Where are the Patriots headlight adjusting screws - Jeep Patriot Forums
JeepPatriot.com   JeepPatriot.com
The Jeep Patriot Enthusiast Resource
Notices
Electrical and Audio Discuss stereos, NAV, general wiring, lighting & GPS
JeepPatriot.com is the premier Jeep Patriot Forum on the internet. Registered Users do not see the above ads.
Reply
Thread Tools Display Modes
  #1
Old 01-29-2013, 02:16 AM
paulmackie paulmackie is offline
Senior Member
Ride: 2011 Jeep Patriot North Edition
paulmackie will become famous soon enough
Hi,
Does anyone have a picture of where the 2011 Patriots headlight adjusting screws are.
Thanks
Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
  #2
Old 01-29-2013, 02:22 AM
goguadi's Avatar
goguadi goguadi is offline
Senior Member
Location: Breaza , Romania and Nea Trapezounta-Katerini , Greece
Ride: 2.0 CRD LTD Patriot, ,3.0 crd Commander
goguadi has a spectacular aura about
don't have a pic,but they are on top of the lamp and you have access through the front black console.
you must use an allen type screwdriver.
__________________
[OlllllllO]
Eat,sleep,Jeep
2.0 CRD Limited,Lifted with StuCoils,1.25" wheel spacers,engine-transmission&gas tank skidplates,6000K HID conversion kit,rear parking sensors,tow bar,245/65/17 Lassa Competus A/T on League 208 Nocturne rims (summer tires),235/65/17 Kingstar RW07 on stock rims (winter tires), chrome grille,Patriot door sill guards,Startech Lifestyle leather interior,Husky Liners,Jeep aluminium pedal and dead pedal set.
Nothing like the sweet smell of Diesel
  #3
Old 01-29-2013, 03:19 AM
Senior Member
Hi,
I am not sure if you mean the front grill or some part of the plastic covering the headlights?
Here are pics of my headlight.
https://skydrive.live.com/#cid=C363A...B363ED8368!133
https://skydrive.live.com/?cid=c363a...B363ED8368!134
There is an oval plastic cover over the headlight assembly that is one piece and goes the full width of the car to the other headlight; there is a slot at the front in the centre of each headlight, but I can't see any adjusting screws, do I have to remove the plastic cover to get to the adjusting screws?
Or, do you mean the front grill?
  #4
Old 01-29-2013, 04:45 AM
Metaxa's Avatar
Metaxa Metaxa is offline
Senior Member
Ride: 2011 Patriot
Metaxa is a splendid one to beholdMetaxa is a splendid one to behold
Its 1 in the morning here otherwise I'd run out and confirm but...
I have read on this forum that the adjusting screw is grey plastic and is on the top of the lamp assembly which is under that black plastic shroud that runs from side to side...the one you refer to as "oval plastic cover".
  #5
Old 01-29-2013, 06:28 AM
goguadi's Avatar
Senior Member
as above
__________________
[OlllllllO]
Eat,sleep,Jeep
  #6
Old 01-31-2013, 03:37 AM
Senior Member
Ok, so I found the grey screw, which is accessible without removing the plastic shroud, but it would only adjust the driver's headlight up.
I then removed the plastic shroud and undid two of the three nuts holding the light in place, I had to add 1/4" of shim to both screws to tilt the light to 2 inches below the centre of the headlight bulb at 25 feet; but the driver's side (left) headlight is about 12 inches off centre to the left (shining into oncoming traffic) and there is not enough screw length to add enough shim to align the headlight?
The car is still under warranty, so I will take it to the dealership.
I was just wondering how does the front plastic grill come off? I loosened 7 screws at the top, plus two bolts, but could not see how the bottom of the grill is held in place?
  #7
Old 01-31-2013, 03:42 AM
Metaxa's Avatar
Senior Member
Ride: 2011 Patriot
You have to remove the entire front end to get the grill out...the fender liners come off, the front bumper cover and the valance come off along with the grill.
Its doable with patience and there are threads on here with pictures.
My search skills don't work with more than 4 beer in me so I'll just advise you to use the search bar above...they are here...
And I have not had to aim my Patriot lamps but based on previous vehicles a two inch drop is way too much. You will be lighting the ground immediately in front of you, not down the roadway.
Sponsored Links
Advertisement
Reply
Gear in this thread - Powered by O'Reilly Auto Parts
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Jeep Patriot Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Insurance
Please select your insurance company (Optional)
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2016, vBulletin Solutions, Inc.
