Patriot 2008 electrical problem - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 03-21-2013, 12:04 PM
Le_Georges Le_Georges is offline
Junior Member
Ride: Jeep Patriot 2008
Le_Georges is on a distinguished road
Arrow Patriot 2008 electrical problem
Hi, im new to Jeep. I always had Honda and Acura's over the last years. I also have some good overall knowledge about cars, but not with electrical problems (also sorry if my english is bad, im french).
Here's my story. 2 months ago, i bought a used 2008 Jeep Patriot North 4WD 2.4L from a used dealership.
Now, couple weeks ago, i went to work with my Jeep and everything was fine. After my shift, 8 hours later, I jumped in car and tried to start and nothing. Battery had power, i could use the radio, wipers, lights were on.. but couldnt start the car. The air bag and check engine lights were on and there were at least 4 or 5 beeps when i put key in, but couldnt start it.
I brought the car to a Jeep dealer and they told me that the problem was the fusebox under the hood. I was like a fusebox that break that easily on a 45,000km car. I had no choice but to get it repaired. Here is my "problem".
After they changed the fusebox (and a 1500$ bill (850$ for the part + job)), lot of electrical "accessories" were not like before and the dealership keep telling me i'm wrong. Here's an example of what changed.
- no more sound when i grab the handbrake,
- doors get locked at 20km/h, before they were locking when i press brake to shift on Drive,
- seatbelt light goes off when i pull belt, it was going off when i locked it before,
- when using wipers with windshield washer, now they wipe 2 times only, they were wiping 3 times before (i checked with a friend who has a 2008 patriot too and they wipe 3 times).
- rear passenger door doesnt lock/unlock anymore,
I know it's nothing important, but i am wondering what happened. Do told me they had to program the new fusebox in the computer..!? never heard of that in my life. But if they changed the computer's program, my question is.. when you change the under hood fusebox, do you ABSOLUTLY NEED to make any changes in the computer?
Also, when they fixed the fusebox, check engine and air bag lights were still on but car could at least start (yay!). The mechanic called Chrysler and they had no clue what was the problem. So they told me it was the PCM. They changed it under warranty.
So, i went to work, parked the car, came back 8 hours later and car would not start. The fusebox and PCM broke like that and bam..
Is this "normal" ? Do fuseboxes and PCM break that easily on these cars with this average kms? Anyone ever experienced something like this?
Any ideas?
Thanks and sorry for the long story
Sponsored Links
Advertisement
  #2
Old 03-21-2013, 12:21 PM
cmoore's Avatar
cmoore cmoore is offline
an odd member
Ride: 2011 Jeep Patriot 4x4 sport
cmoore has a spectacular aura about
Except for the back door not unlocking the rest of the stuff sounds like it was an update to the Software in your Jeep... All of those things are what my my Pat has done from day one...
And for the PCM and fuse box… It does not sound like a normal wear and tear that most of the users here experience... You may have some wiring problems somewhere that is causing the two to short out some how... Some of the other members here will probably more of help but as far as most of your issues those are just updates
__________________
An Angry Mind is a Narrow Mind
  #3
Old 03-21-2013, 01:29 PM
MB's Avatar
MB MB is offline
Seriously Addicted
Ride: 2008 Wrangler Unlimited Rescue Green
MB is a jewel in the rough
^x2
I was going to say most of that sounds normal to me except for the door issue with it not locking /unlocking
__________________
MB's Build Thread
  #4
Old 03-21-2013, 03:32 PM
Terasec's Avatar
Terasec Terasec is offline
Senior Member
Location: from NYC and have places in upstate NY and in PA
Ride: 2007 Patriot, Light Khaki, 4x4, CVTII FdriveII,
Terasec is just really nice
Send a message via AIM to Terasec Send a message via Yahoo to Terasec
Fuse box controls a lot more than just fuse voltage function.
Hence the name tipm totally integrated power module.
As it contains more functions. Things will fail.
As for price, install/labor shouldn't be much.
1 hour labor.
Cost here in US is as follows at the dealer.
Tipm: $700
Install/labor: $100-$125
Reprogramming: $85.
And yes it has to be programmed with cars VIN#
Car won't function unless tipm is programmed.
  #5
Old 03-22-2013, 03:28 AM
goguadi's Avatar
goguadi goguadi is offline
Senior Member
Location: Breaza , Romania and Nea Trapezounta-Katerini , Greece
Ride: 2.0 CRD LTD Patriot, ,3.0 crd Commander
goguadi has a spectacular aura about
Any ideas?
check my thread on the relay box under the left fender behind the plastic wheel well cover.
i had a similar issue and it was pinned to 2 damaged relays due to corrosion.
__________________
[OlllllllO]
Eat,sleep,Jeep
2.0 CRD Limited,Lifted with StuCoils,1.25" wheel spacers,engine-transmission&gas tank skidplates,6000K HID conversion kit,rear parking sensors,tow bar,245/65/17 Lassa Competus A/T on League 208 Nocturne rims (summer tires),235/65/17 Kingstar RW07 on stock rims (winter tires), chrome grille,Patriot door sill guards,Startech Lifestyle leather interior,Husky Liners,Jeep aluminium pedal and dead pedal set.
Nothing like the sweet smell of Diesel
  #6
Old 03-22-2013, 03:01 PM
99_XC600's Avatar
99_XC600 99_XC600 is offline
Senior Member
Ride: 2006 Jeep Liberty
99_XC600 is on a distinguished road
On the Jeep...actually most vehicles there are 3 major components in the electrical system. They are the:
PDC - Power Distribution Center - Basically the fuse box and junction point for the wiring harneess and fuses
BCM - Body Control Module - Controls all things attached to the Jeep, (Radio, Wipers, lights, horn, remote entry etc etc)
PCM - Power Control Module - Controls all aspects of the engine , transmission and cooling
From reading the description it sounds like they changed the BCM or Body Control Module. When replacing any computer, the component needs to be flashed with the correct VIN otherwise it may not have the correct software. From everything you mention it sounds like they put in a new BCM and never flashed it.
One thing you didn't mention..Was this a Jeep/Chrysler dealership that did the repair? Since the software and tools are proprietary and only the dealership can do the repair correctly
  #7
Old 03-22-2013, 06:04 PM
2012 Cherry Patriot's Avatar
2012 Cherry Patriot 2012 Cherry Patriot is offline
Senior Member
Ride: 2013 Nissan Rogue SV FWD w/ Premium Package
2012 Cherry Patriot is on a distinguished road
Thats about normal. Mine is a 12 and does all those things since day one. Sounds like you got 11+ updates on an 08, lucky man! lol
However for the PCM and fuse box should not have broke. But that may be the cause of the 11+ updates in the PCM on 08 parts.... I really dunno, just throwing suggestions.
__________________
[SIGPIC][/SIGPIC]
  #8
Old 03-22-2013, 08:47 PM
Junior Member
Yes repairs were done at a Chrysler/Jeep dealership. And yes, they changed the TIPM (got the right part number on bill) and the PCM (have no bill, it was on warranty). That's what they told me.
This looks like they did an update but like you said, this looks like a '11 update in a '08.. they should have left the original '08 program in the '08 car imho...
Now if i have more problems later, i'll have to go back to the dealership and start over and pay again ><
That's why i asked if you guys, have a '08 patriot and if they do those things and if the program they put in, is the right one. Because at the dealership, they dont even believe me when i told them that lot of things have changed.
And no, that is not the problem why TIPM and PCM broke. I (and they) really have no idea. Like i said, i parked the car a 11:00PM (i work at night) and at 7:00AM, put the key in and car wont start even with power in battery and everything else working.. We even tried to "boost?" the car and nothing..
And thanks guys for taking some time to answer my questions! much appreciated
  #9
Old 03-31-2013, 01:37 PM
Junior Member
Well, after the TIPM and PCM were replaced, Check Engine Light came back yesterday
Also, happened once, Alarm system light went on last week... dont know why because there is no alarm system on car.. wtf?
Going back to the dealership this week...
  #10
Old 03-31-2013, 09:54 PM
99_XC600's Avatar
Senior Member
All Chrysler products since 2005 have a anti-theft system built into them. It's called the SKIM system and works with a transponder located within the key fob.
If you look at the ignition on the column, you will see a plastic ring around it. This is actually the atteana for the system and will read the transponder of the key when it's inserted into the ignition.If it doesn't match, the security light will become active and it will not allow the vehicle to start.
All I can say is be patient. Electrical issues absolutely suck. I had to deal with a major issue with my Liberty last year and I became well versed with all of the electrical systems in the Jeep. It even took the dealer 6 weeks to chase down the issue before it was finally fixed. In the end, my issue was caused by a broken wire from the gauge cluster to the ECM.
  #11
Old 04-02-2013, 04:29 PM
Junior Member
I was wondering if the firmware version installed on my Pat can cause these troubles? I mean, when i had issues a couple weeks ago, if they put in a firmware for 2011+ Patriot, can it causes problems to my 2008? Do car's year and firmware version needs to match or a 2011 firmware can fit in any Pat's ?
Like i said earlier, i noticed many electrical differencies before and after my problem. So, that means the firmware wasnt correct when i bought the Jeep. That also means someone did some work on the PCM and/or TIPM (was the car stolen? had a major accident? i really dont know yet). But i will try to get some infos from Chrysler...
  #12
Old 01-04-2014, 02:53 AM
Patriot2010's Avatar
Patriot2010 Patriot2010 is offline
Junior Member
Patriot2010 is on a distinguished road
Talking CrazyWild Patriot
Jeep Patriot 2010, built / bought late 2009
From what I see here, the problem I am having is due to BCM? I just had the software update done per recall, and my car is going beserk! It's been a couple weeks, but it started with dead battery , twice recharged at home. Tonight, after driving to the store and back, in terribly cold weather, I made sure everything was off when leaving. I had to go back out, and tried to lock with key remote, did not see interior lights come on when unlocking. I went inside and it was dinging, even with everything off. All warning lights on, funny sound coming from radio area, lights dimming, brights on but not. car would not lock/unlock...like aliens had been there. Map lights on but dim and could not switch off. Then the headlights dimmed, eventually one went out while other was on. Oh really?!
Will they charge me for correcting this bull? Will they tell me it was something else?
I love my Jeep regardless. It's great on the highway, and grips nicely when the Neon would not!
  #13
Old 01-04-2014, 10:28 AM
todde702's Avatar
todde702 todde702 is offline
Senior Member
If you look in the owners manual, some of those things are user changeable. For example, how the doors lock/unlock can be changed by doing a series of key on/off cycles and pressing the lock button on the door within a certain amount of time.
__________________
-Todd
Quote:
- William Shakespeare
- Anonymous
  #14
Old 05-07-2014, 02:31 PM
Jeepharness Jeepharness is offline
Junior Member
Jeepharness is on a distinguished road
I have a 2008/170.000. I adore it even when I couldn't start it in a snow storm. I've changed clutch switch - no go.
At dealership despite diagnostics at over 100 bucks nothing was found.
Car started but the next day it didn't.
Long story short: there is a black plastic box on driver side under the hood, below the headlight with four
relays. It is not sealed and all road and weather gets into it. Delicate relay fuses corrode and loose contact with the connecting wire harness. I pulled it up, opened, removed relays and white plastic seat, bought two new relays, inserted new wires, reinstalled relays, marreted new wires to thin grey with red stripe(three were loose - engine fan, starter and something else) wrapped box in plastic shopping bag and pulled it high beside fuse box, which is good and doesn't need replacement. Did it in March and so far no problem. Don't let yourself to be pulled in replacing whole wiring an the box. Get a good one from salvage, cut wires as long as possible and connect wires colour to colour. Takes some time and right crimpers, but it is way less than $1500 or more at the shop. And you'll feel good. When done, do not forget to wrap it up and place as high to the fuse box as you can, secure with a bungee art two. Have fun.
  #15
Old 05-07-2014, 03:31 PM
goguadi's Avatar
Senior Member
exactly what happened to me in feb 13.
found two corroded relays,one with a broken pin.
wrote a thread on that.
wrapped the whole thing in a plastic bag.
no issues since.
__________________
[OlllllllO]
Eat,sleep,Jeep
Sponsored Links
Advertisement
Reply
Tags
2008, fusebox, patriot, pcm, tipm
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
