Engine Oil Cooler - Jeep Patriot Forums
4X2 Patriot Discussion 4X2 Patriot Discussion. Mods that are Street Orientated
(ie. Performance/Suspension, etc...)
post #1 of 28 (permalink) Old 02-04-2009, 02:23 PM Thread Starter
Engine Oil Cooler
Well I just ordered a 2009 2x4 manual Patriot. I noticed that there has been some discussion regarding the need/requirement of an engine oil cooler to tow 2000 lbs. Well, that package is not available on the 2009 Patriot for some unknown reason unless you get the off-road group which is expensive(is available on the Compass). I would think that towing 2000 lbs. with the 2.4 would be OK if one uses a little common sense and care not to excessively strain the engine and overheat the oil and water. Has anyone towed more than 1000 lbs. and what was the result? Also, would 100% synthetic oil be a better choice when towing? Thanks!!
Last edited by 63LeMans; 02-04-2009 at 06:58 PM. Reason: typo error and new information
63LeMans is offline
post #2 of 28 (permalink) Old 06-25-2009, 10:57 AM
KillaCam's Avatar
if you go through mopar's site they do have an engine oil cooler for towing for the 09 patriot...i think it's like $15 and comes with an installation guide? i'm probably going to be moving from NC to RI an will definitely be installing the oil cooling kit as well as a trailer hitch & wiring kit because i got the 4x2 limited w/CVT II that offers no towing or anything
try justforjeeps.com under cargo and racks for pats
KillaCam is offline
post #3 of 28 (permalink) Old 06-25-2009, 11:23 AM
homac's Avatar
You cannot tow more than 1000 lbs without the engine oil cooler. (You will be forever slowing down and pulling over) I know someone who towed roughly 1500 lbs and the engine overheated quickly.
The engine oil cooler does a surprising job at keeping things at a reasonable temperature. You should be able to have an engine oil cooler added. Regarding sythetic oil, if you fall into maintenance schedule "B" then a synthetic oil does help. 5w-30 Penzoil Platinium would be my recommendation.
82210700 Automatic/CVT
82210701 Manual
POTM July 2008 & December 2009
homac is offline
post #4 of 28 (permalink) Old 06-28-2009, 08:26 PM
Bought the kit for 2009, defintely a wise investment for $110 (dealer asks $149) installation is relatively simple. Why take the chance? Some say it's not needed or seems like a useless piece of mechanics, I say protect your investments, ie your jeep AND whatever it is your towing by being properly equipped.
09 Sport 4X2 - 5 Speed Manual, RV TOW Package: 2" reciever hitch, Prodigy brake controller, engine oil cooler kit - BF Goodrich All Terrain KO 225/70r16
rednosepitbull is offline
post #5 of 28 (permalink) Old 07-23-2009, 04:31 PM
anyone tried it
So has anyone tried towing 2000 lbs with the liberty? It seems like the horse power would be inadequate to tow that much.
co native is offline
post #6 of 28 (permalink) Old 07-23-2009, 10:52 PM
MCJ197731's Avatar
Part Number
Do you know what the part number is for the oil cooler? If so would it be the same for a 4x4 manual? Thanks.
MCJ197731 is offline
post #7 of 28 (permalink) Old 07-24-2009, 12:41 AM
homac's Avatar
82210701 Manual
homac is offline
post #8 of 28 (permalink) Old 08-01-2009, 08:21 PM
Penzoil?
82210701 Manual
I wouldn't use Penzoil if my life depended on it. Oh wait, it does!
slick is offline
post #9 of 28 (permalink) Old 08-01-2009, 10:21 PM
craig03's Avatar
I have the Oil Cooler stock with my veh. We drove from NH to IL 4 full size adults, lots of luggage, summer time heat, straight drive only stopping for gas... My oil temp never hit the 1/2 way mark!!! YUP it was just below the 1/2 all the way there and on the way back. Granted I wasnt towing anything but still, seems to work.
Life is short, live hard!
craig03 is offline
post #10 of 28 (permalink) Old 08-07-2009, 05:33 PM
R.E.M.'s Avatar
82210701 Manual
Is this the same for the 4x4 version????
R.e.m.
Jeep Patriot 2009 North Edition 4x4, North Plus, Wheels and Sun and Sound packages, Mopar Fog light, Mopar hitch, Mopar window side vents, Engine oil cooler, black muffler, more to come...
R.E.M. is offline
post #11 of 28 (permalink) Old 08-07-2009, 08:23 PM
homac's Avatar
Yes.
homac is offline
post #12 of 28 (permalink) Old 08-07-2009, 10:08 PM
misterchristophe's Avatar
Here'S a pdf file that shows how to install for manual or automatic. Step by step with illustrations
http://www.mopar-accessories.com/en-...r.ashx?id=2147
misterchristophe is offline
post #13 of 28 (permalink) Old 09-06-2009, 01:48 PM
How did you get an oil temp gauge on your Patriot?
2009 Green Patriot Sport 5-spd 4wd
1996 Cherokee 4.0 5-spd
Wooden Dog is offline
post #14 of 28 (permalink) Old 09-06-2009, 09:33 PM
POTM November 2008
jepstr67's Avatar
I would love to have a temp sensor and readout at radiator input and output for coolant temp, and one on the oil cooler input and output.
Knowing what the temps are before the fluid goes into the engine or oil cooler to absorb the heat is useless, but it would still be interesting to know just how much heat the cooling system takes away and how it is affected by the Air conditioner.
NO INCUMBENTS!
____,_____
//_l_l_,\____\,__
l_/--\_l__l/--\0lllllll0
_(o)) _) _(o))---))_______________________________
jepstr67 is offline
post #15 of 28 (permalink) Old 09-09-2009, 08:51 PM
I just towed a 5x7 UHaul (900 lbs) with roughly another 1000lbs in the back. Made several trips back and forth total about 500 miles. With the AC on my temp gauge never went over half. Felt fine towing. I kept it under 65. I ordered the tow package with my 08 so i have the cooler. I would definitely order that cooler for the 09 if you planned on doing any towing at all.
roberttroll is offline
