HID issues finally worked out... ghetto style - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 12-08-2012, 06:03 PM
FailWheelDrive's Avatar
FailWheelDrive FailWheelDrive is offline
Regular Schlub
Ride: 01 JGC, 04 GTO, 08 1125R
FailWheelDrive has a spectacular aura about
Send a message via Yahoo to FailWheelDrive
Question HID issues finally worked out... ghetto style
So I haven't said anything about this on here but lately my HIDs have been flipping off and then back on at seemingly random intervals. Sometimes 2 or 3 times in a row. I was pretty bad the other night coming home from the airport, a guy in front of my actually pulled over so I killed my HIDs and rolled home with my Off Road lights on.
The way it's wired up is one headlight power wire goes to a relay which flips on the HIDs. The original headlight power wire was cutting out here and there (something to do with testing to see if the light was out or something I think).
The only way it works seems to be to apply a load to the headlight power. We tried on of those resistors for LED turn signals as a test and it worked but they aren't designed for constant use so it obviously isn't a good long term fix.
Me & the guys at the shop ended up just wiring in a small bulb mounted in the engine bay. It works and isn't unsafe or anything... just kinda ghetto for my tastes.
Any ideas on how to safely apply a load to the headlight power in a non-ghetto style fashion?
PS: While I was at the HID/LED shop I had them install a 40" LED light bar and a really cool front hitch cover that looks like a claymore. I'll post pics once I get me jeep washed up.
__________________
Quote:
JoeP: How disappointed was I to discover that 'blown' in this context was used to mean 'broken' and that 'tranny' was short for 'transmission'.
Sponsored Links
Advertisement
  #2
Old 12-08-2012, 10:50 PM
goser's Avatar
goser goser is offline
Senior Member
Ride: 2008 Patriot FDII Ltd.
goser is on a distinguished road
You can see a resistor setup in my post here:
http://www.jeeppatriot.com/forum/showthread.php?t=62827
I also have a capacitor sitting on my desk that I'll get around to testing... someday...
  #3
Old 12-09-2012, 08:55 PM
Regular Schlub
Thanks for posting the link. I searched for that thread while I was at the shop but couldn't find it.
I tried a resistor that looks similar to the one you have... I was getting so hot that I didn't think it would last for very long. Does yours get that hot?
We tested a capacitor and it didn't work.
__________________
  #4
Old 12-10-2012, 09:14 AM
croat's Avatar
croat croat is offline
Senior Member
Ride: Tiburon
croat has a spectacular aura about
You can buy similar resistors on eBay with much larger heat sinks BTW.
__________________
Those who desire to give up freedom in order to gain security will not have, nor do they deserve, either one.
~Thomas Jefferson
  #5
Old 12-10-2012, 11:23 AM
Regular Schlub
Quote:
That sounds like a better long term option, I just ordered some. Thanks!
__________________
  #6
Old 01-03-2013, 07:04 PM
ponyboy's Avatar
ponyboy ponyboy is offline
Member
Ride: 2008 Silver Patriot/ 1956 Dodge Coronet
ponyboy is on a distinguished road
where did you wire in the light bulb? the flicker is killing me.
  #7
Old 01-03-2013, 11:01 PM
Regular Schlub
All I needed to do on mine was introduce a load on the relay circuit, so I had the bulb wired inline on the positive wire before the relay.
I did end up wiring in one of those big resistors and it's working great!
__________________
  #8
Old 01-04-2013, 02:54 PM
ponyboy's Avatar
Member
Yeah I think ill go grab a resistor. I know there are tons of threads on the issue... but how did you wire in the resistor? to and from what wires? just to stay consistant with a solution that I know has worked for you. Thanks for the help!
  #9
Old 01-04-2013, 03:35 PM
Regular Schlub
I wired the resistor in just like the bulb. Inline with the old headlight power wire that's being used as a signal to the relay so it sees a load. I screwed the resistor to the inner fender on the driverside of the engine bay.
__________________
  #10
Old 01-06-2013, 11:22 AM
goser's Avatar
Senior Member
No, the resistor doesn't get very hot at all. IIRC I calculated 25W power dissipation to be more than enough for 200 ohms. Can always go to 50W if you're worried.
  #11
Old 05-07-2013, 04:56 AM
kostas kostas is offline
Junior Member
kostas is on a distinguished road
My friend i am a new member here and i want your help.i just install a hid kit in my patriot,with a relay which takes signal from the one headlight in drivers side and is turning on and off every 2-3 minutes.what did you do to avoid the problem?what size of resistance did you use and how many?
  #12
Old 05-10-2013, 04:37 PM
lOStjEEp's Avatar
lOStjEEp lOStjEEp is offline
Senior Member
Ride: 2008 Jeep Patriot
lOStjEEp is on a distinguished road
Ahhh, reading this reminds me of how mine did the same thing when I first installed them. It can be a pretty complex install, definitley not "Plug N Play" like most vehicles. I have 2 resistors for each bulb, and I've had my fair share of HID issues but after turning it over to some professionals I have a reliable kit in there now finally! Hope your issues get resolved!
__________________
Rioting since 2008. Only tasteful mods... |2.4L| |Steel Blue| |Custom 8000k Hi/Lo HID Kit| |Replacement interior HID LEDs| |20% tint all around| |NightShade tail lights & turn signals| |Plastidipped alloy wheels| |Upgraded starter & brakes| |Debadged front; black Jeep logo on rear| Black muffler| +100kmi; original owner|
  #13
Old 05-11-2013, 02:11 AM
Regular Schlub
kostas: I had my HIDs working perfectly by installing the above mentioned resistor inline on the factory headlight power wire that is used to trigger the relay.
Basically what happens is the computer that controls the headlights is looking for a certain range of resistance/or current draw (or whatever) and the relay by itself doesn't consume enough power so the computer keeps testing the circuit (turning it on/off).
The resistor provides enough draw on the factory headlight power wire to trick the computer. Just make sure that you mount it up and away from anything that it will melt because it gets pretty freakin hot when the headlights are on.
__________________
  #14
Old 05-13-2013, 05:07 PM
Junior Member
what resistor did you use?200ohm 50w?only in low lights?
  #15
Old 05-13-2013, 09:32 PM
Regular Schlub
I don't remember the specific values of the resistor. It's just the same heavy duty one that people use to cure the fast flash of LED turn signals.
On mine I only had to use the resistor on the low beams. Apparently the high beam drew enough current to not throw the computer that controls the lights into a seizure.
__________________
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
