New to Site, HELP with 2007 Jeep Compass Vibration - Jeep Patriot Forums
Notices
Newbie Check-In First Post? Make your big introduction here.
Reply
Thread Tools Display Modes
  #1
Old 01-28-2013, 03:23 PM
kggilbert2 kggilbert2 is offline
Junior Member
kggilbert2 is on a distinguished road
We are experiencing an issue with a 2007 Jeep Compass, CVT transmission, 2.4L. There is a bad vibration at approximately 30-40 mph. So bad that it feels like you are going over rumble strips in the road. It stops when you let off the gas. Not present at idle. It's not the transmission, not the axles. Both had been replaced and the problem persists. Very weird. Thought it was possibly the drive shaft but it only does it between 30-40 mph. Any suggestions?
Sponsored Links
Advertisement
  #2
Old 01-28-2013, 03:34 PM
K Dubya's Avatar
K Dubya K Dubya is offline
Member
Ride: 2012 Patriot
K Dubya is on a distinguished road
Can you tell where the vibration is coming from? or where you feel it the most? Front, back, all 4 tires, steering wheel, floor, seats? etc.
Can you give more info on the replaced parts? how long ago, who preformed it, etc.
You said it stops when you let off the gas. If you press the gas pedal again while still going 30-40 does the vibration resume? Does the Vibration stop after 40 MPH?
Also, welcome to the site! I hope someone here can help with your problem.
__________________
  #3
Old 01-28-2013, 04:25 PM
Junior Member
thanks so much for the welcome. I'm a mechanic that owns a transmission shop. It's coming through the steering wheel, don't feel it anywhere else. Yes, when you let off the gas then hit the gas again, it usually starts again. Transmission was rebuilt 2 days ago and the axles were replaced today. About 10 minutes ago, I just took out the rear drive shaft, plugged the transfer case and drove it, no more vibration. However, if it was the drive shaft itself it should vibrate continuously, not only at 30-40mph. I am leaning towards something in the rear differential or the AWD unit. Any ideas?
(this is actually the wife/secretary doing the posting, he hates typing Thanks again for the welcome and for any ideas or insight)
  #4
Old 01-28-2013, 05:06 PM
K Dubya's Avatar
Member
Ride: 2012 Patriot
If the vibes stopped after the drive shaft removal, then I would assume the culprit is the drive shaft or one of the components either side of it.
I thought that an imbalanced or warped drive shaft would resonate more at a certain RPM range.
Wouldn't the diff and awd unit still be functioning/rotating/working without the drive shaft in place?
Do you have a way to check if the shaft is balanced and straight? or a spare one to test drive with?
I'd put my money on the drive shaft, but I'm not mechanic, and I've been wrong before.
__________________
  #5
Old 01-29-2013, 10:13 AM
FailWheelDrive's Avatar
FailWheelDrive FailWheelDrive is offline
Regular Schlub
Ride: 01 JGC, 04 GTO, 08 1125R
FailWheelDrive has a spectacular aura about
Send a message via Yahoo to FailWheelDrive
Welcome to the site.
If you haven't already read about it here, you'll find the the Patriot has some weak links in the front end that may be the culprits for your wobbling problem.
Check your balljoints & tie rod ends. If anything looks suspect, swap it out with a Moog part.
__________________
Quote:
JoeP: How disappointed was I to discover that 'blown' in this context was used to mean 'broken' and that 'tranny' was short for 'transmission'.
  #6
Old 01-29-2013, 11:16 AM
Dangerous Dangerous is offline
Junior Member
Dangerous is on a distinguished road
Have you tried putting it in 4wd to see if it changes? It might be a problem with the electronic coupler.
__________________
  #7
Old 01-29-2013, 01:54 PM
Arthur's Avatar
Arthur Arthur is offline
Senior Member
Ride: Patriot 2.4L 2013 / '94 Wrangler - Sahara
Arthur is on a distinguished road
Welcome! I hope your troubles get fixed!
  #8
Old 01-29-2013, 01:59 PM
PatriotMB's Avatar
PatriotMB PatriotMB is online now
Seriously Addicted
Ride: 2010 Patriot Latitude 2.4L Natural Green
PatriotMB is a jewel in the rough
Well im not a mechanic, but if its only happening during acceleration could it be the motor mounts?
__________________
2010 Jeep Patriot Latitude "Green Machine"
MB's Build Thread
  #9
Old 01-29-2013, 02:27 PM
willsapples's Avatar
willsapples willsapples is offline
Senior Member
Ride: '08 Patriot CRD LTD Steel Blue FD1
willsapples is on a distinguished road
Welcome. Could it be the wheels (front particularly) that need balancing?
Sponsored Links
Advertisement
Reply
Tags
cvt transmission, jeep compass, vibration
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
