Cross Bar Project
6K views 12 replies 10 participants last post by  karlo
I wanted to get the maximum spread possible on the factory roof rack, so I decided to make my own cross bars. The main reason I did this was for hauling my canoe. I like to spread the support points as much as possible.
Parts List:
8' of 1" x 1" x 1/8" square tube $15
4 - slotted riv nuts 1/4-20 Free (I had them already)
4 - 1/4 20 knobs $10
4 - rubber washers $2
4 - 1" square caps $2
4 - Torx head 1/4 20 machine screws 1 1/2" long $5
1 - can black paint Free
$34 , so far....
First, I drilled the holes for the riv nuts 3/4" back from the roof rack bar caps. I painted the edge of the hole prior to installing the riv nuts and I cleaned out all the drill shavings.
Then using the riv nut installation tool installed all four riv nuts. You can put quite a bit of pressure on the riv nuts. You don't want to rip the riv nuts/bar apart, but you need enough pressure so that the nut won't turn in use.
Next, I cut the bars for a 2" overlap on each end, drilled the bars to match the riv nut width and painted the them black. I used black RTV to install the end caps on each bar.
For installation, I used a stainless machine screw with lock and flat washer on top and a rubber washer on the bottom of each bar.
When the bars aren't on, I use the knobs to seal up the riv nut holes. I drilled out some flat faucet washers for the bottom of the knobs and I use teflon tape to help keep the knobs from vibrating out.
I still plan to put on a coat of satin black paint on the bars and I haven't decided yet on what type of rubber to put on the top of the bars. I'm thinking either Buna-n or Neoprene with an adhesive back. This will add about $20 to the project depending on what I choose.
#8 · (Edited)
nice but only one thing won't work for me:
distance between roof and crossbar.
crossbars are too close to the roof and if i mount my ski carriers,i wouldn't be able to put the skis on,as there would be no room for the ski bindings as they face one downwards and one upwards.
i guess it depends what you want your crossbars for.
nice project though,and very neat and clean.
congrats!
#9 · (Edited)
Thanks for the replies! You do need the installation tool for the riv nuts. I may need to raise my bars a little higher when I put my canoe on as well. If so, I'll just add some spacers. I wouldn't want to go any higher than 2-3inches with this set up though. Any higher and I would use two riv nuts per attachment point.
You can buy the riv nuts and tool at Mcmastercarr. I use these guys for all my speciality stuff. They ship fast to my area. I can get anything from them the day after I order it.
#11 · (Edited)
I put some pipe foam on the cross bars temporarily and tried the canoe. It fit fine. Normally, the pipe foam will be used on the canoe rails not the bars, but either way will work. It would be nice to have the front bar up over the front seats and I may end up mounting some Yakima landing pads to the roof to increase the spread. Then I could just use my rear bar. For now, I will see how this works.
Here is a look with just the foam on the bars. This looks pretty good, but would work better with round tubes.
