Patriot wheels sizing - Page 5 - Jeep Patriot Forums
Suspension and Wheels Articles covering suspension, lifts, gears, axles
as well as tires and wheels.
post #61 of 94 (permalink) Old 01-11-2012, 11:15 AM
Anyone know of a 15" that will fit? I've got some older wheels from my TJ laying around that aren't listed above.
Was thinking of getting some snow/ice/winter tires and mounting them on the TJ wheels and putting them on the Patriot, and leaving the nice 17" wheels for summer.
225-70-15 is about the same as the 215-60-17 that's currently on my Patriot.
SmurfJK is offline
post #62 of 94 (permalink) Old 02-12-2012, 04:57 PM
2012 POTY
the_jeep_now's Avatar
To add to the knowledge bank. 16'' alloy rims from Liberty Renegade do not fit. The rim will not clear the caliper.
"Jeep isn't just another vehicle, it's the lifestyle."
TJN's Build Thread
TJN's Tour
the_jeep_now is offline
post #63 of 94 (permalink) Old 02-12-2012, 05:47 PM
Metaxa's Avatar
Heh, I was browsing and come her and look what has popped up.
And, look at what i found elsewhere...a data base that matches your vehicles wheels to any and all others that use the same spacing.
http://www.roadkillcustoms.com/hot-r...2C+4WD#Matches
Scroll down on that page, I'd already done the search when I copied the URL.
I'm going for the 1982 Lincoln Town car wheels, you?
Metaxa is offline
post #64 of 94 (permalink) Old 02-12-2012, 05:55 PM
MrJeepR44's Avatar
According to that link, the Cherokee 15" wheels could fit, and so would the Liberty wheels The Jeep Now tried... but they don't. Unless I read it wrong
MrJeepR44 is offline
post #65 of 94 (permalink) Old 02-12-2012, 07:10 PM
Metaxa's Avatar
Oh, yea, its from the Internets so...
proceed at your own risk or something like that.
Metaxa is offline
post #66 of 94 (permalink) Old 02-12-2012, 07:35 PM
Cherokar!
Tyler-98-W68's Avatar
It's earlier in this thread or another, but I have pictures from when I tried a
16" liberty rim, and wouldn't clear the caliber on the front tires, back tires were fine.
With a small spacer you could run them no problem
2016 Cherokee Trailhawk V6
3.2L V6
Interior LED Conversion
LED Signal Lights
AFE Intake
245/70/17 Falken Wildpeak AT3/W
Tyler-98-W68 is offline
post #67 of 94 (permalink) Old 02-12-2012, 10:14 PM
2012 POTY
Tyler, I did see your thread. This is a little bit different rim that your tried on. I currently run 16'' steel rim from '04 Liberty with no problems and no spacers.
TJN's Build Thread
TJN's Tour
post #68 of 94 (permalink) Old 02-20-2012, 12:19 PM
michael.leinen's Avatar
Need help on this one...
Ok so Im about to get my first set of rims for the Pat. IM SO LOST though. I understand the rim size and bolt pattern BUT the offset and backspace I need a better understanding of. Im looking at Cragar or Pro Comp rims. Please help me out here.
michael.leinen is offline
post #69 of 94 (permalink) Old 02-22-2012, 07:56 PM
FunkRider's Avatar
If they touch the back side of the spokes just add a small wheel spacer and they will clear. 1/4 inch spacer is all you need. Small wheel spacers won't hurt anything. Its the thick ones that don't bolt on to the hub that are sketchy.
FunkRider is offline
post #70 of 94 (permalink) Old 02-22-2012, 08:19 PM
2012 POTY
I sold that set to a happy Cherokee owner and bought Unique 297 instead.
TJN's Build Thread
TJN's Tour
post #71 of 94 (permalink) Old 05-24-2012, 07:36 AM
Ramiroum's Avatar
Post
Originally Posted by heckler View Post
Ravine
PURCHASE AT YOUR OWN RISK - ONLY ONE MEMBER HAS USED WHAT LOOKS LIKE THIS WHEEL
* 15x8 aluminum
* 5 on 4.5" bolt pattern
* Backspacing = 5.5"
* Optional wheel with 30" tire package
* Offset = +25 mm
Well, over a couple of years later and thanks to our commitment to research (that's how I call our inner desire of messing up with things that were just fine to begin with) we can now say these puppies fit...(if you are willing not to get scared by a very low clearance between the wheel and the brake caliper on the front wheels). but so did JeepingLG, Bwpakk, Sandstone & myself.
RamiroUM
Ramiroum is offline
post #72 of 94 (permalink) Old 09-14-2012, 10:45 PM
pattymcgaff's Avatar
Hey guys, new Riot owner and trying to figure all this out... I have FDII and 215/65/17 Wranglers and am wanting move to a beefier tire on a smaller rim. I have found a set of old Cherokee rims for $100. They are 15x7, with 5 bolts and a 4.5" diameter. All I know is that these rims are a medium offset, whereas the stock Riots are high offset... Any comments? Thoughts?
Patrick
pattymcgaff is offline
post #73 of 94 (permalink) Old 09-19-2012, 09:34 PM
full house's Avatar
$100 rims is a good price.
full house is offline
post #74 of 94 (permalink) Old 10-27-2012, 12:06 AM
15" Rims and Tires
Thought I would gather all the 15" rim info I found together to make it easier for those who are interested in fitting their MK's with 15" rims and tires. If anyone knows of anything that should be here but isn't, let me know and I'll add it in.
A comment on caliper clearance:
Even when the 15" rims fit, clearance between front calipers and the rim can be very close. This may be more of a concern for steel rims as they can bend.
* 15" Rims That Fit *
Ravine alloy 15x8
These rims are lighter than stock 17" rims (18 vs 22 lbs), which can help offset the weight of larger tires.
There are at least 4 members who used this rim with various tires.
JeepinLG - 30x9.5? with no mods to calipers reported, trimmed pinch weld cover in wheel well.
My Jeep Green Patriot With RR Lift, Wrangler 15" alloy wheels and Wrangler GS-A Tires
Bwaak - 235-70-15 - No mods or rubbing reported.
15"rims on a patriot?
Sandstone - 30x9.5 GSA with slight rubbing, 235/75/15 Duratrac with no rubbing or mods.
15" Ravine Wheels ('06) w/ 30x9.5R15 Goodyear GS-A.
http://www.jeeppatriot.com/forum/sho...d.php?p=380132
Ramiroum - 275/60/15 No mods or rubbing reported.
275/60 on 15x8 Ravines
Jeep "Turbine" alloy rims
Only one member has these. They are older rims from late 1970's / early 1980's vehicles.
Wolf - 235/75/15 - No mods reported
15 inchs mags 235/75/r15 tires
Flat Five - Steel
Some fit, but others don't. May need spacers or caliper mods.
ChuckTerry - 235-75-15 - No mods reported
Upgrade to 15" wheels
koolkatken83 - 235/75/15 Caliper Mods(grinding) needed
235/75R15 on Powder Coated Wheels
Rims that won't fit without mods (spacers, etc)
Jeep Canyon
5 Star Cherokee
post #75 of 94 (permalink) Old 11-19-2012, 03:32 PM
Unhappy Question about stock 16 inch wheels and RRO lift.
Hello Wise Forum,
My 11 4wd Pat Sport is in the shop right now, decided to get someone else (tire shop) to do my RRO lift for me to save trouble with alignment issues. What should have been an easy job for even a shadetree like me, was a nightmare for them, getting things lined up etc. They were given the instructions, and it was not the first lift they have ever done. Long and short is that I wanted to fit a set of 235 65 16's on and there is no room! the rear drivers spring/strut barely clears the inside sidewall of the stock tire!?! Am I missing something? Could the lift be installed wrong? Tire guy is searching skinny alternatives for me as we speak!
Help!!
2011 metallic silver Sport 4X4 CVT, RRO lift but still deciding on tire and size, homestyle power locks and groovy westech floormats.
Timu8 is offline
bolt pattern, wheel offset
You may not post new threads
