Patriot Water Leak Poll - Page 38 - Jeep Patriot Forums
View Poll Results: Have you experienced water leaks?
No leaks - nice & dry inside 709 59.83%
Firewall leak 27 2.28%
Sunroof leak 186 15.70%
Roof leak other than sunroof 148 12.49%
Side doors leak 30 2.53%
Rear hatch leak 127 10.72%
Other 63 5.32%
Multiple Choice Poll. Voters: 1185. You may not vote on this poll
post #556 of 566 (permalink) Old 11-28-2015, 02:49 AM
pigcar's Avatar
Originally Posted by phil8400 View Post
Well I got the front dome light leak. What's the cause of this? Sunroof?
Don't you have a circuit breaker?
http://www.importscollection.com/
pigcar is offline
post #557 of 566 (permalink) Old 01-08-2016, 12:23 PM
priell3's Avatar
Took my son's Patriot to the dealer yesterday to detect and fix the ongoing leak into the front passenger floor.
They called about an hour and a half after we dropped it off and said they had been running water on it for an hour and found nothing. The kept at it. Later in the afternoon they called back and said it was fixed.
The repair order said it was sealed/re-sealed around the front cowl and re-sealed at the windshield.
It is supposed to rain this week. We shall see.
MikeP
2015 Jeep Patriot Altitude Maximum Steel
2015 Dodge Journey AVP White
http://www.dodgejourneyforum.com/
priell3 is offline
post #558 of 566 (permalink) Old 01-12-2016, 02:12 PM
07 Pat, no sunroof, water in dome lights
My Jeep is parked upward on a sloped driveway. I'm getting water in the dome lights and major condensation on the inside of the windshield. I've temporarily scotch taped the top outside windshield to body joint; that didn't help.
I notice the body to windshield side gasketing is somewhat loose so I definitely see a water path from the top corners of the windshield/body joint down along the side of the windshield. ( I'd want to silicone this up only as a last resort). I just can't see how it would run uphill to get into the lights. I'd appreciate any insight to this.
jcarr is offline
post #559 of 566 (permalink) Old 01-16-2016, 05:49 AM
Jason31's Avatar
re
After a very heavy rain this spring, water began pouring out of the map light as I drove. The car is now back at the dealer for a third attempt at a repair, after two subsequent rain/leaking events.
Jason31 is offline
post #560 of 566 (permalink) Old 01-16-2016, 06:54 PM
Grahamburglar's Avatar
I had the map light leak one day. I read on the forums that you can basically snake a line of 0.8 or smaller weed-eater line down the sunroof drains to clear any clogs. I did that and haven't had any leaks since. I also opened up that light and dried everything out with shop towels and a blow dryer just to make sure I don't end up with mold or anything.
That was a few weeks ago. Since then I drove it to Utah, and camped overnight in snowy conditions (got about 3 inches of snow overnight). So far, so good. Haven't seen any other leaking. I'll just cross my fingers and knock on wood now. ;p
Grahamburglar is offline
post #561 of 566 (permalink) Old 01-22-2016, 03:19 PM
Hey Jason31,
TSB 23-005-13 may relate to your vehicle:
SUBJECT:
Water Leaks At The Front And/Or Rear Roof Area
OVERVIEW:
This bulletin involves inspecting the front and/or rear of the headliner for dampness. If
necessary add additional seam sealer to the roof ditch and replacing the front and/or rear
sunroof drain tubes or grommets.
MODELS:
2007 - 2010 (MK) **Compass** / Patriot
NOTE: This bulletin applies to vehicles built before August 20,2010 (MDH0820XX).
SYMPTOM/CONDITION:
Water leaks from the roof ditch and sunroof area.
JeepCares is offline
post #562 of 566 (permalink) Old 01-23-2016, 12:59 PM
ATFXINK's Avatar
Dome light leakage -Dealership replaced the track and "roof gutter" by removing inside headliner and focusing on sunroof drainage spots. Sealed and replaced. No leaks after water pressure test and heavy rains
ATFXINK is offline
post #563 of 566 (permalink) Old 07-25-2016, 07:49 PM
jammey97's Avatar
Nice storm last night. Nice pool of water in my '16 Pat this morning. Came in through the map lights. Looks like it pooled into the Nav unit and shorted that out as well.
Dropping it off at the dealer tomorrow for them to 'inspect' it.
jammey97 is offline
post #564 of 566 (permalink) Old 09-20-2016, 07:05 PM
Diane1611's Avatar
No water leaks in my 2010 Patriot.
Diane1611 is offline
post #565 of 566 (permalink) Old 01-27-2017, 01:17 AM
Mine is the latest model of patriot. But i do face the problem of side door leakage. What might be the reason for it?
CharlesCookJ is offline
post #566 of 566 (permalink) Old 01-27-2017, 05:39 PM
Your new Patriot is leaking? Take it in for warranty repair.
breadtruck is online now
