Dealer flashed my CVT today - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 01-16-2013, 05:36 PM
NHPATRIOT's Avatar
NHPATRIOT NHPATRIOT is offline
Senior Member
Ride: 2011 Patriot Latitude 4WD FDI
NHPATRIOT will become famous soon enough
While at the dealer today having things worked on( re: suspension check and adjust speedo for new tires )they did the CVT flash that has been out for a while to improve shift performance. At 1st I was actually kind of upset they did it as I had read from others that it has hurt their MPG a bit. I had told them before not to do it but the new guy with good intentions did it today. However, after driving the vehicle now I am all for it. Makes a big difference(IMO) in how the CVT performs. It also seems much quieter? less ""buzzy". Hopefully the MPG doesn't go down as my MPG #'s have been stellar so far.
__________________
Royal Purple
Sponsored Links
Advertisement
  #2
Old 01-16-2013, 06:21 PM
SBDFAN's Avatar
SBDFAN SBDFAN is offline
Railroad photographer
Ride: 2013 Patriot and 2012 Compass
SBDFAN will become famous soon enough
No difference in MPGs for us after the update. Made a world of difference with the CVT performance.
__________________
Charles Burgess
2013 Jeep Patriot Latitude
Black outside/Dark Slate Gray inside
4x2 2.4L CVT
Trailer Tow Prep Group-Security and Cargo Convenience Group-Uconnect 430-Uconnect Voice Command with
Bluetooth---Mods: K&N air filter, stainless steel exhaust tip, 2.4L badge, Jeep shift knob, Mopar door sills, bulldog89 stickers
2012 Jeep Compass Latitude
Bright White/Dark Slate Gray
4x2 2.4L CVT
Uconnect® Voice Command with Bluetooth-Uconnect® 430-Security and Convenience Group
  #3
Old 01-16-2013, 07:30 PM
Metaxa's Avatar
Metaxa Metaxa is offline
Swollen Member
Ride: 2011 Patriot
Metaxa is a jewel in the rough
After my flash I lost 1 mpg, paper calculated.
But after a while it came back and more.
I'm going to have to get another cycle of coming out of winter and into summer to see if the bump was due to that or not.
Anyway, had the negative cable off a couple of times for various reasons, drove, etc and it seemed to all level out.
I know what you are saying about the drive-ability tho...everything is tweaked a bit from throttle tip in to noise to rpm at cruising...seems to stay at 2,000 when cruising regardless of actual speed. Unless you are over that 60-65 mph sweet spot.
__________________
It's okay, John. If you were here with me now, I'd give you a very long and large hug. I'd listen to you. Hear you out. Discuss potential solutions for the problems we've got. I feel like after such a session you'd feel better, perhaps even "good," but either way, I just wanna reach out to you on this sad, sad afternoon. Chin up, John! Let's get through this.
  #4
Old 01-16-2013, 08:29 PM
SteveReject SteveReject is offline
Senior Member
Ride: 2013 Jeep Patriot Limited '92 Chrysler Lebaron GTC
SteveReject is on a distinguished road
I should be safe and probably not need my cvt flashed since it's a 2013 right?
__________________
2013 Jeep Patriot Limited FWD
True Blue, 2.4L, CVTII, K&N drop in, BA speakers with Dynamat in doors, Viper 2-way Alarm, Weathertech floor mats, Mopar Splash Guards, misc LED lights
  #5
Old 01-16-2013, 10:01 PM
PPiekarski PPiekarski is offline
Senior Member
Ride: '12 Latitude 4x4 in Copperhead Orange Pearl
PPiekarski has a spectacular aura about
Send a message via AIM to PPiekarski
yes, even the 2012 are fine
__________________
- Engine/Transmission/Fuel tank skidplates - Front tow hooks - 2" tow hitch w/ hook attachment -Deluxe mud guards - Rockford Fosgate R1693 front and rear door speakers w/crutchfield wire adapters - Weathertech digital fit mats/Husky cargo Liner - AVS window visors and bug deflector with Jeep emblem - 2" stubby antenna - UltraGauge - Exhaust tip - RRO Lift - Romik running boards - 1.25" spacers - Jeep plate frames - Mopar door sills - K&N Air Filter -
  #6
Old 01-17-2013, 10:50 PM
zettler zettler is offline
Senior Member
Ride: 2009 Jeep Patriot Sport
zettler is on a distinguished road
I do not think they have touched mine and it's a 2009 - any thoughts out there?
  #7
Old 01-18-2013, 12:20 AM
Medic311 Medic311 is offline
Senior Member
Ride: (Patriot pending...I hope)
Medic311 will become famous soon enough
Send a message via AIM to Medic311 Send a message via MSN to Medic311
i got mine flashed with Windows 8, but there's no Start button
(thank you, thank you)
  #8
Old 01-18-2013, 07:17 AM
Creation's Avatar
Creation Creation is online now
Senior Member
Ride: 2008 Jeep Patriot Steel Blue Metallic
Creation is on a distinguished road
Re: Dealer flashed my CVT today
Nor does it work properly!
Sent from my Galaxy S III using Autoguide. Please excuse my spelling.
  #9
Old 01-18-2013, 03:25 PM
Senior Member
^^^^ What he said!
__________________
  #10
Old 01-18-2013, 07:59 PM
Ignatz's Avatar
Ignatz Ignatz is offline
Senior Member
Ride: 2008 Patriot 4x2 2.4 CVT
Ignatz has a spectacular aura about
My '08 CVT failed a couple weeks ago at 110,000 miles and was replaced under lifetime warranty. Can I presume my new tranny was set to whatever the new specs are? Honestly I didn't notice a difference, but I'll try to pay attention.
  #11
Old 01-19-2013, 07:38 AM
NHPATRIOT's Avatar
Senior Member
The flash is only supposed to be done if the customer complains about the shifting. Some dealers like mine will check for flashes available and do them anwyay which is how mine got done. Other dealers are like mine BUT they just do them and never tell the customer it was done so some members w/ 2011 and earlier models may have already had it done and just not know it.
__________________
Royal Purple
  #12
Old 01-19-2013, 09:59 AM
hypno444's Avatar
hypno444 hypno444 is offline
Member
Ride: 2011 Jeep Patriot Latitude, 2009 VStar 650
hypno444 is on a distinguished road
I had mine done right after I bought it. (with 27K miles on it). Dealer asked if I was having problems and I just said "No, I like to be up to date." So, they did it. Did seem to make it a bit quieter.
__________________
[/URL]
  #13
Old 01-19-2013, 10:42 AM
aroundincircles's Avatar
aroundincircles aroundincircles is offline
super duper moderator
Ride: 2012 Jeep Patriot FDII
aroundincircles will become famous soon enough
Quote:
Not necessarily, as the CVT itself is not flashed, but the ECU. and if they were just dropping in a new part, it wouldn't need new software as its the same part. I would ask the dealer if they updated the software while it was in for work.
  #14
Old 01-30-2013, 10:23 AM
Nick77 Nick77 is offline
Junior Member
Ride: 2011 Jeep Patriot Latitude X
Nick77 is on a distinguished road
Had mine flashed last night after owning it for a few months. Bought it with 28k miles, now has 30k. Felt a little sluggish at times so fingers crossed that this helps. Not expecting huge improvements but slight would be nice.
Btw, for those interested I just walked in and said it seemed to be shifting funny. They looked up my car in the system and then said they would perform the flash to see if it improves. Took less than 30 minutes in and out.
  #15
Old 01-30-2013, 11:33 AM
John Cu's Avatar
John Cu John Cu is offline
Junior Member
Ride: '11 Silver Patriot
John Cu is on a distinguished road
That sounds good, i don't know if my 2011 need it...
__________________
'11 Silver Patriot..
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
