Sound proofing - Page 4 - Jeep Patriot Forums
JeepPatriot.com   JeepPatriot.com
The Jeep Patriot Enthusiast Resource
Notices
Interior Interior questions and modifications.
Seats, dash, rollcages, mounts and misc
JeepPatriot.com is the premier Jeep Patriot Forum on the internet. Registered Users do not see the above ads.
Reply
Thread Tools Display Modes
  #46
Old 12-06-2012, 10:41 PM
Metaxa's Avatar
Metaxa Metaxa is online now
Swollen Member
Ride: 2011 Patriot
Metaxa is a jewel in the rough
Quote:
To keep up with the latest news, be sure to "like us" on Facebook: https://www.facebook.com/?ref=logo#!/GtSoundControl (You might also see what I look like )
Ahem....
__________________
It's okay, John. If you were here with me now, I'd give you a very long and large hug. I'd listen to you. Hear you out. Discuss potential solutions for the problems we've got. I feel like after such a session you'd feel better, perhaps even "good," but either way, I just wanna reach out to you on this sad, sad afternoon. Chin up, John! Let's get through this.
Sponsored Links
Advertisement
  #47
Old 12-07-2012, 12:53 AM
cmoore's Avatar
cmoore cmoore is offline
an odd member
Ride: 2011 Jeep Patriot 4x4 sport
cmoore has a spectacular aura about
Quote:
Originally Posted by Metaxa View Post
Ahem....
I don't have Facebook... Someone go get her picture =)
Sent from my iPhone using AutoGuide.com App
__________________
An Angry Mind is a Narrow Mind
  #48
Old 12-07-2012, 02:16 AM
Metaxa's Avatar
Swollen Member
Ride: 2011 Patriot
OK, I've been thinking about this and I really don't see much difference between soundproofing a music studio and a car.
Except the car is way more trouble I'd bet.
Back in the day I did some roadie work for various bands and I often booked music into my restaurants...so I have observed sound men and etc as they grappled with this or that.
Plus new code says that whenever you duplex or suite a house you have to do sound attenuation between units and I have watched as tradesmen have performed that in rentals for us.
I think (and Tracie, please correc5t me if I'm wrong) that the sound deadeners like gmat and dyna mat don't need to go wall to wall but rather in strips and chunks on the boingy areas.
Then you want an isolation membrane that does go wall to wall. Closed cell flooring underlayment is what I've seen used. It acts as a decoupler between the deadener (gmat) and the barrier. Now, in housing, the barrier is sound rated drywall and acoustical sealants but we did use mass loaded vinyl around electrical outlets and ducts and stuff,
Mass loaded vinyl weighs a pound or so per square foot...it is heavy so you probably only want to use it very judiciously in your vehicle.
You sound proofing guys need to think in layers, using more than just the one product I think.
When we sound proof a basement suite it is mineral wool insulation into cavities that have been generously sealed with acoustical sealant and then sound rated drywall hung on resilient channels so it isn't touching the joists or the insulation. Three layers.
Same with side to side duplexing...gotta break up the sound transmission lines and you do that with decoupling membranes and lots and lots of acoustical sealant and mass loaded vinyl wrapping anything that penetrates...like electrical lines, boxes, heat ducts, etc.
I think if I was to embark on something like this I'd use less of the peel and stick mat but use it more judiciously...then cover the entire panel or area with that floor underlay, make sure it is closed cell foam, and use that new red tape they use in construction...it sticks and lasts forever. I'd then see if that got me what I wanted and if not then I'd look into a top coat of mass loaded vinyl.
Damn...this is going to become my next project...I can tell.
You folks are very bad...I came here a year ago not needing anything on my Patriot and here I am, short antenna, blacked out emblems, de-badged and etc.
Now I'm going to spend even more to make it quieter.
But I'm going to do it out of Home Depot...
__________________
Last edited by Metaxa; 12-07-2012 at 07:26 PM. Reason: spell Tracie's name correctly. sorry.
  #49
Old 12-07-2012, 10:09 AM
cmoore's Avatar
an odd member
I think (and Tracy, please correc5t me if I'm wrong) that the sound deadeners like gmat and dyna mat don't need to go wall to wall but rather in strips and chunks on the boingy areas.
Agreed. When sound proofing our studios, we use wood frames filled with fiberglass insulation, topped with black mesh. It is one of the cheapest and most effective methods. Because of fiberglass's structure it breaks sounds waves down essentially. It's dense in strands so to speak.
We did use wool also, but the fiberglass is both cheaper and more effective. The only real noise I have now is from my tires. While I know it won't be eliminated because of the type of tire, I would like to see an 8-10 db drop. About half as loud. I no longer have the wind noise and cars passing are barely audible. (Thanks tracie)
I want to add a rubberized coating that's durable to the wheel wells in the front. I have achieved about 4-6 db drop so far.
I would do layers, but there is simply not enough room behind the panels to add a layer that's thick enough to have anymore effectiveness...
However, the floors could be done... And it would make the carpet nice and squishy so that is a thought.
My goal right now is the wheel well. The more I can deaden closer to the source the more effective it will be. So I'm thinking spray on bed liner. Or brush on... Might be able to get it thicker... Hmmmm
__________________
  #50
Old 12-07-2012, 11:43 AM
Tracie@GTMat's Avatar
Tracie@GTMat Tracie@GTMat is offline
Junior Member
Tracie@GTMat is on a distinguished road
Quote:
Originally Posted by cmoore View Post
Is it applicable on the exterior of vehicles?
Yes it is, but we do not have testing information as to how well it holds up against the elements. I have a few samples out to the fellas over at the Can-Am Commander forum for exterior placement testing. I'd be happy to pass that info along once I have it available.
You are correct sir. We are actually launching a new butyl based mat within a few weeks and are even looking into adding a foam product as well. I'm still learning a lot about this so I won't have all the answers.
__________________
Tracie @ GTMat | www.gtmat.com | 1-855-GTSOUND
  #51
Old 12-07-2012, 12:19 PM
cmoore's Avatar
an odd member
tracie is quite the attractive one...
and yes ma'am please pass that info along
and one more thing.. where do I need to write my review of the product?
__________________
  #52
Old 12-07-2012, 12:50 PM
Junior Member
I'm sure the guys here would appreciate a review of any product. We are asking that reviews be posted on our Amazon pages so that we build our brand search results. These can be found by searching Amazon.com for GTMat.
I will be sure to pass on the exterior test results as soon as I have them.
__________________
  #53
Old 12-13-2012, 01:48 PM
Junior Member
Our free promotion is ending soon guys. Get yours while you can: 1-855-GTSOUND
__________________
  #54
Old 12-13-2012, 03:08 PM
Doc's Avatar
Doc Doc is offline
Senior Member
Ride: 2012 Patriot Sport 4x4, Mineral gray
Doc is on a distinguished road
So...how'd it work out?
__________________
2012 Mineral Gray Patriot Sport 4X4 CVTII, aftermarket crossbars, plasti-dip badges and wheels, more to come....
"before they call on their God, before they call for their mom, they call on him." United States Army Combat Medic
  #55
Old 12-13-2012, 03:44 PM
cmoore's Avatar
an odd member
With only the mat it definitely helped with some road noise. Probably about 4-6 db. If you have regular tires. (Not noisy ones) it would probably do even better. It did great on wind and other road noise. And it still did help. I was averaging about 90 db in the cabin. I am down to 84-86 on average. Some peaks in the 90s. But very few. I'm going to coat the inside of my wheel wells and see how it affects the cabin
__________________
  #56
Old 01-07-2013, 11:47 AM
Junior Member
Any new results out there?
__________________
  #57
Old 01-07-2013, 11:50 AM
csowers's Avatar
csowers csowers is offline
I don't reMember
Ride: 2008 Jeep Patriot Sport 4x4
csowers is on a distinguished road
Send a message via Skype™ to csowers
Quote:
Tracie, is this promotion for the free 10 SF still going on? Thanks!
__________________
  #58
Old 01-08-2013, 12:21 AM
tt1 tt1 is offline
Senior Member
tt1 is on a distinguished road
Yeah i was also wondering about the results, what ended up happening?
  #59
Old 01-08-2013, 01:08 AM
cmoore's Avatar
an odd member
Mine remains the same conclusion about a 4-6 db improvement. Also using a rubberized coating in the wheel wells and underneath helped.
__________________
  #60
Old 01-08-2013, 11:15 AM
Junior Member
Quote:
We have ended the promotion at this time. We have some new items coming in at the end of this week so keep your eyes peeled on our Facebook page. Thanks for the participation fellas! I'm still antsy to know if anyone tried the Liqui-Damp X on anything. I'll check back in here later.
__________________
Sponsored Links
Advertisement
Reply
Tags
dynamat, sound deadener
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, vBulletin Solutions, Inc.
