SERVICE BULLETIN: 23-005-13 2007 - 2010 MK Front/Rear Roof Water Leak - Page 2 - Jeep Patriot Forums
post #16 of 24 (permalink) Old 07-30-2013, 04:21 PM
Lee, thank you very much for your fast replies! I tried attaching the TSB for anyone who might want to see it in the future, but the forum only allows a max size of 19.5kb and the file is over 500kb. Perhaps a moderator can attach it or someone else can remote host it.
It looks like it includes new drain tube part numbers for 2012-13 vehicles as well as the replacement of a right-angle grommet for the front drain tubes with a straight one. Many others on this forum have argued that this kink was the problem all along.. fingers crossed!
-Mike
mikejeep is offline
post #17 of 24 (permalink) Old 07-31-2013, 08:51 AM Thread Starter
Here's the wording - the problem is the eleven figures that don't show:
PARTS REQUIRED:
Qty. Part No. Description
1(AR) 57010774AA Tube, Right Front Sunroof Drain (Patriot)
1(AR) 57010773AA Tube, Left Front Sunroof Drain (Patriot)
2(AR) 05160134AC Tube, Rear Sunroof Drain (Patriot)
**1(AR) 68082597AB Tube, Right Front Sunroof Drain (Compass)**
**1(AR) 68082598AB Tube, Left Front Sunroof Drain (Compass)**
**2(AR) 05160043AB Tube, Rear Sunroof Drain (Compass)**
2(AR) 05027191AA Grommet, Front Sunroof Drain Tube
1(AR) 05116250AD Molding, Right Roof Ditch
NUMBER: 23-005-13
GROUP: Body
DATE: February 27, 2013
1(AR) 05116251AD Molding, Left Roof Ditch
1(AR) NPN Kent Hi-Tech Clear Seam Sealer P10200 or
Equivalent (One 5oz. tube services one
vehicle)
1(AR) NPN 3M 08984 General Purpose Adhesive
Cleaner or Equivalent (1oz. services one
vehicle)
INSPECTION PROCEDURE:
1. Inspect the headliner at the front and rear of the vehicle. Was there any dampness
and/or water stains on the headliner?
a. Yes>>> Proceed to Step #2.
b. No>>>This bulletin does not apply continue further diagnosis.
2. Lower the headliner. Perform a water flow test to the entire roof. Where there any
signs of water leaking?
a. Yes>>> Proceed to Step #3.
b. No>>> This bulletin does not apply continue further diagnosis.
3. If the water was leaking from the front and/or rear of the roof area and built before
12/10/2009 and is equipped with convoluted drain tubes (Fig. 1) proceed to Step #1 of
the repair procedure. If the vehicle was built after 12/10/2009 proceed to Step #1 of
roof seams and rear body plugs.
Fig. 1 Convoluted Drain Tube
1 - Convoluted Drain Tube
2 - Sunroof Module
REPAIR PROCEDURE:
1. Remove the right and left front sunroof drain tubes. Refer to the detailed removal
procedures available in DealerConnect> TechCONNECT under: Service info> Body>
Sunroof> Tube, Sunroof Drain> Removal.
2. Is the vehicle equipped with a manual transmission or automatic transmission?
a. If the vehicle is equipped with a automatic transmission proceed to Step #1 install
left front drain tube for vehicles equipped with an automatic transmission only.
b. If the vehicle is equipped with a manual transmission proceed to Step #1 install left
front drain tube for vehicles equipped with a manual transmission only.
INSTALL LEFT FRONT DRAIN TUBE FOR VEHICLES EQUIPPED WITH A
AUTOMATIC TRANSMISSION ONLY:
1. Remove the air cleaner body. Refer to the detailed removal procedures available in
DealerConnect> TechCONNECT under: Service info> Engine> Air Intake System>
Body, Air Cleaner> Removal.
2. Remove the two nuts retaining the master cylinder to the brake booster and move it
forward so the left front sunroof drain tube routing path can be accessed behind the
left front strut tower (Fig. 2).
NOTE: Do not disconnect any brake lines connected to the master cylinder.
Fig. 2 Brake Booster
1 - Nuts
3. Remove the lower left side cowl trim panel. Refer to the detailed removal procedures
available in DealerConnect> TechCONNECT under: Service info> Body> Interior>
Panel, Cowl Trim, Side> Removal.
4. Remove the kneeblocker. Refer to the detailed removal procedures available in
DealerConnect> TechCONNECT under: Service info> Body> Instrument Panel>
Kneeblocker> Removal.
5. Route the new left front sunroof drain tube through the engine side of the bulkhead
(Fig. 3)
Fig. 3 Left Front Drain Tube
1 - Strut Tower
2 - Air Box
3 - Master Cylinder
4- Drain Tube Grommet
NOTE: From underneath the left side instrument panel, roll back the jute between
the bulk head and the instrument panel at the top left to verify drain tube
routing.
6. Verify the grommet is correctly seated in the bulk head using a mirror and position it
behind the strut tower looking at the upper right corner (Fig. 4).
NOTE: **If the grommet is damaged or has a 90°elbow and is not a straight grommet,
replace it with new grommet PN 05027191AA.**
Fig. 4 Drain Tube Grommet Seated
1 - Drain Tube
2 - Bulk Head
7. Connect the drain tube to the sunroof drain spout and drain tube pass through
grommet.
8. Install the Kneeblocker. Refer to the detailed removal procedures available in
Kneeblocker> Installation.
9. Install the lower left side cowl trim panel. Refer to the detailed installation procedures
Panel, Cowl Trim, Side> Installation.
10. Re-secure the master cylinder to the brake booster with the two nuts previously
removed.
11. Install the air cleaner body. Refer to the detailed Installation procedures available in
Body, Air Cleaner> Installation.
12. Skip the next procedure for manual transmission only and proceed to Step #1 RIGHT
FRONT SUNROOF DRAIN TUBE.
INSTALL LEFT FRONT DRAIN TUBE FOR VEHICLES EQUIPPED WITH A MANUAL
TRANSMISSION ONLY:
2. Remove the master cylinder. Refer to the detailed removal procedures available in
DealerConnect> TechCONNECT under: Service info> Brakes> Hydraulic/Mechanical>
Master Cylinder, Brake> Removal.
4. Remove the clutch pedal for access to the bulk head where the drain tube will be
routed.
5. Route the new left side sunroof drain tube through the engine side of the bulkhead
(Fig. 5).
routing.
Fig. 5 Right Front Drain Tube
1 - Right Strut Tower
2 - Drain Tube Grommet
behind the strut tower looking at the upper right corner (Fig. 6).
Fig. 6 Drain Tube Grommet Seated
1 - Drain Tube Grommet
2 - Bulk Head
grommet.
8. Install the clutch pedal.
10. Re-instal the master cylinder. Refer to the detailed Installation procedures available in
Master Cylinder, Brake> Installation.
RIGHT FRONT SUNROOF DRAIN TUBE:
1. Remove the lower right side cowl trim panel. Refer to the detailed removal procedures
Panel, Cowl Trim, Side.
2. Route the new right side sunroof drain tube through the engine side of the bulkhead
(Fig. 7).
Fig. 7 Right Front Drain Tube
routing.
3. Position a mirror behind the right strut tower and verify the grommet is properly seated
against the bulkhead(Fig. 8).
Fig. 8 Drain Tube Grommet Seated
2 - Bulk Head
4. Connect the drain tube to the sunroof drain spout and drain tube pass through
grommet.
5. Install the lower right side cowl trim panel. Refer to the detailed installation procedures
REAR DRAIN TUBES:
1. Remove the right and left rear drain tubes. Refer to the detailed removal procedures
available in DealerConnect> TechCONNECT under: Service info> Body> Sunroof>
2. Install the new rear sunroof drain tubes. Refer to the detailed installation procedures
Tube, Sunroof Drain> installation.
3. Proceed to Step #1 of the verification procedure.
ROOF SEAMS AND REAR BODY PLUGS:
1. Using a trim stick remove the right and left roof ditch moldings.
2. Remove all adhesive residue in the roof ditch with 3M General Purpose Adhesive
Cleaner 08984 or Equivalent with a general purpose cloth.
3. Apply a clear paintable seam sealer such as Kent Hi-Tech Seam Sealer P10200 or
equivalent along both sides of the roof ditch seam as shown in (Fig. 9).
Fig. 9 Roof Ditch
1 - Clear Seam Sealer
4. At the rear check all body plugs and grommets (Fig. 10) and verify they are properly
seated.
Fig. 10 Grommets And Plugs
1 - Grommets And Plugs
5. At the rear roof panel apply Kent Hi-Tech Seam Sealer P10200 or equivalent around
the patch shown in (Fig. 11) on the right and left side.
Fig. 11 Roof Seam
1 - Side Aperture
2 - Sealer
3 - Tailgate
6. Allow the sealer to fully cure per adhesive manufacturers recommendations.
7. Install the right an/or left roof ditch molding(s).
NOTE: When installing the roof ditch molding apply firm pressure to the molding so
proper wet is achieved to insure proper adhesion.
VERIFICATION PROCEDURE:
1. Perform a water flow test and verify there are no water leaks.
2. Return the vehicle to the customer.
POLICY:
Reimbursable within the provisions of the warranty.
JeepCares is offline
post #18 of 24 (permalink) Old 08-12-2013, 10:24 AM
Thanks for all the great information on this. I had an issue with my 07 in 09 where water came out of the dome light but they fixed it at no coast as a seal had failed. It is currently at the dealership for this TSB and they have told me that any parts required for this fix are covered under my warranty. I did purchase the Max care on top of the lifetime power train warranty though.
Fred
Chevyiiragtop is offline
post #19 of 24 (permalink) Old 04-04-2014, 08:21 AM
Nocturnx's Avatar
Apparently they still haven't fixed this problem. My 2014 I've only had for a month has water pouring through the front dome light. Ridiculous.
Would someone be able to email me the full PDF of the TSB? Thanks
Nocturnx is offline
post #20 of 24 (permalink) Old 04-04-2014, 01:46 PM Thread Starter
PM me a "real" email address.
post #21 of 24 (permalink) Old 06-18-2014, 07:37 PM
Hi Lee, Could you please e-mail me the Service Bulletin. rbherbert@shaw.ca
Thank you.
rbherbert is offline
post #22 of 24 (permalink) Old 10-09-2014, 03:23 PM
Could someone please email me the PDF of this information at twentyoneg@aol.com? I have been having this issue for years and nothing has helped. Now out of warranty. I hate this car!
twentyoneg is offline
post #23 of 24 (permalink) Old 04-21-2015, 01:37 AM
Jeep Cares, would you be able to email me a copy of the service bulletin?
actinicity@yahoo.com
Thank you very much!!!
weedum is offline
post #24 of 24 (permalink) Old 12-17-2015, 10:16 PM
Just had this issue with my 08. No water spots on my headliner yet. Is this a a fix that someone has done themselves?
Thanks for the PMs Lee
2008Patty is offline
