Hi All,
I have a 2016 4WD Patriot that I want to add a tow package to (receiver & wiring). I have a transmission cooler, so all good on that side of things.
My questions is what option would you all recommend?
OPTION 1: Have Uhaul install non-Mopar receiver and wiring for just under $400 ($254 parts, $135 installation)
OPTION 2: Purchase Mopar parts (reciever kit 82213567AB; wiring kit 82209280AE) myself and have Uhaul install (they confirmed they could do this) for $515 ($380 parts, $135 install)
OPTION 3: Have everything done at the dealership for just over $1000 ($323 parts, $690 installation).
I bought the car new back in August 2016 and am a little worried that Uhaul may do something to the car that would mess up my warranty (or the vehicle).
This was the response from my Service Manager at the dealership when I asked about the huge cost difference between them and Uhaul:
What should I do? Is it safe to use Uhaul, or is there a huge ($500+) benefit in having it done at the dealership? Factory parts, or aftermarket parts okay?
Thanks in advance for any advice!
"Yes, Uhaul can do it cheaper than anyone. However, they will not use factory parts. (Note: Not entirely accurate - If I purchase the factory parts, Uhaul will install them) We will register the option with Chrysler as a dealer-installed factory item, and we will install the correct wiring harness. Uhaul usually installs an adapter harness, which may or may not work in all cases."
