Patriot Water Leak Poll - Page 2 - Jeep Patriot Forums
View Poll Results: Have you experienced water leaks?
No leaks - nice & dry inside 703 59.83%
Firewall leak 26 2.21%
Sunroof leak 185 15.74%
Roof leak other than sunroof 146 12.43%
Side doors leak 30 2.55%
Rear hatch leak 127 10.81%
Other 63 5.36%
Multiple Choice Poll. Voters: 1175. You may not vote on this poll
post #16 of 564 (permalink) Old 12-31-2007, 03:31 PM
nearly.normal.jimmy's Avatar
Aftermarket sunroof = no leaks.
Haven't noticed anything else.
Although I park under a carport, only have 2500 miles and we are experiencing a drought.
I do use the laser car wash, and have been dry on the other end of it.
I am very suprised and saddened at the # who are having problems.
This must be the 'flappen hood' of 2008.
Now we just need a youtube video.
Home Grown Patriot Info Site<--clicky
Before: 4x2, 2.4L, 26F, CVTII, Sirius, Single CD
After: Nav Radio, Sunroof, Front Plate Holder, Rear Reading Light, Front Tint, Splash Guards,
Front Air Deflector, iPod integration, Pioneer 6982 6"x9",Infinity 10.7t tweeters, ScanGaugeII,
Billet Antenna, K&N Air Filter, Side Air Deflectors (removed)
nearly.normal.jimmy is offline
post #17 of 564 (permalink) Old 01-01-2008, 12:03 AM
Wheezy's Avatar
Originally Posted by Gaze View Post
Just experienced a leak this morning. This is the 2nd time I'll have my Patriot back to the dealer for the leaking sunroof issue.
What did they say was wrong with it the first time, and what did they do to (not?) fix it?
Wheezy is offline
post #18 of 564 (permalink) Old 01-01-2008, 01:06 AM
No leaks...had it since April/07...FDII...I did get the sirus radio w/mine...I didn't know if there is a wire that goes from this antennae through the roof, following the headliner to the front of the Jeep and into the radio…Any chance this has a bad seal on some of these?
snowpatriot is offline
post #19 of 564 (permalink) Old 01-01-2008, 07:52 PM Thread Starter
ray
The poll suggests that about 1 out of 10 owner get water seepage of some kind. That sounds high, but there are only 63 votes so far. We need a few hundred more votes to get a more accurate picture.
ray is offline
post #20 of 564 (permalink) Old 01-01-2008, 09:17 PM
Wheezy's Avatar
My Patriot goes in for the day tomorrow so hopefully I'll find something out as to why my Patriot started leaking after 6 months of being perfectly fine...
Wheezy is offline
post #21 of 564 (permalink) Old 01-01-2008, 11:15 PM
Gaze's Avatar
Send a message via AIM to Gaze
They blamed it on some pinched seals the first time and replaced them but apparently not properly or that wasn't the biggest problem. I'll be giving them hell when I take it there tomorrow night. Last time they left a few fingerprints on the headliner that thankfully wiped right off... none of that crap this time.
Gaze is offline
post #22 of 564 (permalink) Old 01-02-2008, 12:15 AM
No leaks at 500 miles. Production date July 2007 with 12/20/07 purchase/delivery date.
kucing is offline
post #23 of 564 (permalink) Old 01-02-2008, 04:42 AM
Bone dry.Production mid Nov.Picked up 27Dec.100 miles
charlieB is offline
post #24 of 564 (permalink) Old 01-02-2008, 12:29 PM
Wheezy's Avatar
The dealership just called and said that the sunroof drain tubes were blocked, so they'll have to take off the headliner and replace/fix them, so I'll probably get it back in about 4hrs.
Wheezy is offline
post #25 of 564 (permalink) Old 01-02-2008, 12:36 PM
Gaze's Avatar
Yeah... sounds about the same as what they told me. Hopefully yours stay "clean" a little longer than mine did.
Gaze is offline
post #26 of 564 (permalink) Old 01-02-2008, 06:26 PM
Wheezy's Avatar
Got the Jeep back, here's an excerpt from the sheet that was given to me when I picked it up:
Found bulletin for repairing sunroof drain tubes. Remove headliner assembly and all 4 drain tubes. Repair as per TSB #23-043-06.
Anyhow it says they tested it and it didn't leak so I guess I'll believe that the fix has worked unless I get another cold shower in the middle of winter.
Wheezy is offline
post #27 of 564 (permalink) Old 01-03-2008, 03:55 PM Thread Starter
ray
Don't forget, this poll is for "non-leakers" as well.
ray is offline
post #28 of 564 (permalink) Old 01-03-2008, 06:34 PM
Sigpnut's Avatar
I keep finding a film of water when I roll my windows up after having them down. Anybody had this problem or got an idea if it is normal?
2008 Jeep Patriot Limited 4x2 Metallic Steel Blue W/All Extras
Sigpnut is offline
post #29 of 564 (permalink) Old 01-03-2008, 07:04 PM
neilcrichton's Avatar
There's a problem with the accuracy of the poll. 3.8% of respondents have had a leak in the sunroof, but we don't know how many respondents have or don't have a sunroof. It would be helpful to know what percentage of sunroofs leak.
neilcrichton is offline
post #30 of 564 (permalink) Old 01-03-2008, 07:15 PM
Agreed. I was thinking the same exact thing.
However, as it stands, the numbers are pretty scary to me.
unclejjg is offline
