the starter? Or the solenoid?
If starter worked could be a bad solenoid.
Or could also be a loose connection somewhere.
  #4
Old 03-31-2013, 12:14 AM
Junior Member
I have already tried a brand new starter and still the same issue. frustrating to say the least.
__________________
O||||||||O
  #5
Old 03-31-2013, 01:12 AM
nth256 nth256 is offline
Senior Member
Ride: 08 Patriot Sport 4x2
nth256 has a spectacular aura about
Brilliant_Black - This may sound dumb, but have you tried cleaning the battery connections?
  #6
Old 03-31-2013, 07:47 AM
Junior Member
Quote:
Not dumb, sometimes the simplest answer is the right answer. But in this case no. I have cleaned both the connectors and the terminals.
__________________
O||||||||O
  #7
Old 03-31-2013, 12:17 PM
todde702's Avatar
todde702 todde702 is offline
Senior Member
From the 2008 FSM:
Quote:
The starting system consists of:
Starter motor (including an integral starter solenoid)
Other components to be considered as part of starting system are:
Battery
Battery cables
Ignition switch and key lock cylinder
Clutch pedal position switch (manual transmission)
Park/neutral position switch (automatic transmission)
Wire harnesses and connections.
The Battery, Starting, and Charging systems operate in conjunction with one another, and must be tested as a complete system. For correct operation of starting/charging systems, all components used in these 3 systems must perform within specifications. When attempting to diagnose any of these systems, it is important that you keep their interdependency in mind.
The neutral safety is included in the transmission range sensor, which is bolted to the transmission where the control cable connects to select the gear.
It shows this diagnostic:
Quote:
Diagnostic Test
1. CHECK FOR ACTIVE DTC
With the scan tool, read the DTC's.
Cycle the ignition switch from off to on, leaving the ignition on for a minimum of 10 seconds.
Does the scan tool display this DTC as active?
Yes
Go To 2
No
If the DTC is stored, check for an intermittent condition. Using the wiring diagram/schematic as a guide, visually inspect the related wiring harness connectors. Look for broken, bent, pushed out, or corroded terminals.
2. TRANSMISSION RANGE SENSOR
Turn the ignition off.
Disconnect the Transmission Range Sensor harness connector.
Turn the ignition on, wait 30 seconds.
With the scan tool, read TIPM DTCs.
Yes
Replace the Transmission Range Sensor in accordance with the service information.
Perform BODY VERIFICATION TEST VER 1 (Refer to 8 - ELECTRICAL/ELECTRONIC CONTROL MODULES - STANDARD PROCEDURE)
No
Go To 3
3. ENGINE CONTROL MODULE (DIESEL)
Disconnect the Diesel ECM C1 harness connector.
Yes
Replace the ECM in accordance with the service information.
No
Go To 4
4. (F962) FUSED IGNITION SWITCH OUTPUT (START) CIRCUIT SHORT TO GROUND
Disconnect the TIPM C5 connector.
Measure the resistance between the (F962) Fused Ignition Switch Output (START) circuit and ground.
Is the resistance below 10K ohms?
Yes
Repair the (F962) Fused Ignition Switch Output (START) circuit for a short to ground.
No
Replace the TIPM in accordance with the service information.
__________________
-Todd
Quote:
- William Shakespeare
- Anonymous
  #8
Old 09-02-2015, 08:10 PM
Broadsands Broadsands is offline
Senior Member
Ride: Jeep Patriot 2.0CRD 6-speed manual, Audi TT 3.2 V6
Broadsands is on a distinguished road
Did you ever find out what this issue was?
Sponsored Links
Advertisement
Reply
Tags
ignition, neutral safety switch, not starting, starter
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
