Front Brake Pad Replacement - Page 4 - Jeep Patriot Forums
Suspension and Wheels Articles covering suspension, lifts, gears, axles
as well as tires and wheels.
post #46 of 54 (permalink) Old 03-02-2016, 01:17 PM
SitAndWatch's Avatar
SitAndWatch is offline
post #47 of 54 (permalink) Old 03-18-2016, 03:40 PM
When doing the front brake pads, if you look over the top to the caliper and look down
to see the piston, there is room on the side of the piston closest to firewall. Insert a
screwdriver and pry on the piston being careful of the rubber band on the piston. Put
some pressure on the piston by prying on the screwdriver moving the piston back into
the caliper about 1/8 inch and the caliper will easily come off. Pry on the screwdriver
slowly and you will feel the piston move. Easy to do once you've done it.
wpeck2 is offline
post #48 of 54 (permalink) Old 04-29-2017, 06:50 PM
u35828's Avatar
Excellent information...the only thing missing for me is the wrench sizes needed for the bolts that attach the caliper to the steering knuckle, along with the rear bracket. Trying to save myself multiple trips to the hardware store.
Thanks in advance,
John
"There's no replacement for displacement."
- Walter Owen Bentley
u35828 is offline
post #49 of 54 (permalink) Old 04-29-2017, 09:45 PM
14mm for the slide pins and 18mm for the bracket-to-knuckle bolts.
Sent from my SM-N910V using Tapatalk
thesavo is offline
post #50 of 54 (permalink) Old 04-29-2017, 09:51 PM
u35828's Avatar
Thanks, thesavo. This may sound like a dumb question, but the are the bracket bolts for the back calipers the same size as the fronts?
u35828 is offline
post #51 of 54 (permalink) Old 04-29-2017, 10:04 PM
I haven't yet done the rears, sorry.
thesavo is offline
post #52 of 54 (permalink) Old 04-30-2017, 08:05 AM
u35828's Avatar
Thesavo, no problem. I just read in another forum that all one needs to do with the rear calipers is swing it out of the way by removing one of the guide pins, as if to change the brake pads.
u35828 is offline
post #53 of 54 (permalink) Old 04-30-2017, 11:53 AM
excellent post. thank you metaxa
mercv12 is offline
post #54 of 54 (permalink) Old 05-01-2017, 10:31 AM
u35828's Avatar
You need a 14mm socket to remove the rear rotor bracket (I have the 262mm rotors).
u35828 is offline
You may not post new threads
