Patriot Stalling Strangely - Jeep Patriot Forums
Notices
Reply
Thread Tools Display Modes
  #1
Old 11-25-2012, 09:56 PM
florianne florianne is offline
Junior Member
florianne is on a distinguished road
I do love my 2011 Jeep Patriot. Bought it new 15 months ago and it has been great for me until a couple weeks ago. I am wondering if anyone has experienced the same problems. Took it to 2 different dealership but they don't seem to find much wrong with it.
It started a couple weeks ago. I noticed the clock had reset and engine light was on and it happened while it was not running. After 5-10 min. the engine light went out. Came back on a couple days later and took it in the dealership, they found nothing. Just a battery disconnect code. While backing out a couple days later it stalled and was totally dead, then a few minutes later it was fine again, without doing anything to it. Two days later again, went to the bank, came out and it would not start, totally blank dead. 20 minutes later it started and was fine. 2 days later, while backing out it stalled dead again. It started a couple minutes after but I could not drive more than 60km an hour, and the slightest hill would go down to 40km/hr. It would not shift in 3rd gear, and lights were dimming high and low high and low. Had it towed to dealership, Before the tow truck driver got here I started it to make sure it would and it did. 20 min. later the tow truck driver got in and again it was dead. 2-3 min. later it started. Although the dealership has tried to reproduce the same thing, they could not and tells me there is nothing wrong. The only code they get again is a battery disconnect. There is obviously something not functioning properly. Stalling while backing out on busy street is very scary. Once I have it in park to try restart it I cannot put it neutral to push it out of the way. So if anyone understand this or has had that problem, please answer to this post.
Thanks.
Sponsored Links
Advertisement
  #2
Old 11-26-2012, 08:26 AM
MrJeepR44's Avatar
MrJeepR44 MrJeepR44 is offline
Senior Member
Ride: 2012 Rav4 Limited 4wd V6, former 2011 Limited FDII
MrJeepR44 is a glorious beacon of light
That's sounds like a loose cable off the battery or alternator. I've also read of rodents chewing through wiring.
  #3
Old 11-26-2012, 08:32 AM
todde702's Avatar
todde702 todde702 is offline
Senior Member
The dealer should be checking all battery connections and cables. If those are all fine, then my next guess would be a bad TIPM and they should keep the vehicle to figure that one out. Random stalling out is a very unsafe situation and it endangers you and anyone behind you when it happens. Get them to take this a little more serious then just pulling codes.
__________________
-Todd
Quote:
- William Shakespeare
- Anonymous
  #4
Old 11-26-2012, 08:58 PM
JeepFan JeepFan is offline
Senior Member
JeepFan will become famous soon enough
Don't forget to check the battery under load too. as Todde and the others say, it's most likely a bad cable connection either at the battery or ground, but sometimes a battery going bad will mimic the same sort of problem. When the detected voltage drops too much the system shuts down.
  #5
Old 11-27-2012, 12:57 AM
2012 Cherry Patriot's Avatar
2012 Cherry Patriot 2012 Cherry Patriot is offline
Senior Member
Ride: 2013 Nissan Rogue SV FWD w/ Premium Package
2012 Cherry Patriot is on a distinguished road
See if you can record whats happening day by day. Thats what I did with mine, and when I showed it to the service manger, they insisted on keeping it for 5 days, and the tech even drove it home the last night.
  #6
Old 11-28-2012, 10:26 AM
JeepCares JeepCares is offline
Senior Member
JeepCares has a spectacular aura about
florianne -
Is the problem still going on?
__________________
Ryan
Jeep Social Care Specialist
  #7
Old 11-28-2012, 10:46 AM
Junior Member
my jeep stalling
Thanks for all the feedback. The dealership kept it for a few days and they did drive it home after they cleaned up a corroded ground, they explained. The problem never reproduced itself with them. They also questioned me as to who had installed the remote starter, which was already in when I bought it. But they seem to have done a good job. I have had it back for 2 days now and I have had no stalling - yet. I hope it is cured.
Thanks again for the concerns, Great informative site.
  #8
Old 11-01-2014, 08:53 PM
Aurora Aurora is offline
Junior Member
Aurora is on a distinguished road
I am having the same problems of stalling while driving the Jeep Patriot on the highway. I am not alone in this complaint. Apparently it has to do with the transmission which Jeep changed in both the Patriot & Compass. The dealers don't know how to fix it and Jeep doesn't want to deal with it.
  #9
Old 11-02-2014, 10:21 AM
PPiekarski PPiekarski is offline
Senior Member
Ride: '12 Latitude 4x4 Copperhead Orange Pearl FD 1
PPiekarski has a spectacular aura about
Doubt it's the transmission, have you had the gas tank recall done yet?
__________________
Engine/Transmission/Fuel tank skidplates-Front tow hooks-2" Curtis tow hitch w/ hook attachment and wiring harness-Deluxe mud guards-Rockford Fosgate R1693 front and rear door speakers w/crutchfield wire adapters-Weathertech digital fit mats/Husky cargo Liner-AVS window visors and bug deflector with Jeep emblem-Exhaust tip-RRO Lift-1.25" spacers-Jeep plate frames-Mopar door sills-K&N Air Filter-Hankook Dynapro ATM RF10 235/65/17-Mopar Cross Bars
  #10
Old 11-02-2014, 06:32 PM
bwpakk bwpakk is offline
Senior Member
Ride: '08 FDl 4x4 Tow pkg Reese hitch ScanGauge ll
bwpakk is on a distinguished road
What year Patriot are you referring too, having transmission changed in? Which engine, transmission, (power train option) do you have? One hit negative wonder (lack of info)?
__________________
FDl Sport 4x4 E Tow pkg Thule Roof Rack System Reese Hitch Scangauge ll 15" Ravine Alloys Dunlop GrandTrek 235/70/15 Stu's coils
  #11
Old 11-02-2014, 06:57 PM
Metaxa's Avatar
Metaxa Metaxa is offline
Senior Member
Ride: 2011 Patriot
Metaxa is a splendid one to beholdMetaxa is a splendid one to behold
Quote:
If you go into the wayback part of this site you see, over and over, years old threads resurrected with a new complaint. Most often by a poster with very low post count that you never ever see again.
Then a couple of other very low volume posters chip in and then the old thread again sinks back into obscurity.
This thread was almost 2 years old when it was posted to, with as you state a very low info post.
I think its robots myself, employed by other vehicle manufacturers.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
